Old 10-14-2016, 07:36 AM   #1
mammadovadil
My Ride: BMW E46 330i
Engine oil level light comes on unexpectedly
Hi everyone.
First of all, this is my first post here, so this may not be perfect.
I have 2002 BMW E46 330i. As many others, I also have to top of engine oil time-to-time. When engine oil is low, generally yellow engine oil light came on so I added about 1 litters of oil.
Previously, I used 5W-40 Castrol Magnatec and 5W-40 Castrol edge. Last time, I gave a try to 5W-30 Shell Helix Ultra. As I usually top-off engine oil, 0.5l Castrol Magnatec and 0.5l Castrol Edge left in my trunck. So, when last time yellow engine oil light came on, I poured Castrols on top of Shell. Because according to, my cars manual I can do this, I can even use other oils which are not "BMW High Performance Synthetic Oil".
If you are unable to obtain an approved
Oil," you may use small volumes of
other approved synthetic oils for
topping up between oil changes. Use
only oils with the specification API SH
or higher.
The issue:
After doing this I have problem whith engine oil light. Now, when I start the warmed-up engine, afer approximatelly 10 seconds yellow engine oil light comes on, stays for about 10 seconds and goes out. I checked oil level manually and it is normal. Please, pay attention that, this does not happen when I start the engine when it's cold (i.e. in the morning), it only happens when I drive car for some time, shut down car (i.e. go to store) and when I re-start warmed-up engine it happens.
Have anybody experienced situation like that? Is my oil level senser malfunctioning? How can this issue be solved?
B.t.w: I absolutely love my car . Thanks in advance.
mammadovadil is offline   Reply With Quote
Old 10-14-2016, 08:08 AM   #2
markusmarkus
My Ride: 2001 330Ci
The oil level sensor is located in the bottom of the oil pan. Buy a new Hella sensor and change it the next time you change the oil. Your engine is, in BMWeze, an M54B30 engine. They burn oil as the oil control rings require a consistent crankcase vacuum. The crankcase ventilation system (CCV) is a piece of crap. The only real solution is an oil catch can.
Old 10-14-2016, 08:11 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
https://www.fcpeuro.com/products/bmw...-12617508003-1
Old 10-14-2016, 08:23 AM   #4
mammadovadil
Originally Posted by Solidjake View Post
markusmarkus and Solidjake, thank you for reply. I have replaced CCV in the past and decreasing of oil was not resolved.
Do you think that, my issue is according to oil sensor? But it began to happen after a day I mixed 5W-40 Castrol and 5W-30 Shell. Also, it does not show up when engine is cold. I do not want to change oil sensor, beacuse I do not think that it is because of it. How can I be sure that the reason is oil sensor itslef or something different?
Old 10-14-2016, 08:28 AM   #5
markusmarkus
My Ride: 2001 330Ci
Check the engine oil level after the engine has been off for 5 minutes after reaching full temperature. That's the "gold standard" for determining the actual oil level. If the yellow oil light comes on even though the oil level is fine the sensor is bad. It's a typical failure. Mixing oils won't hurt the engine as long as both oils are synthetic.
Old 10-14-2016, 08:36 AM   #6
Manolito
My Ride: '04 325iT Manual
If you have an e46, your oil level sensor will fail. It is important to make sure the electrical connection to the sensor is clean and tight, but the sensor will eventually fail.
My experience agrees with Marcus. The Hella sensor I put in the 330i seems to be working OK after six months. The cheaper sensor I put in the 325i started throwing false low oil level lights almost immediately after being installed. Unfortunately, I did not make a note of what brand it was.
I doubt that mixing oil brands contributed to your sensor failure.
Manolito is offline   Reply With Quote
Old 10-14-2016, 09:13 AM   #7
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
^This. Very common problem.
Don't rely on the sensor to tell you when you need oil, even when it's working properly. It's good practice to check the oil level via the dipstick at least once a week.
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 10-14-2016, 09:19 AM   #8
juslookin
My Ride: 05 330ci ZHP
And when you change the sensor be very gentle of the 3 nuts/studs holding it in. They will snap. Ask me how i know. Still only have 2 nuts holding mine in until i can get the stud out. No leak tho!
juslookin is offline   Reply With Quote
Old 10-14-2016, 12:53 PM   #9
mammadovadil
Thanks everyone for reply.
Yes, I know that. I let the engine to stay about 10 minutes on even place then I check oil with dipstick.
Thanks for the tip.
I will wait until next oil change. If the problem persist then I will consider replacing oil sensor. Because, as it began immediately after mixing oils I am a bit suspicious about this situation. I will let you know about the results, in case someone needs it.
Old 10-14-2016, 01:41 PM   #10
das_autobahn
My Ride: 2004 330ci coupe
surprised fruity guy didnt chime in saying replace engine...
das_autobahn is offline   Reply With Quote
330i, bmw, e46 2002, engine oil, engine oil light
