Old 11-29-2016, 06:23 PM   #1
paperpilot22
My Ride: 2004 325Ci
325Ci Overheat at idle
Okay I'll present what's become a tricky issue for me. I'm sure you smart folks here can assist. I've looked through the boards here and it's really impressive to see the expertise here.
My coolant expansion tank blew the other day so I replaced it, the lower thermostat, and the water pump (it was noisy anyways). Everything went back together well and I bled the system a few times.
Since doing the repair I notice the temperature will do some strange things. I drive for about 20 minutes and then, when I sit at idle, the car begins to get hot.
The aux fan turns on when the AC is on but I don't see it otherwise. All fuses check good. The coolant level is good. All connections look good. The heater blows hot air (and brings the engine temp down). The AC blows cold.
Maybe the temperature sensor?
Thanks very much for any help you can give. I really appreciate it.
And of course, once I figure this I'll bring up the 0171/0174 issue. Man I can't tie that thing down. What a pain.
paperpilot22 is offline   Reply With Quote
Old 11-29-2016, 07:25 PM   #2
Loaded325i
My Ride: bmw 325i
Why did you put a lower temp thermostat in? Sometimes when people do that sort of stuff the radiator never has time to cool the coolant mixture because the t-stat is always open instead of cycling open and close.
A mechanical hobbyist and car enthusiast
1971 Datsun 240z Devil Z red
1999 740il Titanium Silver
2004 BMW 325i CW,PP and Sports Package
1996 toyota avalon-263,000-Sold
2003 Lexus Is300-Sold
2000 Acura TL-Sold
2000 Accord 5 speed-Sold
Loaded325i is offline   Reply With Quote
Old 11-29-2016, 07:31 PM   #3
paperpilot22
My Ride: 2004 325Ci
I'm probably using the incorrect name. It's the thermostat at the bottom of the expansion tank. It broke as I removed the tank so I had to replace it.
Old 11-30-2016, 08:56 AM   #4
markusmarkus
My Ride: 2001 330Ci
That's the thermostat for the automatic tranny fluid. Your car has 2 fans. The one in front of the radiator cools the AC condenser. The other is attached to the water pump via a thermally activated fluid clutch. That is, when under hood temps get high the clutch fluid will increase in viscosity thus speeding up the fan speed. That clutch is going bad.
Old 11-30-2016, 09:58 AM   #5
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
It sounds like your aux fan is not coming on when it should. Read this and check it.
https://drive.google.com/file/d/0B59...k5SkwxVlE/view
///Mmmmmm...
Old 11-30-2016, 11:23 AM   #6
JFM330i
My Ride: 2002 330i
I would check the fan clutch, as stated above it might be bad. Or the tstat or water pump, if none of these has been replaced recently, it may be time.
2002 330i auto
1999 323i 5 speed
2013 Úlantra 6 speed
2010 rogue AWD
2003 eclipse GTS 5 speed
1995 celica st 5 speed
2007 gsxr 750.....track weapon!
JFM330i is offline   Reply With Quote
Old 11-30-2016, 11:50 AM   #7
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
BaliDawg is referring to the electric aux fan. Sounds like a classic failure via intermittent operation. Prudent to verify the CTS is functional though. Measure the ohm difference Hot vs Cold - should be > 200ohms Directions in the linked guide in BD's post.
BMW-North E46 Electric Fan Guide
Download a clean working copy of BMW Standard Tools with Special Tests for e46 :
Single NRG file: Complete BMW Standard Tools Suite You will also need ISO Workshop (free edition - linked) to create the install directory (image) or disk. NRG file: 347,183 Kb
BMW-North is offline   Reply With Quote
Old 12-04-2016, 05:18 PM   #8
paperpilot22
My Ride: 2004 325Ci
I replaced the fan clutch and it seems to be doing very well. I had no idea how bad the old one sounded till I heard this new. it's just smoother.
But, of course, the same problem occurred. I went out driving for a while and the temp held, then the stop and go traffic took its toll and it got real hot, real quick. I have everything taken apart and don't see any obvious issue. I'm guessing perhaps the electric fan. In reading the document, which gives great information, I'm still not sure what part may be failing. The aux fan runs fine but must not be getting to full speed. What would that indicate? Otherwise, I've pretty much replaced everything else possible (I replaced the CTS a year ago).
Any thoughts?
Old 12-04-2016, 07:22 PM   #9
BMW-North
As Balidawg pointed out earlier, it is likely your electric fan and not the clutch fan that is the root of the overheating.
The electric fan module often fails on speed ratios and may work at certain times. The DME uses algebraic formulas with multiple inputs to calculate the output speed. This data is sent to the fan module as a PWM signal.
I think sometimes the fan module just doesn't put out the right power or misinterprets DME command signal. Often corrosion on terminals can cause this. You need to replace your electric fan assembly or minimally the Bosch fan module mounted on the shroud.
Last edited by BMW-North; 12-04-2016 at 07:25 PM. Reason: I typed PWM. Apple prefers Pam.
Old 12-04-2016, 07:57 PM   #10
paperpilot22
My Ride: 2004 325Ci
I think you're absolutely correct. And I definitely appreciate the input. I'll check out the fan and see if it's a connection issue or the whole fan. Either way I'm anxious to get it settled.
Thanks very much!
Old 12-09-2016, 07:11 PM   #11
paperpilot22
My Ride: 2004 325Ci
Electric fan
I replaced the electric fan and it isn't coming on at all...even with the AC on at idle. It should come on then, correct?
Should I take it for a drive to fully warm it up or is it showing me that it's not working already?
Gotta be honest, I'm running to of ideas on this. One fix creates another problem it seems. Any input is very appreciated.
Old 12-09-2016, 08:48 PM   #12
jmo69
My Ride: 03 325xi 98 328is
I know you replaced the pump but it sounds like you don't have enough flow at idle. Either a restriction or bad pump. T-stat still good?
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 12-09-2016, 08:54 PM   #13
paperpilot22
My Ride: 2004 325Ci
I think it's good. i replaced it about a year ago. I'm not sure about a restriction.
One thing I did notice, if it helps, is when it was getting real hot a few days ago, the hose from the thermostat to the expansion tank was very firm. I know it's got some pressure to it but I couldn't even squeeze it hardly.
Is that normal or could that show a restriction somewhere? Also, what about the fan never turning on? Is there a mistake I could have made installing it?
Old 12-09-2016, 10:16 PM   #14
BMW-North
Did you check the lower rad hose coolant temp sensor as stated earlier. If you disconnect it ( the cts) then start car, then turn on ac the fan should fire up. It maybe putting out false values which mess with DME output calc.
Old 12-09-2016, 10:17 PM   #15
BMW-North
Reading this sounds like your tstat is closed shut or the water pump isn't working. Either way sounds like a coolant circulation issue.
Edit: if the coolant isn't circulating the the coolant at the CTS will not be hot enough to send a reading to DME that would command the fan be turned on. I think a thorough diagnosis of the cooling components is warranted.
Old 12-10-2016, 09:56 AM   #16
jmo69
I was going to suggest the t-stat, but I would think it would run hot under all conditions, like air in the system. A friends e34 had a bad stat and using the heater was the only way to keep it cool, that was on an m20.
Hers His
Old 12-10-2016, 10:52 AM   #17
paperpilot22
My Ride: 2004 325Ci
It's a shame this all started from that stupid expansion tank cracking.
I tried disconnecting the CTS and having the ac on but the fan doesn't move. The only way to get the fan spinning is to unplug its connector and reconnect it. The fan will spin up to speed then wind down. I may have to admit defeat and take it to a pro for a good look over. I think all your advice is spot on. There must be something strange happening that I'm overlooking.
Old 12-10-2016, 12:13 PM   #18
jmo69
The clutch fan should be enough to keep the car from overheating at idle, I think you have a flow problem.
Hers His
Old 12-10-2016, 12:20 PM   #19
BMW-North
Inpa fan test or a known good fan module from another's car to test. See my video on YouTube testing a different fan Assy without uninstalling the old one on an automatic.
Old 12-11-2016, 11:05 PM   #20
paperpilot22
My Ride: 2004 325Ci
Changed out the thermostat and it seems to have done the trick. I drove the car all over for an hour and the temp is rock solid. I appreciate the inputs. You were all correct, as usual. I'm still unsure why the aux fan never turns on, but for now the car can drive so I'm glad.
Now on to the 171 and 174 codes....haha
aux fan, coolant, overheat, temperature sensor
