Old 01-02-2017, 06:51 PM   #21
brea
My Ride: 00 328Ci & 98 528i
ZF 5HP19 dumping fluid from bellhousing after install
Bolts right here at the rear of the trans
IIRC, you might have to loosen the valve body bolts and let it drop down a bit. But definitely don't have to remove it all the way.
'00 328Ci - M54B30 Manifold - EU2 - Rogue Engineering UDP's - Catless headers - OE M3 Engine/Trans Mounts - UUC Stainless Brake & Clutch Lines - ST Coilovers - SPC Adjustable Rear LCAs - Mason Engineering Rear Subframe Support - Burger Motorsports 12mm Spacers - 5spd "ZHP" Shift Knob
brea is offline   Reply With Quote
330i, leak at bellhousing, zf5hp19
