Old 10-11-2016, 09:45 AM   #1
Webster569
My Ride: 2004 BMW 330i
"Red cog of Death"
Hey everyone.... I have a 2004 330i that has had the red cog light come on and goes into "limp mode" twice in the last 3 days and not sure what could be causing it. Last week I was able to fix an intermittent stalling problem with a new camshaft position sensor and putting in new fuel and air filters, could this somehow be related to my reg cog light problem??
Any thoughts or ideas would be appreciated, thanks
Webster569 is offline   Reply With Quote
Old 10-11-2016, 10:47 AM   #2
das_autobahn
My Ride: 2004 330ci coupe
get the codes from the obd2 port first...
das_autobahn is offline   Reply With Quote
Old 10-11-2016, 12:43 PM   #3
Webster569
The red cog light goes away once the car is turned off and back on, will it store the codes?
Old 10-11-2016, 01:26 PM   #4
Webster569
Read codes there are none
Old 10-11-2016, 05:40 PM   #5
Archbid
My Ride: 2003 330cic
What are you using to read codes?
Archbid is offline   Reply With Quote
Old 10-11-2016, 09:31 PM   #6
Webster569
I'm using a Bosch OBD 1150 code reader
Old 10-12-2016, 01:13 AM   #7
Gannon1226
My Ride: 2003 325i
Sounds crazy but I'm gonna say it . Voltage regulator/alternator. At the very least get them tested. I had stalling then a few days later red cog . Then eventually it went from a monthly thing to a every few day thing. I'm thinking it was getting voltage surges/drops and it was trying to protect itself . Changed my alternatir and all has been well for months now . Eventually I should mention , but it didn't happen at first, I would get an ses. But only for misfires due to loss of voltage I assume and then eventually after that a battery light .
Gannon1226 is offline   Reply With Quote
Old 10-12-2016, 03:00 AM   #8
das_autobahn
check for ac noise from alternator .03vac or more usually will make stuff freak out. at least it does on cummins trucks like mine if they have auto trans
Old 10-13-2016, 11:15 AM   #9
Webster569
How would I go about checking for noise from the alternator?
Old 10-14-2016, 09:07 PM   #10
Webster569
UPDATE: I got the red cog to show up again and got a code off it this time, it read P0721 output shaft speed sensor
330i, red cog
