Thread Tools Search this Thread Rating: Thread Rating: 419 votes, 4.68 average.
Old 01-05-2017, 12:54 PM   #3361
Mr.Wilson
My Ride: 04 e46 325i
how many sensors are attached to the cooling system? temp sensor and level sensor? so coolant light issues troubleshooting meanwhile temp sensor overheating behind my back?? not possible if the temp sensor reads anything?? as mine does sit at normal operating range but now new continuous light. just dont want her tellin lies to me while im tryna pick up the kids lol also heard that expansion tank issues cause light as well just in what manner? mounting? sensory? or just plain old clogged up?? help me Mango!!
Mr.Wilson is offline   Reply With Quote
Old 01-05-2017, 01:53 PM   #3362
jmo69
My Ride: 03 325xi 98 328is
The level sensor just lets you know if the coolant level is to low, just like the sensor in the washer tank. There are two temperature sensors, one in the head and one in the lower radiator hose. If the tank sender says it's low you need to check the level and if it's low find out where the leak is. Obviously if it's too low the temp can rise and possibly overheat.
Hers His
2003 325xi StahlGrau metalic almost modless, just lots of new parts, wife's DD. 1998 328is lowered, X-brace, Sparco strut brace, HIDs, AEs, almost everything blacked out, my DD.
jmo69 is offline   Reply With Quote
Old 01-05-2017, 01:56 PM   #3363
My Ride: Lexus
I do not recommend "troubleshooting" the cooling system. If your light is on, it means you have low coolant. If you have low coolant, the most common cause by far is the expansion tank leaking. A system overheat isn't too far behind if you don't add coolant, assuming air was not and is not being introduced into the system. I recommend replacement of the entire cooling system. See my blog here: http://www.e46mango.com/2014/10/hi-t...6fanatics.html
Old 01-05-2017, 05:09 PM   #3364
ChuckyVee
My Ride: 2000 323i, '99 328is
Originally Posted by zapsix View Post
Yes! That's a good idea. Where can I purchase these items? (Coolant pipes. Hoses. Crank case vent valve, ccv, vacuum lines, starter?)
2004330iZHP
Not sure if you're tolling or not? In case you're not...punch in the last 7 digits of your VIN on realoem.com. Get the part numbers you need and use any online vendor you like. Also, if you're thinking about working on the car yourself, there are TONS of DIYs and posts on here for just about any problem you may encounter.
Good luck!
First Bimmer..."Miss December"...2000 323i, purchased Dec. 2013 w/82K on the clock. PM thus far...pads/rotors, belts/pulleys, complete CS overhaul, FCABs, plugs, autotranny/differential service, fuel pump, filter, and relay. Full front end refresh with LCAs and bushings, struts and mounts, inner/outer tie rods, sway bar endlinks and bushings.
ChuckyVee is offline   Reply With Quote
Old 01-06-2017, 08:53 AM   #3365
zapsix
My Ride: 2004 BMW 330i ZHP
My coolant lights comes on when I go fast. But it only comes on once I slow down after hitting speed like 90. It's weird. I checked the coolant level and its right on the full mark.
2004330iZHP
zapsix is offline   Reply With Quote
Old 01-06-2017, 10:15 AM   #3366
El conquistador
My Ride: 2004 325xi
Then, don't go fast
El conquistador is offline   Reply With Quote
Old 01-06-2017, 10:20 AM   #3367
zapsix
Lol
2004330iZHP
Old 01-06-2017, 01:38 PM   #3368
DEADF15H
My Ride: 2001 325i Auto
Did you try bleeding it correctly?
When was the system refurbished?
Sent from my SAMSUNG-SM-N910A using E46Fanatics mobile app
DEADF15H is offline   Reply With Quote
Old 01-06-2017, 08:58 PM   #3369
Mbryant616
My Ride: 2004 325Ci Vert
Running Cold?
Hey all: Have been studying this thread (and many others), I am 5 weeks into ownership of my sweet baby, 2004 325 vert. Driving it in "mostly" cold weather so far, I've noticed it runs on the cold side of the gauge. I plan to do a full cooling system refresh once its not so flippin cold out. On warmer days it will run with the gauge straight-up 12 oclock, but on cold days like today, it will stay at or near the blue. If idling (parked), it will rise closer to 12 noon,but when at speed (30-70 mph) it cools off to touching the blue area. I had a brief low coolant light on the first cold day I owned her, at startup, and I topped off the ET with the BMW coolant/distilled water 50/50 mix, and she's been perfect since. Just wondering, with the cold air temp, is this normal or is it a sign of a soft t-stat fail?
Mbryant616 is offline   Reply With Quote
Old 01-07-2017, 10:36 AM   #3370
Big-K
My Ride: 2004 325i
I would suspect it's a soft thermostat failure. I don't know how cold it is where you live, but it's around low to mid 20s here in Seattle and my temperature gauge doesn't have a problem getting to middle. I would get that replaced sooner rather than later; it's not good to have your engine running below optimal temperature for extended periods of time.
Sent from my KIW-L24 using Tapatalk
Big-K is offline   Reply With Quote
Old 01-07-2017, 10:52 AM   #3371
Mbryant616
Thanks Big-K, yes I've been studying other threads on this subject and I agree. Interestingly, at least for now, I have no other cold-running symptoms (i.e. starting, mayo, etc.) I have a Coling Systme refresh kit on order from FCP Euro. Might as well do it all!
Old 01-08-2017, 06:15 AM   #3372
BMOne
My Ride: 325CI 03
Originally Posted by jmo69 View Post
Sounds like you still have are in the heater core, check the level when its cold and if you need to add more coolant do it with the bleed screw out and the usual key on, heat on high fan on low. Watch for more bubbles out of the bleed screw. Hopefully the higher rpms will push the air out of the heater core and into the expansion tank.
I think the level has stabilised, today the coolant level was the same as the day before. It's really hot down here atm but i will try bleeding with the screw off again when it cools down
BMOne is offline   Reply With Quote
Old 01-08-2017, 12:19 PM   #3373
jmo69
I think you're done, if the level hasn't changed the air should be out. Check it regularly keeping in mind the warmer the ambient temp the higher the float will be. The levels on the float are for an optimum temp of 68F.
Hers His
Old 01-08-2017, 02:51 PM   #3374
sixelaaaa
My Ride: bmw
Sorry if i post in wrong thred but i am lost.i own an e46 318ci n46b20 and i do not know what antifreeze is suitable.in realoem it gives me 3 part numbers.also i do not know which the difference between green and blue antifreeze.can you help me please?
***931;***964;***955;***952;***951;***954;***949; ***945;***960; ***964;***959; LG-D855 ***956;***959;***965; ***967;***961;***951;***963;***953;***956;***959;***960;***959;***953;***957;***964;***945;***962; Tapatalk
sixelaaaa is offline   Reply With Quote
Old 01-08-2017, 02:53 PM   #3375
Mbryant616
***931;***964;***955;***952;***951;***954;***949; ***945;***960; ***964;***959; LG-D855 ***956;***959;***965; ***967;***961;***951;***963;***953;***956;***959;***960;***9 59;***953;***957;***964;***945;***962; Tapatalk
Don't know about specific part #'s but I bought genuine BMW coolant from my local dealer ($27 per gal) and distilled water from the local grocery. 50/50 mix.
Old 01-08-2017, 02:54 PM   #3376
sixelaaaa
My Ride: bmw
What colour was that?
Old 01-08-2017, 02:59 PM   #3377
alcarazdiego10
My Ride: 2003 325i m56
There usually blue
Sent from my SAMSUNG-SM-N900A using Tapatalk
alcarazdiego10 is offline   Reply With Quote
Old 01-08-2017, 03:06 PM   #3378
Mbryant616
It's in a gray jug but the coolant is BLUE. This is what I have (but I purchase at my local stealership).http://www.bimmerworld.com/Fluids/Ge...sCIBoCjwrw_wcB
Old 01-11-2017, 03:34 PM   #3379
BMOne
My Ride: 325CI 03
I can hear a slight chirping sound when first starting the car in the morning, seems to go away after. coolant level looks good and I haven't needed to put in anymore in today.
Is it really not recommended to open the bleed screw just a bit when it's warm/hot to lose the air?
Temp seems to go up to 98c (seen it at 99c for a sec) then goes down is this normal ?
Old 01-11-2017, 03:34 PM   #3380
BMOne
My Ride: 325CI 03
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
Rate This Thread
