Old 01-04-2015, 03:30 PM   #1
gewais
My Ride: 2003 BMW 325i
Coolant Leak, Drain Plug?? Radiator?? please help
Hello everyone,
I need help figuring out a problem i have in my car.I noticed a coolant leak by the radiator drain plug(screw). Now after checking the car multiple of times, i found out that when the car is cold and parked and not used for hours or days or weeks, there is no leak. when i warm up the car for a while i don't notice any leaks, once i drive around i start to notice drops of coolant. Today, i cleaned the radiator, expansion tank, hoses and every place around the leak area so i can test the car and see where the leak is coming from. Drove it a little, kept the engine running, pulled the car up and i saw the leak. It drops one drop a minute or so. I cant tell if its from the radiator drain plug or not but its from the bottom corner of the radiator. Definitely not from the top or expansion tank or hoses or anywhere else Its from the bottom. sometimes i see a drop on the drain plug and sometimes like today i saw it dripping from bottom of radiator and a little wet around the drain plug screw but i am not sure if its old or not. Now one more thing, if i push on the drain plug with my hand it starts to leak a lot and once i take my hand off it stops. so not sure if the drain plug is the problem. i dont know if it cause an inside leak or something and it comes out from the bottom of the radiator. I did order a new drain plug and waiting for it. Is there a specific way to install that? any ideas or anybody has same issue? The car doesnt overheat or lose a lot of coolant. Maybe if i drive it for a month it might get low.
please check the images in attachments
 photo 17111437360-1_zps8d54254b.jpg_a1_
ID:	585769   Click image for larger version
ID:	585770   Click image for larger version
ID:	585771   Click image for larger version
gewais is offline   Reply With Quote
Old 07-09-2016, 06:25 PM   #2
EssArr
My Ride: 330ci
Having the same problem -- coolant dripping just from the drain plug area
Were you able to figure this out? How did you fix it?
EssArr is offline   Reply With Quote
Old 07-10-2016, 09:54 AM   #3
Travis424
My Ride: 2004 BMW 325Ci
Have you done a cooling system refresh yet. Could be from anywhere. My radiator was leaking and it looked like it was coming from the drain plug. Check lower radiator hoses. Underneath the expansion tank. All the common areas it could be leaking from. And like I said if the car hasn't had a cooling system refresh done now might be the time. Better safe then sorry IMO.
________________________________
Travis424
2004 325ci
Travis424 is offline   Reply With Quote
Old 07-10-2016, 09:59 PM   #4
KawiNinjaZX
My Ride: 2000 323i Gold 5spd
Mine did the same thing, drain plug didn't fix it, I put in a new behr radiator $120 and it has a traditional drain plug instead of the bmw one.
KawiNinjaZX is offline   Reply With Quote
Old 07-10-2016, 10:03 PM   #5
EssArr
My Ride: 330ci
What happened when you replaced the drain plug?
Old 07-10-2016, 11:10 PM   #6
Travis424
The drain plug is at the bottom of the cooling system. Any coolant leak eventually will make its way to the bottom Your leak could be anywhere and I'm sorry to tell you but its probably not the drain plug. Try it and see if it works. Just be careful replacing it because it is only plastic and very fragile. Do not use pliers or wrenches to tighten it in. It should twist in by hand. If you over tighten it it will break and then you will have a bad leak. They don't tend to develop spontaneous leaks so if the drain plug hasn't been touched I doubt that is your problem. Unfortunately your symptoms seem to point to a leaking radiator considering you didn't notice any leaking elsewhere in the system. OEM radiators have a lot of plastic parts on them that can expand and crack over time. If you can get a good look at your radiator (ie: removing fan) Check along the edges where the radiator meets the plastic. You might see some white or black staining or residue. Also check for any bowing of the radiator. also remember that short of removing the radiator you will only be able to see one side. If you see any of this that's probably where the leak is coming from. Granted I am not a mechanic so these are only suggestions based on my experience. If you really want to find out where the leak is coming from you should bring it to an indie shop. If you have to replace the radiator go for either OEM or Behr. I replaced mine with a Behr for roughly $120. I also noticed from your pictures that the coolant appears to be adjacent to drain plug and not on the actual plug. Another indicator that its probably not your plug.
Old 07-11-2016, 03:43 AM   #7
e4six03
I had a leak on the drain plug, replaced the o-ring on it and it stop leaking.
e4six03 is offline   Reply With Quote
Old 07-13-2016, 10:54 PM   #8
EssArr
My Ride: 330ci
Thanks very much for the informative reply, very useful info!
For my leak, I spent time under the car looking right at the drain plug with a very bright light and saw the leak slowly forming right at the connection of where the plastic hex plug meets the radiator. I'm 100% certain that the leak wasn't anywhere else..
Although I agree with you that the radiator itself is probably on its way out maybe
Old 07-13-2016, 11:13 PM   #9
Travis424
Good luck hopefully the drain plug fixes the problem. If the radiator looks like its on its way out I would replace as soon as you can however. You really don't want to overheat your car. Doesn't take long to cause some serious damage. Go easy on the install. The plugs are cheaply made. Also if you use the drain plug I recommend using a coin to tighten the blue plug. Its very easy to strip or break using a screwdriver.
325i, coolant, e46, leak, radiator adjustment screw
