Sponsored by BAVSOUND
Old 07-10-2013, 05:36 PM   #1
Luis4810
My Ride: 2001 325ci
Help!!!!! No sound from my speakers radio still works
My speakers don't sound at all my radio is working it shows the radio stations turns on and everything. I been trying to read post on here about the same problem and I already checked my fuses I try disconnecting the battery and leave it for 15 mins and disconnected the amp and waited 1 minute but still no sound the only thing I can think of now is my factory amp if its burn has anyone ever had this problem or can you give me other things I could try before I buy a new factory amp ??
Luis4810 is offline   Reply With Quote
Old 07-10-2013, 06:01 PM   #2
aldeghij
My Ride: 2003 330i
Is it the Harman Kardon system? If so I had the same problem. Water had leaked into my trunk and ran right down through the amp. Had to buy used one.
aldeghij is offline   Reply With Quote
Old 07-10-2013, 06:38 PM   #3
Luis4810
My Ride: 2001 325ci
I don't know what system it is and where did you buy the amp from ?
Old 07-10-2013, 08:19 PM   #4
Br3tt71
My Ride: 2000 BMW 323i
Go on ebay and search for a used amp for your car. I got mine for like $60 I think with a year warranty.
Br3tt71 is offline   Reply With Quote
Old 07-10-2013, 09:21 PM   #5
aldeghij
My Ride: 2003 330i
Re: Help!!!!! No sound from my speakers radio still works
I got mine at a bmw recycler here in town, cant remember what I paid for it. If it's the Harman kardon system it would say it on the speakers themselves. There would also be an amp in the trunk behind the carpet on the drivers side.
Sent from my Nexus 7 using BimmerApp mobile app
Old 07-12-2013, 01:14 PM   #6
Luis4810
My Ride: 2001 325ci
Hey yeah I have an hk system is there any way I could be 100% sure that its the amp that's blown ??
Old 07-12-2013, 01:29 PM   #7
FenderGuy05
My Ride: 2002 BMW 325i
If you're getting no sound from the speakers, but the radio is working that would be the most logical decision. I had the same issues at one point when putting in my new radio, realized the connection to power the amp was loose. Once i fixed that, the speakers worked again.
FenderGuy05 is offline   Reply With Quote
Old 07-12-2013, 01:33 PM   #8
Luis4810
My Ride: 2001 325ci
Hey thanks, and yeah that would be the most logical thing i will double check it before I go off and buy a new amp because I had a splice connected to the amp signal wire for my other amp I wonder if that could be the problem
Old 07-12-2013, 01:46 PM   #9
FenderGuy05
Definitely could be an issue with the splice, didn't even realize you had done that.
Old 07-12-2013, 01:51 PM   #10
Luis4810
My Ride: 2001 325ci
Yeah I forgot to put that on the post I have 2 12s in my
Trunk but the only wire I'm tapping is the remote wire
Old 07-12-2013, 01:59 PM   #11
willsbma
My Ride: 99 323i
You probably blew the amp.mAnyway, I'd check fuses first. Make sure you're getting power to the amp turn on wire from the radio, maybe a voltmeter pinned into your splice.
Matte Black Kidney Grilles | Smoked Tails & Corners | Mtech II Bumper | Hotchkis Springs | ACS Roof Spoiler | M3 Spoiler | 20% Tint
WTB: Black sun visors & grab handles - PM ME!
I have P.A. Soft and a 20-pin adapter. Only used it a few times but pm me if you need anything coded!
willsbma is offline   Reply With Quote
Old 07-12-2013, 02:08 PM   #12
Luis4810
My Ride: 2001 325ci
[QUOTE=willsbma;15565685]You probably blew the amp.mAnyway, I'd check fuses first. Make sure you're getting power to the amp turn on wire from the radio, maybe a voltmeter pinned into your splice.[/QUOTE
that was the first think I did and my fuses are fine I just check my splice to the remote wire and it's fine I guess I just need a new amp thanks everyone for your reponses I appreciate it
Old 07-12-2013, 03:10 PM   #13
willsbma
My Ride: 99 323i
Before you go amp, check the power from the radio to the amp turn on. I'm not exactly sure but I would imagine the radio turning on would send a low voltage signal to the amp thus telling it to turn on. It would make more sense than having the amp on every time the car was on versus just the radio being on. There's probably turn-on circuitry in both amp and radio.
Old 07-23-2013, 08:12 PM   #14
Luis4810
My Ride: 2001 325ci
I bought a new amp from eBay replaced the old one and still I have no sound wtf do you think it might be the radio ?
Old 07-24-2013, 10:46 AM   #15
Luis4810
My Ride: 2001 325ci
I changed my amp and still no sound I'm out of ideas of what it could be ? Could it be the radio ?
Old 08-15-2015, 11:00 PM   #16
Dark_Madder
My Ride: 2004 E46 330ci coupe
Frutrated
Not that it helps, but i have the same issue. I bought a new amp and a new head unit and still no audio. It's EXTREMEKY frustrating!
Dark_Madder is offline   Reply With Quote
Old 08-24-2015, 05:34 AM   #17
GuidoB
My Ride: BMW E46 330i Touring
Another one here! My amp is tested and is ok, sometimes i have sound, most of the times i dont. I was planning to find another headunit, but i see that didnt work for you.
Do you have television, if yes, when you select television, does it show mute in the bottom of the screen?
My head unit seems to get stuck in mute mode.. I already cut the mute wire at the amp, but that only worked for a week.
Im not sure what to do...
GuidoB is offline   Reply With Quote
Old 08-25-2015, 09:51 PM   #18
jontizzle
My Ride: 2001 330ci
Woah, same issue happened to me. Installed a new Pioneer unit, it lit up worked and everything but no sound. I also have the HK system. I even tried splicing that white(?) amp signal wire into my head unit but gave up after frustration and just put my old Business CD back in
jontizzle is offline   Reply With Quote
Old 12-03-2015, 02:19 PM   #19
eroc75
My Ride: 2004 SGM 330i ZHP
Hey guys.. Another one here. I was actually jamming pretty hard and I pulled into my apartment and set in my parking space till that song went off. And it was turned up pretty damn loud! LOL next time I get in the car, same thing.. Radio is working, CD player is working, zero sound. Did you guys figure any of it out?
eroc75 is offline   Reply With Quote
Old 01-01-2017, 02:32 AM   #20
Dark_Madder
Un.......Real
It was been 4 years. I feel like Tom Hanks in Castaway. I have not heard sound from my speakers in over 4 years. I commute 2 hours a day and the silence is deafening! I am seriously considering selling my car simply because I cannot figure this out. I've replaced the head unit, the amp, every component in the trunk and even the re-ran a new cable from the amp to the head unit. All fuses are fine. I tried some stupid tricks from YouTube channels that say Turn the Key to on, turn your signal on, turn headlights off, rub your belly and poke a hole in your neck and wait 20 seconds, shoot all the Smurfs that emerge from your dashboard and set a small spring trap for the pink rabbit that lives in the door panel. I am about to kill. For god's sake is there ANY ONE...EVEN THE FREAKING DESIGNER that could possibly have a freakin clue?????? In the meantime, I'll be getting fitted for my straight jacket.
Don't be jealous the voices don't talk to you...
amp, e46, no sound, speakers
