Old 05-14-2015, 08:22 PM   #1
xulili
Past Site Sponsor
My Ride: bmw 520i
V2.11 KTAG K-TAG ECU Programming Tool Master Version with Unlimited Token
V2.11 KTAG K-TAG ECU Programming Tool Master Version with Unlimited Token Hardware V6.070+ECM TITANIUM V1.61
K-TAG ECU Programming Tool is designed entirely around the needs of our customers to be more responsive and reliable. A true champion of innovation, K-TAG introduces another brand new novelty to Alientech world: J-Tag communication for Asian car.
Notice:
Please only use the software we provide and do not update you
V2.11 KTAG has unlimited tokens, we have add a renew button, when you run out of tens, only need press the renew button, then you will have tokens again.
Bitte verwenden Sie nur die Software nicht update.
V2.11 KTAG hat unbegrenzte Token, haben wir fügen Sie ein erneuern Taste, wenn Sie aus der Zehn laufen, drücken Sie die Taste zu erneuern, dann wird Token wieder haben.
Compare between new and old KTAG:
KTAG Connection Picture Display
KTAG Description:
The new K-TAG is 100% J-Tag compatible, but in a completely different way. Usually J-Tag programmers are available only for big productions, never present in chiptuning devices. Using only the essential components, Alientech have merged J-Tag, Motorola BDM/Nexus and Bootloader Mitsubishi/Infineon Tricore/ST communication lines into a single product.
K-TAG works in perfect harmony. Learn how to use K-TAG takes almost no time, because all the communication protocols operate along similar principles. Once you have learned to use a protocol, you will naturally use all the others. Alientech knows what it means to work in motion. For this reason the research methods of the protocols and choice of cars are detailed and ordered.
Unlike many ECU programming tools, with K-TAG you have at your disposal only the applications you really need. Once you have the hardware, you can choose which group of protocols to enable and then start working. In this page you can find a complete list of the ECU currently supported by K-TAG.
- See more at: http://www.obd2ii.de/v2-11-ktag-k-ta....YJa8koK5.dpuf
xulili is offline   Reply With Quote
ecm, ecu, ktag, obd2
