Hi all,
Just thought I'd post up some pics of my amber to blue interior backlighting conversion.
Before I start, let me just say that this is definately not a DIY type of project and if you should take EXTREME caution when modifying your OEM BMW circuit boards and switches. The problems and setbacks I encounted with this project were numerous, and if/when I get time I'll note them all done for you.
I decided to do this conversion as I'd always wanted a blue backlit interior I know BMW is amber/orange by standard.. and some of you may think the blue is wrong, but I LOVE it, and it's what I wanted. Also, I am a strong believer in "BMW Individual" program, but of course, there's no way BMW were going to do this mod for me! I want my Bimmer to be a one of kind, so that's another reason I took the plunge and did this. A big thanks for SilverLight who is (to my knowledge) the only other person in the world to attempt this kind of project. I know there have been people who have changed a switch or two, but this was a complete overhaul. There are no original LED's left in the car
All orange/amber LED's where moded to blue, and all green switch (on) indicators, as well as turning indicators, and any other green lights on the cluster, were all changed to amber.
This kind of job, apart from taking you car apart completely to bits, involved LED's that are EXTREMELY small. They were mostly surface mounted 0603's, 1206's, and PLC2 type. The size of some of these LED's measure only 1.6mmx0.6mm - yes you need a magnifying glass and specialised equipment for this kind of resoldering. The LCD panels (air-con and cluster odomotor) were also changed with alot of patience, and testing that probably hadn't been done before. I had no help or resources to turn to on this but in the end it turned out great.
I am still 'tweaking' some things... the stereo/NAV lights, although the same, appear dimmer. THis is because resistors on boards are filtering out for the factory orange LED's which run at a lower voltage and blue LED's typically require a higher voltage. I will be pulling the NAV out and changing these resisters soon, but again, like many parts of this project, work was done and re-done many times until I was happy with the result.
In the end, I replace over 150 LED's of various types and sizes. There were also several resisters I changed, or am in the process of changing to adjust voltage flow to different parts withint the car. The cost of this project (parts only) was approx. US$250. It took approx 2 weeks, almost full time to complete.
I have an electrical background, so again I stress to take care if you ever think about doing something like this. There was no documentation from BMW on what the specifications of their parts are, ie. voltage, or MCD (brightness) values so a lot of what I done was by trial and error, and from information shared from SilverLight, a BMW moder from Germany.
Photos are differcult to capture the true look but I hope you get the idea from below. Other parts done but not shown include sunroof switch and the 2 pin whole lights, ashtray light, front and rear, and let's not forget the boot/trunk release
Enjoy,
BoD.
Enjoy,
BoD.
