Slipping clutch after 40,000 miles - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 06-09-2017, 10:31 AM   #1
megammax
My Ride: M3
Posted this over at m3forum, but wanted to see if anyone here could offer some insight.
Hey Everyone. Here's a little background on my car. About 40k miles ago I had a clutch replacement. I had the clutch disk, pressure plate, release bearing, flywheel, pilot bearing and pivot pin replaced.
Over the past month or two I've noticed what feels like the clutch slipping. I first noticed on the highway, when I stepped on the gas there would be an rpm surge before the car accelerated. It's gotten progressively worse. Now it slips between all gears. The rpms will surge almost to redline when changing gears.
I just replaced my guibo and center support bearing hoping that was the problem. There is no change in performance after these repairs.
It seems unlikely that I could have burned the clutch this quickly. I don't ride the clutch or drive like a maniac. Is there something else that could cause this behavior? Master or slave cylinder? I haven't noticed any leaks and my reservoir is full. I have noticed that I have to keep the clutch pedal pushed all the way to the floor to start the car.
A few months ago I switched out my brake calipers, but did not bleed the clutch. Could that have started the problem? Any input would be greatly appreciated. Thanks.
megammax is offline   Reply With Quote
Old 06-09-2017, 10:58 AM   #2
Dan04E46
My Ride: '04 S54B32 Coupe
Leaking rear main seal?
DAN WAS HERE
2001 330Ci= Sold :(
2004 M3 coupe= Mine! :D
Dan04E46 is offline   Reply With Quote
Old 06-09-2017, 12:48 PM   #3
megammax
My Ride: M3
Would I be able to see the leak from under the car?
Old 06-09-2017, 06:49 PM   #4
BKMrSteel
My Ride: 99 328i
Have you been finding oil under your car? Was the rear main not replaced with the clutch?
You might be able to see it leaking. Look on the bottom of the bell housing where it mates the engine, you will find a small gap at the bottom. Oil will drip from here, and usually cover the bottom of your trans if the rear main is leaking. Other leaks further forward can cover this aria as well. Clean the under side really well, and check again after a short time.
If so, you are probably looking at a new clutch disk, rear main, PB, TOB. I think the oil contaminates the disk, and I wouldn't open my trans without replacing the rest anyway.
Flywheel and PP should be fine.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 06-09-2017, 10:08 PM   #5
megammax
My Ride: M3
I was just under there replacing guibo and center support bearing and didn't notice any leaks. But I'll check again tomorrow. Regardless I'm taking it to the shop next week, but am still open to suggestions.
Old 06-12-2017, 10:27 AM   #6
megammax
My Ride: M3
Looked under the car. No leaks.
Old 06-12-2017, 10:39 AM   #7
GhostFlame
My Ride: E46 Sedan
If it is not leaking, I would really check the slave cylinder's operation & bleed it thoroughly.
You would be looking at pressure plate next if that checks out.
GhostFlame is offline   Reply With Quote
Old 06-12-2017, 11:35 AM   #8
BKMrSteel
My Ride: 99 328i
What does the clutch pedal feel like? Do you feel any vibration if you rest your foot on the pedal, or press lightly?
Do you have a self adjusting pressure plate? Try bleeding the master/slave, make sure it's working properly, and go drive the crap out of it. It's going to work, or it won't. Can't really harm it further.
I personally don't think a slave would make the clutch slip. It should be the opposite, as it would be unable to engage the clutch and staying locked up.
</a>
Old 06-12-2017, 12:21 PM   #9
GhostFlame
My Ride: E46 Sedan
Sure it can. If the piston doesn't fully retract, your clutch is never fully engaged.
Old 06-12-2017, 12:28 PM   #10
GhostFlame
My Ride: E46 Sedan
Also, did you check your brake fluid level? Simple but often overlooked.
I'm confused.. these parts have nothing to do with a slipping clutch.
If the guibo completely failed (never heard of such a case), you would not be moving anywhere at all.
Old 06-12-2017, 03:42 PM   #11
megammax
My Ride: M3
Fluid level is good. I'll try bleeding everything thoroughly.
Replacing the guibo and center support was wishful thinking. I already had the parts and they needed to be replaced anyway.
Old 06-12-2017, 03:45 PM   #12
megammax
My Ride: M3
This is what it feels like. Clutch engages, but not fully. The pedal has no vibrations and shifts easily between gears. It just doesn't have the power.
The rpms go up way too much in proportion of the speed the car is traveling.
Old 06-12-2017, 07:47 PM   #13
shoman24v
My Ride: 2002 330i 1999 328is
Are you sure you didn't drive the hell out of it?
2002 330i - 5-SPD 91k | 1999 328is - 12+ years of ownership, 221k (170k by me) 5-SPD, Factory M Aerodynamic Package, No Sunroof
shoman24v is offline   Reply With Quote
Old 06-12-2017, 09:25 PM   #14
megammax
My Ride: M3
Not enough to destroy the clutch this fast. The original clutch lasted 130,000 miles.
Old 06-15-2017, 08:26 PM   #15
Commando
My Ride: M3 - SMG
If its an original SAC they can be installed wrongly and not adjust. Requires removal and correct re-install.
If you have not burned the clutch out yet you can re-use it.
Commando is offline   Reply With Quote
Old 06-20-2017, 06:07 AM   #16
megammax
My Ride: M3
Bringing it in tomorrow. I'll update the thread when I have a diagnosis. Thanks for all the replies.
Old 06-22-2017, 08:25 AM   #17
megammax
My Ride: M3
Ding Ding Ding! We have a winner! Unfortunately it looks like I need a new clutch kit and flywheel.
