///M3 Forum
Old 06-08-2017, 12:35 AM   #1
spark90703
My Ride: 2003.5 E46 M3
shorter clutch pedal movement.
like the title says is there a clutch pedal that makes shorter movement?
also unrelated but what is the normal idle for e46 m3 manual?
mine idles about 800-850 rpm.
spark90703 is offline   Reply With Quote
Old 06-08-2017, 02:21 AM   #2
Commando
My Ride: M3 - SMG
A shorter clutch will be a heavier clutch - unless you upgrade to SMG...
Idle is right and RPM is set in the DME. The IAC can get glugged up if you are having idle problems.
Commando is offline   Reply With Quote
Old 06-11-2017, 12:28 AM   #3
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
have you considered a clutch stop?
http://www.ebay.com/itm/BMW-Clutch-S...8iOz1g&vxp=mtr
JetBlackE46 is offline   Reply With Quote
Old 06-11-2017, 01:02 AM   #4
BKMrSteel
My Ride: 99 328i
Shorter clutch movement can be had with a clutch stop, as mentioned.
https://forum.e46fanatics.com/showthread.php?t=206363
Shorter clutch engagement can be had with a heavier, stronger clutch. Depending how far you go, and type of clutch, drivability becomes more challenging under daily use.
On a previous car, I installed a 12lb flywheel, heavy pp, and 6 puck clutch with LSD. It was impossible to take off in the rain without the back end coming loose.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 06-11-2017, 03:06 PM   #5
spark90703
I found this Mason clutch pedal on ebay.
I'm thinking about trying it.
http://www.ebay.com/itm/MASON-ENGINE...ZZMZXM&vxp=mtr
I will consider the clutch stop though I don't think my car has it.
thanks
Old 06-11-2017, 04:20 PM   #6
BKMrSteel
My Ride: 99 328i
thanks
That's a lot of money for a part that's going to do the exact same thing. The clutch stop is basically a spacer under the pedal to prevent further travel. It's something you make or install, doesn't come on the car. Read the thread I linked.
</a>
Old 06-19-2017, 03:59 AM   #7
spark90703
clutch stop
I went ahead and gave it a try, the clutch stop, it worked wonderfully.
it made it feel like the clutch pedal has been shorted.
I thought maybe my car would not start but my car started just fine.
thanks.
Old 06-19-2017, 04:59 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Nice. I have the stop as well and it's great. Enjoy
