Old 12-07-2015, 07:32 AM   #1
E46XITurboJoe
My Ride: 2001 330XIT Turbo
325 to 330 DME conversion
I have been reading in the forums about DME and EWS flashing, which I think will be the route I go for my up and coming tuning of my turbo system.
However in the mean time I have a few questions.
I currently have my 330 running on my old 325 DME, I have not looked at which versions they are but the car is an 01 and the motor and ECU are from an 03 I think.
my first question are we able to flash ECU's at home with the proper tools now?
and if so will it be easier to flash a tuned 330 code over my current 325 ECU to keep the alignment?
or
will it be easier to swap ECUS (does this still require chip swapping?) and is ECU swapping still something that needs to be done at shops?
any links would rock I am down to read as I still need to understand BMW's systems a bit better.
Thank you
E46XITurboJoe is offline   Reply With Quote
Old 12-09-2015, 12:41 AM   #2
TerraPhantm
My Ride: M3 & ZHP
Easier to flash. Takes about 20 minutes with WinKFP
Old 12-09-2015, 07:01 AM   #3
E46XITurboJoe
I just got an looped my K+Dcan cable so I am going to download and look at this program tonight, are the needed 330 files in this forum I am guessing?
Old 12-09-2015, 08:06 AM   #4
JDUTHIE
My Ride: 2003 325xi
there in here, but also should be in with the winKFP, and SSS progman etc.. disks
JDUTHIE is offline   Reply With Quote
Old 12-09-2015, 05:47 PM   #5
E46XITurboJoe
ok ya my cable has the disk so I just need to get my laptop here and start Messing around with it.
Old 01-05-2016, 10:08 PM   #6
limpiabota809
My Ride: 330 XI
Eu2 flash on your current dme
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 01-06-2016, 07:32 AM   #7
E46XITurboJoe
Tune
Thanks I will look into that program as well, I have a few others I want to try as well. does this program flash in a way that won't count towards having your ECU locked out? know anything about getting it/ downloading it?
Old 01-08-2016, 05:33 AM   #8
limpiabota809
My Ride: 330 XI
Do you mean like the flash count? You can disable the writing and it won't count it
dme, dump, ecu
