///M3 Forum
Old 06-01-2017, 02:30 PM   #1
916M3
My Ride: M3
HELP! E46 M3 oil leaks
Help! E46 M3 oil leaks. My brother and I replaced the clutch and flying wheels, oil pan gasket, rear main seal and CPV-O ring. After all that, we are so excited we get to put the stuff back onto the car. The only thing that was put back onto the car was the manual transmission (engine not running). Everything else still under the car. We noticed oil is leaking from the bellhousing as shown in the pictures. Did we missed something or did something wrong? Autosolutions SSK will be installed also! We also having a hard time putting the starter back. Any advice would be greatly appreciated.
ID:	656077   Click image for larger version
ID:	656078   Click image for larger version
ID:	656080   Click image for larger version
916M3 is offline   Reply With Quote
Old 06-02-2017, 07:18 AM   #2
bradleyhenry94
My Ride: 2001 BMW E46 M3 6MT
its a long shot but if the leak is coming from above the cpv maybe valve cover gasket?
bradleyhenry94 is offline   Reply With Quote
Old 06-02-2017, 12:28 PM   #3
PITT M3 RR
My Ride: E46 M3
Cam POS sensor o ring is above too. Oil pan gasket too
UUC SSK / AFE STG1 Intake / AKG Red Motor mounts / AKG Red Tranny mounts / AKG Red Subframe bushings / AKG Red Differential bushings / AKG Red RTABS / TMS Subframe reinforcement / Custom in trunk subframe structural brace / Bilstein PSS10's / Ground control camber plates / Turner RSM
PITT M3 RR is offline   Reply With Quote
Old 06-03-2017, 11:30 PM   #4
916M3
My Ride: M3
New CPV-O ring, rear main seal and oil pan gasket
Old 06-09-2017, 09:14 PM   #5
916M3
My Ride: M3
Forgot to mention, we drained the oil before we did the clutch/flying wheel, rear main seal and oil pan gasket. We haven't put the new oil in yet, so where is the leak coming from?
