Leak from above oil pan - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-13-2016, 11:29 AM   #1
06.325ci
My Ride: 2006 325ci
Soo yesterday i got home late andi saw a baby puddle from the center of my car and it didnt look like oil and didnt really smell like coolant soo i took a video hoping you guys can enlighten me on the situation , it may of happened once before but im not sure. It is directly above the trans oil pan. Looks just like plain water? Any answers wil be appreciated! Thanks in advance !
Will upload video in abiut 2 or threee hours ***128077;***127995;
06.325ci is offline   Reply With Quote
Old 12-13-2016, 01:24 PM   #2
06.325ci
My Ride: 2006 325ci
Old 12-13-2016, 01:26 PM   #3
06.325ci
My Ride: 2006 325ci
And can anyone tell me what that cracking type noise is ? I think its comming from exhaust but only after really long drive?
Old 12-13-2016, 01:52 PM   #4
Bigc2016
My Ride: 328i
Looks like coolant leaking and am new to E46's so I dont know what could be above your oil pan but it could be a heater hose in that location. Also after a long drive and you hear cracking noise coming from the exhaust most likely that is going to be your catalytic converter cooling down.
Bigc2016 is offline   Reply With Quote
Old 12-13-2016, 02:27 PM   #5
das_autobahn
My Ride: 2004 330ci coupe
thermal expansion/contraction of metal. normal.
das_autobahn is online now   Reply With Quote
Old 12-14-2016, 02:27 AM   #6
BiH55
My Ride: 2001 bmw 325i
Does look like plain water
BiH55 is offline   Reply With Quote
Old 12-14-2016, 07:29 AM   #7
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
It looks like water from the AC drain tube. Were you running the AC? See this post.
http://www.bimmerfest.com/forums/sho...58&postcount=8
///Mmmmmm...
Old 12-14-2016, 03:24 PM   #8
Yewzer B Lewzer
My Ride: 2003 325i
This
Sent from my SM-G930V using E46Fanatics mobile app
Yewzer B Lewzer is offline   Reply With Quote
Old 12-14-2016, 04:07 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
Originally Posted by das_autobahn View Post
thermal expansion/contraction of metal. Normal.
+1.
Old 12-14-2016, 04:09 PM   #10
jdstrickland
Condensate from the AC. You are driving with the defrost on, or just the AC, and that's water that drips off of the evaporator coil.
Old 12-14-2016, 04:31 PM   #11
Dave1027
My Ride: '06 IR zhp coupe
Ah, the elusive AC drain tube. OP, at least you know your's is not clogged. I'll bet your AC/defrost smells fine too?
Old 12-15-2016, 10:44 AM   #12
06.325ci
My Ride: 2006 325ci
Yes i do drive usually with ac on and do use defrost in front and year in the mornings. Sooo question . Is this anything to worry about ?
Old 12-15-2016, 02:13 PM   #13
jdstrickland
No, it is nothing to worry about.
When you take a beer from the fridge and put it the patio table, water droplets form on the can and drip down the sides. This is what you are observing from your car.
It might be worth the effort to actually look for the tube that the water is coming out of and make sure it is directed away from stuff that cars about water dripping on it constantly. On my X5, I had to redirect this drain tube because the water coming out of it was making something else have a hissy fit. The draining water is not a problem, but where the draining water drains to might be worthy of consideration.
For the record, the rear window is heated by an electric coil that is built into the glass, the water dripping out the bottom of the car is not related to this in any way.
coolant, leak, oil, trans oil pan
