Old 07-19-2016, 04:18 PM   #1
06.325ci
My Ride: 2006 325ci
Aftermarket Temp Gauge
Hey guys soo with all the coolant problems on e46s and the dummy temp gauges that bmws have, i was wondering how to install an aftermarket precise temperature gauge. Dont wanna play the waiting game untill it overheats, i wanna be able to check coolant temperature easily, And i was wondering if anyone has any tips on where and how? And if its a bad idea and why. Thanks in advance!
06.325ci is offline   Reply With Quote
Old 07-19-2016, 04:33 PM   #2
Hukerfaker
My Ride: My wife.
Yup, that's what I'd like too. I had cars with "real" temp gauges and always thought it was crap car that couldn't keep its temp needle stuck in the middle. How wrong can man get. How about some Bluetooth car/phone interface? I'd settle with that if nothing else.
Sent from my GT-I9300 using Tapatalk
Hukerfaker is offline   Reply With Quote
Old 07-19-2016, 04:40 PM   #3
lathrash
My Ride: 2003 330i
Have you looked into reprogramming the temp gauge to a "safer" buffer?
http://forum.e46fanatics.com/showthread.php?t=1013600
lathrash is offline   Reply With Quote
Old 07-19-2016, 09:18 PM   #4
jmo69
My Ride: 03 325xi 98 328is
I did it on my e36 by tapping into the throttle body coolant hose and sacrificing the sunglass cubby, but IDK how to attempt it on my m54. I suppose you could make an adapter and cut the upper radiator hose for the sender and get an A-pillar gauge pod for the gauge. This is the DIY I wrote for the oil pressure and water temp gauges on my m52. http://www.bimmerforums.com/forum/sh...rce-for-gauges
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 07-19-2016, 09:39 PM   #5
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Use obd fusion's dashboard
BMW-North is offline   Reply With Quote
Old 07-19-2016, 11:02 PM   #6
rellik
My Ride: is too slow...
p3cars.com. ECS Tuning sells them. spendy, but a great gauge.
02' Black Sapphire Metallic Dinan 330i
* Dinan TCAI * Dinan Stage III engine software, Tranny software, Throttle Body and Strut Bar * UUC TSE3 * ///M3 Steering wheel * ///M3 lip spoiler * UUC Slotted Rotors * KONI FSD's * 35% tint * OEM (ULO) clears * 5000k bulbs * NGK Iridiums * Stewart WP * Delmarco's Bluetooth retrofit * LED Angel Eyes * 3K HID Fogs * USA Spec * P3Cars Vent Gauge * Hotchkis Sport Suspension Sway Bars *
rellik is offline   Reply With Quote
Old 07-19-2016, 11:13 PM   #7
Hamsocne
My Ride: 2002 330Ci
I use Torque Pro and an OBDII to Bluetooth. Gives the temp and you can set an audible alarm at the temp you choose. Simple, easy, and inexpensive.
Hamsocne is offline   Reply With Quote
Old 07-19-2016, 11:19 PM   #8
Knight
My Ride: '05 330Ci | '01 325i
Re-coding the existing temp gauge is a straight forward and seamless solution.
If you want a digital readout, look into an UltraGauge.
Knight is offline   Reply With Quote
Old 07-19-2016, 11:57 PM   #9
jfoj
My Ride: 330CiC, M5, X5, E93
UltraGauge FTW.
Priced right, programmable threshold alarms. Triggers alarms with Pending or Hard codes, Can read OBDII codes and clear them. Auto sleep and wake up.
But also consider reprogramming the coolant gauge buffer. The only thing it lacks is an alarm. You could consider Coolant Snitch, but UltraGauge is a small and cost effective option.
Old 07-20-2016, 08:07 AM   #10
edmondhk
My Ride: E46 325ci
UltraGauge FTW.
Can the UltraGauge read the oil temp/transmission temp?
I have reprogram the coolant buffer, it's fine now, but the others....
I don't want to put so many gauge in my car, it just not feel right
edmondhk is offline   Reply With Quote
Old 07-20-2016, 11:16 AM   #11
jfoj
UltraGauge has a special version that supports transmission fluid temperature on SOME vehicles, not not all. I also think that version of the gauge does not support reading and clearing OBDII codes???
So not sure I would bank on trans temperature support. Assume you could look at the UltraGauge Forum or ask Tech Support about BMW trans temp support.
Old 07-20-2016, 12:44 PM   #12
dan4081
My Ride: 2000 323i
This is how I watch my temps.....
dan4081 is offline   Reply With Quote
Old 07-25-2016, 11:13 AM   #13
Hukerfaker
My Ride: My wife.
I wouldn't mind to hear more info on the above setup?
Old 07-25-2016, 12:04 PM   #14
dan4081
My Ride: 2000 323i
I replaced the stereo with an Eonon headunit. The newest Eonons run Android just like a phone so I added a $12 bluetooth obd module (from Amazon) and can watch temp guages, check error codes, and many other things running the torque app.
There are a few threads about the eonon on this forum.
aftermarket, coolant, overheat, temperature gauge
