E46 Xi Forum
Old 06-16-2017, 07:47 PM   #1
WilloCO
My Ride: '05 330xi 6 speed
Hmm, Bent trailing arm?
I got my car aligned today after all my suspension work.
They indicated that the right rear trailing arm was maxed but still out of spec and figured that it's bent or the hub to trailing arm is bent.
So, anyone had that? I figure I'll pick up another arm and fit it...
Originally Posted by YoitsTmac View Post
I bedded my pads when I switched from ceramic to my PDF-Z pads. They actually caught fire during bed in.
05 330xi 6 speed
RIP: 86 e30 w/E36 M3 suspension build
WilloCO is offline   Reply With Quote
Old 06-17-2017, 05:35 PM   #2
zander271
My Ride: 6spd ZHP/5sp XI
Look at the lower rear control arm. They can easily bend and throw things off.
http://www.realoem.com/bmw/enUS/show...diagId=33_0840
#5 and #7
Part #7 can mask the bend arm. I find it very hard to believe your training arm is bent.
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 06-17-2017, 05:42 PM   #3
WilloCO
Just replaced with SPC steel arms. I'm thinking it's more likely that the rtab is failing
Sent from my Nexus 5X using E46Fanatics mobile app
05 330xi 6 speed
Old 06-17-2017, 07:54 PM   #4
WilloCO
I'm going to hit the RTABs this weekend. I didn't realize that the mount was moved for the alignment. However, the shop I used said they'd be happy to toss it on the rack again for 'touch ups' after I've swapped it.
05 330xi 6 speed
Old 06-19-2017, 02:35 PM   #5
zander271
Yep the RTA position and the lower rear control arms controls are how the alignment is adjusted in the rear. Good call on the upgraded arms.
