Old 12-22-2016, 07:33 PM   #21
Filipg92
My Ride: 2001 BMW 325ci
Originally Posted by BMW-North View Post
Pa soft does a pretty good job at interrogating ABS/DSC systems. It just isn't so good as INPA for repairing them. Full version of BMW Standard Tools including INPA in my sig. with the steering wheel sensor calibration routine for E46 abs/dsc swap. Xemodex does a great job at a fair price of abs/dsc repair via courier.
You need to get all codes read first tho to know what's up?
So these are all BMW specific scan tools? Will try to get one of them and see whats going on, not a HUGE deal just annoying and I've been driving this car for a month already (At this point I'm pretty much used to driving with no speedo, my e36's didnt work either, but that was a much easier fix)
Thanks for the links will try them out when I get home
Filipg92 is offline   Reply With Quote
Old 12-22-2016, 07:58 PM   #22
AlexC28
My Ride: 323i 2000
Originally Posted by Filipg92 View Post
I went through the fuses in the glove box and they all were good. Are there any other fuse boxes? I've heard of there being one in the trunk but didn't find anything.
that is all the fuses in the car the rest are relays hidden under glovebox and engine, but there isn't one for speedometer
AlexC28 is offline   Reply With Quote
Old 01-01-2017, 12:24 AM   #23
StichickP
My Ride: 328I
Same Problem - No speedometer
1999 328i, 5 standard transmission / 5 speed with M-54 eng.
110 K miles
Speedometer quit. No MPG / Avg MPG.
RPM and other gauges are functioning normally.
No instrument cluster warning lights illuminating.
DSC functions
Fuses are good
Car runs good otherwise.
Could it be an ABS sensor or vehicle sensor on transmission ?
Open to suggestions.
StichickP is offline   Reply With Quote
Old 01-01-2017, 02:03 AM   #24
scottjoh
My Ride: '99 323i & '02 540i
Is the coolant temp all the way in the red too? If so then it sounds the no CAN bus communication.
scottjoh is online now   Reply With Quote
Old 01-01-2017, 01:20 PM   #25
StichickP
My Ride: 328I
Temp gauge operates normally. All other gauges seem to function normally except odometer, and those computerized readouts that require a speed input like the MPG.
Seems like a speed sensor, but which one ?
Do all four wheels have speed sensors ?
Is there a speed sensor on the standard transmission ?
Old 01-01-2017, 01:24 PM   #26
scottjoh
Speedometer not working (NO warning lights on dash) Cluster issue?
If one of the wheel speed sensors were bad you would get a DSC light on the cluster letting you know there is a problem. So replacing the sensor won't do anything. The DSC module takes the 4 wheel speed sensors, but only the rear left sensor is signal conditioned and sent to the cluster. It is that signal that may be bad. Usually because of a bad DSC module. You can check on the back of the cluster X11175 pin 19.
Old 01-01-2017, 01:38 PM   #27
StichickP
My Ride: 328I
Thanx
No DSC light illuminated. Other cluster gauges seem to be functioning normally.
I'll start by checking sensor cables and connections, then will change the left rear sensor attempting the cheapest possible item in the process of elimination.
Hopefully it will solve the problem. If not, perhaps a new DSC is in order.
Thank you scottjoh
Last edited by StichickP; 01-01-2017 at 01:47 PM. Reason: Obmited portion of comment
Old 01-01-2017, 01:51 PM   #28
StichickP
My Ride: 328I
Speedometer inop
Thanx
Thank you scottjoh
Old 01-01-2017, 08:35 PM   #29
scottjoh
The sensor is fine if you don't get a DSC (or ASC) light.
Like I said before the DSC (or ASC) module takes all the wheel speed sensors, but, only the rear left one gets signal conditioned and sent off to the instrument cluster. Search for signal name F_DFAHL in the WDS. It comes from DSC module connector X18303 pin 10 (I don't know where comes out of the ASC) and goes to the cluster black connector X11175 pin 19. If you have factory equipped navigation it goes to the GPS module also and is used for dead reckoning.
Old 01-02-2017, 01:48 PM   #30
StichickP
My Ride: 328I
Scottjoh, I've noticed that as I drive the car and the fuel gauge moved down with fuel consumption toward the 1/4 hash mark, the gauge slowly oscillates up to 1/4, and down to near "E" then again moves up... It seems to continue moving very slowly up and down. The reserve light occasionally blinks. This is a newly noticed symptom. As I said, the vehicle is an early 1999, and is equipped with ASC not DSC. I'll let you know how the speed sensor change affects the situation. I do appreciate your guidance.
Old 01-02-2017, 03:48 PM   #31
scottjoh
Likely a bad fuel level sensor.
Like I said before changing the sensor won't do anything!
For fun I disconnected pin 19 from the back of my cluster and drove around. As I expected no speedo and no mpg.
bc, bmw, cluster, e46, speedometer
