Griffin #116 Turner SpecE46 build - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 12-17-2014, 10:11 PM   #1
BigBill
My Ride: 01 330ci
2015/2016/ 2017 BUILD part 3 final stages...................................................... . This is my first car build and I plan on racing in the SpecE46 class in 2016. Until then I will be doing HPDE with NASA and a BMW CCA competition school this year. I have decided to gut the interior and install cage and seats. Lets get started.
BigBill is offline   Reply With Quote
Old 12-17-2014, 10:46 PM   #2
Rob43
My Ride: 03 331Ci 5spd R1200R
That sounds great & Welcome to E46Fanatics !
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 01-13-2015, 09:27 PM   #3
BigBill
My Ride: 01 330ci
Slight change of plans
Have decided to wait until Nov. 2015 to put in the roll cage. As I will still be driving the car to NASA HPDE events. I have started to remove the interior, including the sunroof and will be replacing the electric seats with manual seats to give me more headroom. I had started posting what I was doing on FaceBook but have decided to post build updates here (it is more work) and leave FaceBook for when I need a quick answer. Just want to say thanks to everyone for the suggestions and support.
Name:	looking into trunk.jpg
ID:	586908   Click image for larger version
Name:	removing interior.jpg
ID:	586909   Click image for larger version
Name:	stuff out of car.jpg
Old 01-13-2015, 09:46 PM   #4
BigBill
My Ride: 01 330ci
Interior for sale 01 330ci grey leather sport
check out my post on craigslist, please.
http://chicago.craigslist.org/nwc/pts/4826718755.html
Name:	sport seats.jpg
ID:	586912   Click image for larger version
Name:	sport seats closeup.jpg
Old 01-23-2015, 06:52 PM   #5
325ragtop
My Ride: needs more HP
Good luck with the build!
I'm doing the same thing here on the east coast.... Like you, I plan to use the car for HPDE this year with the goal of being ready for SE46 by next year. If it were just the car I was prepping, the timetable would be a lot shorter. It's the driver prep that will take some time for me.
Mine is an 03 sedan... I've done front and rear control arms. FCABs and RTABs, put in a temporary coil over set up to replace the original 140K worn out suspension, and I'm currently refreshing connecting rod bushings, installing a 4 bolt oil pump and baffled pan.
Hope to see you on the track someday!
325ragtop is offline   Reply With Quote
Old 01-25-2015, 05:11 PM   #6
BigBill
My Ride: 01 330ci
My plan is to attend 8 NASA Great Lakes/MidWest HPDE events and a BMWCCA competition school. I have already done a cooling system refresh and a complete brake job with stainless steel lines, solid guide bushings, caliper rebuild, Hawk pads, new rotors and ATE brake fluid. Biggest issue I was having was hitting my helmet on the sunroof.
Old 01-27-2015, 09:12 AM   #7
BigBill
My Ride: 01 330ci
Been working on the interior when time permits. With the dash off I installed new AKG Motorsports delrin clutch and brake pedal bushings.
short videos showing before and after new bushings.
what a big differance.
Welcome suggestions from anyone with build experience as this is my first build.
Name:	interior removal.jpg
ID:	588386   Click image for larger version
Name:	dash removed.jpg
ID:	588387   Click image for larger version
Name:	clutch and brake pedal#2.jpg
Old 01-27-2015, 01:17 PM   #8
Spec E46
Moderator
how difficult was the bushing install?
Spec E46 is offline   Reply With Quote
Old 01-27-2015, 05:13 PM   #9
325ragtop
I did the AKG Clutch bushings also.... it wasn't too bad. The hardest part was getting the stupid little spring clip that holds the bushings in place to snap back in. I think I fooled around with that for about 30 mins before I breaking out the needle nose pliers and re-bending the metal to make it fit better. Start to finish it was a little over an hour to complete the clutch pedal. I haven't done the brake pedal yet
Old 01-27-2015, 05:18 PM   #10
325ragtop
I'm on a similar path with the HPDE and BMWCCA Comp school plan.
Pull that sunroof out as soon as you can. Removing the sunroof was one of the 1st things I did... that thing puts a ton of weight right were you least want it.
Old 01-28-2015, 10:10 AM   #11
BigBill
My Ride: 01 330ci
Spec46 IM me on facebook with phone# I can explain how I did it very easy in 30min. ragtop sunroof is out. A friend is going to help me make a model and make a fiberglass filler panel.
Old 01-28-2015, 10:15 AM   #12
RudyT
My Ride: 2001 330i
Doesn't BMWCCA require at least 10 BMWCCA events in the last 24 months for a w2w license? I think with NASA you can make the jump from HPDE4 with one of their Friday schools. Interested to hear your opinions, as I am interested in moving towards the same path.
RudyT is offline   Reply With Quote
Old 01-28-2015, 10:25 AM   #13
BigBill
My Ride: 01 330ci
mostly just doing NASA events, did 4 events last year, starting out this year in HPDE2 and plan on driving 8 events. Was thinking either BMWCCA school or Mid Ohio which is NASA's school for the Mid-West/Great Lakes.
Old 02-02-2015, 09:06 AM   #14
BigBill
My Ride: 01 330ci
rear window motor delete on coupe
I have been gutting the interior and decided to remove the motors that open and close the rear windows. This left the windows hanging open so I needed to find a way to secure them. I posted a question on FaceBook SpecE46 page asking others what they had done. James Clay was nice enough to post some pics of what Bimmerworld had done which got me thinking. I used some flat 1"w aluminum stock, plastic knob and elevator bolt all from my local Ace Hardware store. The cool thing about the elevator bolt is the head size was similar to the BMW part and is flat. I bent the bracket in a vice and extended down to an existing bolt hole. A large rubber washer between the elevator bolt on the outside and the large fender washer on the inside. The plastic know allows me to open the window without tools if needed. I will need to give the head a coat of paint when it warms up.
Name:	rear window with fab bracket.jpg
ID:	588990   Click image for larger version
Name:	rear window with fab bracket and elevator bolt.jpg
Old 02-02-2015, 09:13 AM   #15
BigBill
My Ride: 01 330ci
M3 mirrors
Lots of discussion on FB about outside mirrors. Evan Levine posted some pics on the Spec E46 FB page of some mirrors he got on Ebay. I liked they way they looked and the price. Not too bad in quality and because I ordered the manual version I would not have to deal with the mirror controller on the door panels I was going to have to fabricate.
Name:	M3 mirrors.jpg
Old 02-02-2015, 09:56 AM   #16
BigBill
My Ride: 01 330ci
Door panels
I know! Three post in one day. Trying to get caught up on posting progress. Flight canceled due to snow so I have some down time. Because I'm doing my build in stages I elected to keep the windows in the car as I will be driving it to HPDE events with NASA GreatLakes/Mid-West region. The rules state if you remove door cards and keep windows it must be covered with at least .06 aluminum panel. I got a 4'x8' sheet from NGlantz for $80! Im also making a cover for the rear shelf and seat area. I also didn't like the looks and functionality of using the latch from the door card and just bolting it to the door like I have seen others do. What I really liked was the latches in Porsche GT3 cup cars. Using some scrape aluminum .9 and old bicycle parts I fabricated my own latch. I was able to cut the end of the door cable and shorten the housing without removing it from the door. If anyone is interested can provide more details but it was pretty easy. I plan on covering the panel with carbon fiber vinyl and changing the latch pull strap to red when I get a chance to make it to the fabric store.
ID:	588994   Click image for larger version
ID:	588995   Click image for larger version
ID:	588996   Click image for larger version
ID:	588998   Click image for larger version
ID:	588999   Click image for larger version
Old 02-02-2015, 10:34 AM   #17
BigBill
My Ride: 01 330ci
Tom Hitzeman photos
Tom does great work! check him out at http://f-51gtphoto.smugmug.com/
Name:	IMG_0687_TAH_NASA MO_HPDE#16BMW_Griffin_Oct2014.jpg
ID:	589007   Click image for larger version
Name:	IMG_4190_TAH_NASA MO_HPDE#16BMW_Griffin_Oct2014.jpg
ID:	589008   Click image for larger version
Name:	IMG_5293_TAH_NASA RA_HPDE#16BMW_Griffin_Aug2014.jpg
ID:	589009   Click image for larger version
Name:	IMG_7130_TAH_NASA RA_HPDE#16BMW_Griffin_Aug2014.jpg
Old 02-02-2015, 10:43 AM   #18
BigBill
My Ride: 01 330ci
M3 outside EFab Motorsports
Stopped by last week and meet with Eric at EFab. Thanks Chad Clay for telling me about EFAb. After meeting with Eric have decide to have him build my cage instead of Mark McMahan Autosport. Mark is also 6hrs away and Eric is 30min. I have also decided to make some changes to my build plan after talking with Eric. Looking forward to working with EFab on my build.
Old 02-02-2015, 11:02 AM   #19
AudiEtr
My Ride: 330i
Car is looking good Bill! I'll have to stop by soon and check out the door cards!
AudiEtr is offline   Reply With Quote
Old 02-02-2015, 11:04 AM   #20
BigBill
My Ride: 01 330ci
clutch/brake pedal bushing install
Install took about 1hr. Remove bolt holding switch bracket to clutch bracket (nut is welded to bracket) remove clip from brake pedal connection to hydraulics, remove plastic pin connecting clutch pedal to hydraulics. Disconnect both springs. Then remove 3 nuts holding the entire pedal assembly and lower the entire assembly. Then with it on the bench it is simple to remove the clips and replace the bushings. I noticed that other manufactures bushings sometimes also require a shim, the AKG bushings don't and fit perfect!
http://www.akgmotorsport.com/catalog...ion%2FBushings
