Thread Tools Search this Thread Rating: Thread Rating: 74 votes, 4.82 average. Display Modes
Old 10-25-2016, 03:30 PM   #921
E46loverr
My Ride: Bmw 330ci
Nvm I drove it around a bit and it cleared up
E46loverr is offline   Reply With Quote
Old 10-26-2016, 07:02 PM   #922
lingon300k
My Ride: 2005 325xi Automatic
Originally Posted by Solidjake View Post
Not sure why you had to cut wires. The wire harness from the aux fan goes straight into the electric fan.
Sorry to resurrect an older thread, but I'm putting a parts list together and need expert advice.
Is there a consensus on which fan is better--Behr vs Cool Xpert?
Am I correct in my understanding of this that all I have to do is remove the auxiliary fan and replace it with the new electrical fan? No other parts are needed?
(I apologize if these are stupid questions that have already been answered.)
lingon300k is offline   Reply With Quote
Old 10-26-2016, 07:23 PM   #923
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
I forgot which member it was, but he said the front aux fan can be converted to an electric fan. All you need is the shroud if I'm not mistaken. That will save you money and it works the same.
If you want to buy a fan you can't go wrong with Bosch or Behr. The Cool Xpert I have not looked into.
The mechanic and auxiliary fans are removed and the electric fan goes onto the radiator right in front of where the mechanical fan would be.
Old 10-26-2016, 07:52 PM   #924
orb
orb's Avatar
My Ride: 325Ci
In fact I would get the Bosch motor/module from a Mazda3 and put it on the E46 shroud. BMW-North discusses this somewhere.
For what it's worth my Coolxpert unit may have been acting up last night. It seemed to be stuck on the highest setting. Restarted the car and then back to normal. Don't know if it's in the fan or it's the lower hose fan switch, which honestly I have not replaced. Fortunately the fan is still under warranty, but that being said I'd go the Bosch route if I need to use the warranty.
orb is online now   Reply With Quote
Old 10-27-2016, 12:00 AM   #925
lingon300k
I went with the Cool Xpert fan because it was slightly cheaper. I'll make sure to take some pictures and post them here once I receive it. Bosch wasn't an option at FCP, and the Behr was listed as made in China, so I guess there's a chance the Cool Xpert is better? (I'm sure they're the same. Either way, lifetime warranty.)
Old 10-27-2016, 06:02 AM   #926
Solidjake
Zero. Leaks.
Solidjake's Avatar
Let us know how it goes. You'll love how much easier it will be to work on the engine.
Old 10-27-2016, 08:12 AM   #927
Sansho
My Ride: 2001 325i
Shameless plug ... I have a new, unused, still in shipping carton, Behr fan, if interested ... PM me.
Sansho is offline   Reply With Quote
Old 10-27-2016, 11:30 AM   #928
Solidjake
Zero. Leaks.
Solidjake's Avatar
Prices, links, procedure info, part numbers updated
Old 10-27-2016, 04:43 PM   #929
evanr614
My Ride: 2000 328Ci
if i recall correctly they're both made in China. i went with Behr and i feel pretty confident about it...i price matched it with someone for about 200 flat
evanr614 is offline   Reply With Quote
Old 10-28-2016, 08:05 AM   #930
Solidjake
Zero. Leaks.
Solidjake's Avatar
I was going to say it's not related. Just keep an eye on how the car drives.
Old 10-28-2016, 01:23 PM   #931
BMOne
My Ride: 325CI 03
Anyone know where i can get a bosch in Australia at a responsible price?
BMOne is offline   Reply With Quote
Old 11-02-2016, 07:33 PM   #932
lingon300k
Some pics of the Cool Xpert fan:
http://forum.e46fanatics.com/showthr...804&highlight=
Old 12-05-2016, 03:17 PM   #933
BMOne
My Ride: 325CI 03
Behr china vs coolexpert?
Old 01-16-2017, 09:37 AM   #934
Mbryant616
My Ride: 2004 325Ci Vert
Disregard - I decided to buy a new Behr fan and sell my old aux fan
Mbryant616 is online now   Reply With Quote
Old 01-16-2017, 05:37 PM   #935
Pangeek
My Ride: 2002 e46 330i
Front pusher fan = rear puller fan
Hey so just to contribute to this awesome community and to thank all the members here, I will confirm that the front aux push fan is the same part # as the rear puller fan when they are off the shroud.
Long story but basically my wife's car blew an expansion tank due to the pull fan being intermittent and coolant temp rose a little bit which broke the expansion tank. I did have a spare expansion tank (OE Behr but no spare fan). It was a weekend and I didn't have anyWhere to get parts. I've read the blog mentioned earlier and checked the fans. Low and behold, besides the shroud and the length of the wires, the fan motor, blades and capacitor/resistor box are identical (with identical Part numbers). So I switched the push fan to the back puller fan shroud and issue is solved.
Cheers
John
Pangeek is offline   Reply With Quote
Old 01-17-2017, 07:47 AM   #936
BMOne
My Ride: 325CI 03
I'm a bit confused on autos do we have 2 fans in total the mechanical and another that sits in front on the radiator?
I want to buy a behr electric fan. So do i just need to install that by removing the mechanical? And using the mechanical fan shroud?
Old 01-17-2017, 11:39 AM   #937
WOLFN8TR
WOLFN8TR's Avatar
My Ride: 05 SMG M3
DIY: Aux/mechanical fan to electric fan swap
Yes the Auto's have two fans.
Aux Fan- Behind the front bumper in front of the radiator.
Mechanical Fan- In the engine compartment behind the radiator.
Remove both fans and install the Behr Electric Fan that has its own shroud.
(The 6MT has one fan, the electric fan inside the engine compartment.)
Build Thread | S54 Vanos Thread
-TTFS Engine/SMG Tune- SGT Headers/Sect 1/SCZA- Evolve Eventuri- Sprint Booster V2-
-UltraGauge- Orion V4's- CF Lip/Console/Diffuser- VIS XTS CF Hood- LED Fogs- Valentine One- Turner 15F/12R Spacers-
WOLFN8TR is offline   Reply With Quote
aux, auxiliary, behr, bosch, bumper, clutch, damage, electric, engine, explode, fan, hood, manual, mechanical, mount, mounts, removal, swap
