Old 01-06-2017, 08:57 PM   #1
JohnnySinsm8
My Ride: e46 325i
02 325i sputters and die first crank; Always starts on second start.
Hey guys
My e46 is currently experiencing this problem just recently whereas upon cold starting the car - car been sitting for a while - it always initially turns over to about 600rpm instead of the usual 1000rpm before promptly dying. Upon second turn over it always starts and idles perfectly fine.
This leads me to think its a fuel pressure issue possibly caused by a bad pressure regulator, leaky injectors or fuel pump.
I must note that after driving the car hard a slight groaning or whirring sound is heard from what I assume to be the Fuel filter/pressure regulator though im not quite sure. This sound does go away after driving the car normally for a bit.
I have scanned the car for codes and its not showing any error codes at all.
Thanks guys
Should also note that i have done my vanos seals and ICV/TB cleaning recently before any of these symptoms appeared. I am yet to replace my lower intake boot - though it seemed fine when i took it off - and yet to replace the fuel pump or filter.
JohnnySinsm8 is offline   Reply With Quote
Old 01-06-2017, 09:43 PM   #2
dck8267
My Ride: 2003 325ci M56
Same thing is happening to my 03 325ci except its random in that it happens like every 5th time starting either cold or hot. Has new fuel pump but im also getting cylinder 3 misfire code, but code is always just "pending" and never throws ses light..im stumped as to whats up
Sent from my SAMSUNG-SM-G930A using E46Fanatics mobile app
dck8267 is offline   Reply With Quote
Old 01-07-2017, 08:05 AM   #3
JohnnySinsm8
My Ride: e46 325i
Did u also replace the fuel filter ? I'm thinking it's a bad pressure regulator still distributing fuel to the injectors causing s too rich condition.
Old 01-12-2017, 04:10 PM   #4
dck8267
I have an m56, so the dealer replaced entire tank assembly under warranty
Old 01-12-2017, 04:49 PM   #5
jfoj
My Ride: 330CiC, M5, X5, E93
Originally Posted by JohnnySinsm8 View Post
Hey guys
Thanks guys
Suggest you read this thread - http://forum.e46fanatics.com/showthread.php?t=929501
A moaning FPR, fuel filter or fuel line is usually a soft failing fuel pump. Every E46 really needs a fuel pump by now!
Old 01-12-2017, 05:10 PM   #6
kd7iwp
My Ride: 2001 325i
I'll vote for leaking fuel injectors. My E30 was similar and this was my problem.
kd7iwp is offline   Reply With Quote
325i, e46, fuel, pressure, start
