Can't get new steering coupler (guibo) back on. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BimmerWorld
Old 11-24-2013, 06:42 PM   #1
tlester
My Ride: 2001 330i
Hi all -
My 330i is up on ramps right now as I'm replacing my steering coupler. The old one is out and the new one is partially on. HOWEVER... as I put it back on the rack side (the "toothed" side), I can only get it half way down and it stops. I can't go any further. The bolts are completely out.
Any tips on getting this thing back in? I can't get enough leverage to force it down. I've lubed it up and no luck.
If you have any suggestions, please let me know.
-Tom
tlester is offline   Reply With Quote
Old 11-24-2013, 07:24 PM   #2
cdemott
My Ride: 330ci
Try opening it up with a screwdriver at the split
cdemott is offline   Reply With Quote
Old 11-24-2013, 07:40 PM   #3
tlester
My Ride: 2001 330i
I tried that... I guess I can try to go a little more and see what happens. I wish I could get a little more leverage on it.
Old 11-24-2013, 08:08 PM   #4
Dave1027
My Ride: '06 IR zhp coupe
Put the bolt in the opposite side (threaded side) and wedge something in for the bolt to push against.
Old 11-24-2013, 08:16 PM   #5
tlester
My Ride: 2001 330i
I found this: http://www.bimmerfest.com/forums/sho...d.php?t=417082
This step stuck out to me:
14 - Rotate the knuckle 90 degrees so you can see the plastic tab - ensure that it is slotted correctly in the knuckle. Rotate back 90 degrees so you can see into the bolt-hole. Slide the knuckle down so that you can see the hole is aligned properly. I'm not sure why, but I was only able to push the knuckle back down onto the steering box shaft when the whole assembly was rotated back to it's original position. Go figure. Reinstall the bottom bolt - 22NM.
Old 11-24-2013, 08:18 PM   #6
Encryption76
My Ride: 2000 328i
Send a message via MSN to Encryption76
I have been procrastinating on this job. Have a new one to go into my ride so good info here.
Encryption76 is offline   Reply With Quote
Old 11-24-2013, 08:54 PM   #7
mjpgolf1
My Ride: 00 328i,05 745,03 X5
I almost tried installing mine with the car on the ground then at the last minute I decided to throw it on a lift. I'm so glad I did because you have to really get some good leverage on it to get it into place. Just keep trying OP and you will get it. Try some different positions until you can get a good hold on it.
mjpgolf1 is offline   Reply With Quote
Old 11-25-2013, 08:30 AM   #8
tlester
My Ride: 2001 330i
OMGosh! What a pain. I still don't have it in. I couldn't get the rack side in, so I took it off tried to spread the gap a bit more and still no go. So, I tried to start with the rack side first. I finally got the rack side in, and got the steering column side started, but now I can't get the column side in far enough to get to the groove where the bolt can pass through and thread on the other side.
It's always the jobs that seem the easiest that end up screwing you over. Any advice is appreciated.
-Tom
Old 11-25-2013, 08:38 AM   #9
WDE46
My Ride: '13 128i, '04 330Ci
I had to turn my coupler by one spline when compared to the spline the original one was on. It ended up giving me a bad steering angle, but I fixed that with a toe alignment.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 11-25-2013, 08:47 AM   #10
tlester
My Ride: 2001 330i
The problem now is... If I give up, I can't really drive it to the shop. I'm to that point where I'm so pissed off that I'd gladly pay my mechanic to get it on... but I can just see me driving down the road when my steering column decides to free itself and my drive into a wall or something.
Old 11-25-2013, 09:16 AM   #11
Zell
Zell's Avatar
My Ride: so turbo wow
Mine went on really easily. It was coming off that was the hard part. It should just very easily slide on after you clean up the splines.
Old 11-25-2013, 09:20 AM   #12
WDE46
Do not drive it to the shop. Unlock your steering column and do it that way. You'll just have to get a toe alignment. No big deal.
Old 11-25-2013, 09:30 AM   #13
Mctwist77
My Ride: '99' BMW 323i
Hammer it on...or if you can get it off sand down the part where it goes on, just enough to give you the space to get it on. You gotta get pissed
Sent from my DROID2 using Bimmer App
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
Old 11-25-2013, 09:47 AM   #14
paraklas
My Ride: ESS TS2 320ci
Same, and it even was on a RHD. I don't know about the LHD version, but mine was impossible to install wrong, not even by a spline
Old 11-25-2013, 09:49 AM   #15
tlester
My Ride: 2001 330i
If there was enough room for a hammer, I would!
Old 11-25-2013, 09:52 AM   #16
Zell
Zell's Avatar
OP are you sure some splines aren't damaged? Inspect them really well. When you hammer out the guibo with a long screw driver I can see that being a possibility. Slim, but it's certainly possible.
Old 11-25-2013, 09:54 AM   #17
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
You can do it man. Take a breather, come back to it and finish it off.
Old 11-25-2013, 09:58 AM   #18
WDE46
I think mine was installed one spline off at the factory. When I put it back on one spline over, it slid on easily. The little tab that it fits around was slightly warped, so I think that's what happened.
Old 11-25-2013, 10:11 AM   #19
tlester
My Ride: 2001 330i
The splines are ok, because right now, I have it on the splines. I first tried it like everyone else does it. I.e. put the column side on first, then push the coupler up over the splines and down onto the rack. But, when I did that, I could never get it past the first set of splines. Almost... I could get the holes to line up about half way, but not all the way.
So, I tried putting the spline side on first. I got it on and bolted in. Now, the column side is in, but not all the way in, so I can't pass the bolt through. And there's nothing to grab the column with to pull it into the coupler.
So... I guess I'm going to try it the first way again and see if I can get it down. Unless I hear any other good suggestions.
Old 11-25-2013, 10:14 AM   #20
WDE46
Are you even listening to what I'm saying? Unlock the column. Put the coupler on the column (no bolt), then put it on the rack.
330, coupler, e46, steering
