Old 10-18-2016, 07:25 PM   #1
bluebull107
My Ride: 325ci
[Help] Replaced Coolant Expansion. Still Overheating
I had a leak coming from the coolant expansions which is why I thought that the car was overheating, so I replaced it. Now its still overheating after ive filled it back up. What else could it be? Do I need to bleed the system?
bluebull107 is offline   Reply With Quote
Old 10-18-2016, 07:27 PM   #2
TheMidnightNarwhal
My Ride: Bicycle
Perhaps you have air, if you don't see any coolant leaking...
TheMidnightNarwhal is offline   Reply With Quote
Old 10-18-2016, 07:53 PM   #3
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
Yes:
Originally Posted by Spannerhead View Post
Park in nose-high position.
Remove ET cap and bleed screw.
Engine off.
Turn key to ON.
Set heat to max and turn on blower (halfway or so).
Pour coolant in until it overflows.
Keep pouring until it comes out the bleeder opening
Keep pouring until the coolant is bubble-free (this may take a minute or two).
You will spill a lot of coolant.
Top up ET.
Use turkey baster to remove excess coolant in the ET.
Reinstall bleeder screw and ET cap.
Drive to verify temps are stable and heat comes out of the vents.
Check frequently over the next few days and top off as necessary.
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 10-18-2016, 08:53 PM   #4
bluebull107
My Ride: 325ci
Alright Ill bleed it. Thanks for the quick reply btw. You guys are great!
Old 10-18-2016, 09:08 PM   #5
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Is your electric fan spinning fast when your car is starting to overheat???? Should be at max speed.
BMW-North is offline   Reply With Quote
Old 10-18-2016, 09:15 PM   #6
bluebull107
My Ride: 325ci
Its always at max speed because I have it hardwired into the glovebox.
Old 10-19-2016, 04:38 PM   #7
bluebull107
My Ride: 325ci
bleeding the system worked, thanks guys!
Old 10-19-2016, 10:27 PM   #8
lingon300k
My Ride: 2005 325xi Automatic
Yes:
I feel like we should both take our bleed directions from that thread and make them our signatures. It seems like the most often given piece of advice on this forum is also the most ignored.
lingon300k is offline   Reply With Quote
Old 10-19-2016, 10:28 PM   #9
lingon300k
Glad it worked out okay. Just make sure to monitor the coolant level, and the temp gauge, for the next week.
coolant, expansion, overheating, tank
