Griffin #116 Turner SpecE46 build - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 03-27-2015, 03:08 PM   #61
BigBill
My Ride: 01 330ci
Installed AKG Motorsports rear shock reinforcements, it's the little things that count.
BigBill is offline   Reply With Quote
Old 03-27-2015, 03:13 PM   #62
BigBill
My Ride: 01 330ci
Heated up the garage so I could put a bead of RTV around the sunroof filler.
ID:	594833   Click image for larger version
Old 03-27-2015, 09:34 PM   #63
325ragtop
My Ride: needs more HP
Nice job on the Sunroof Delete! Looks fantastic... sent you PM about the Mold... I have any idea, Hope you're interested.
325ragtop is offline   Reply With Quote
Old 03-27-2015, 10:04 PM   #64
325ragtop
Saw you've got your front subframe out for reinforcement. While it's out, are you also going to take this opportunity to install an oil pan baffle, address the oil pump (wire the nut, or replace with VAC or GSR 4 bolt unit) and maybe take a peak at your con rod bearings? I recently finished up those jobs... my thinking was I really didn't want to pull the bottom apart twice, so did as much as I could while it was apart.
Old 03-28-2015, 09:36 PM   #65
BigBill
My Ride: 01 330ci
Yes installing a VAC Motorsports baffle and pump shaft kit. Have not looked at bearings, good idea.
Old 03-28-2015, 09:40 PM   #66
BigBill
My Ride: 01 330ci
Putting in the good stuff in the tranny!
Old 03-28-2015, 09:46 PM   #67
BigBill
My Ride: 01 330ci
Flushed a quart of ATE using Bav Auto pressure brake bleeder, super easy! Also cleaned and greased the solid brake guide pins! The "To Do List" is getting shorter! Just 2 weeks until Gateway.
ID:	594998   Click image for larger version
Old 03-29-2015, 09:34 PM   #68
BigBill
My Ride: 01 330ci
The list is getting shorter! :-)
Old 04-04-2015, 06:59 AM   #69
BigBill
My Ride: 01 330ci
Spent the entire day working on the #becauseracecar. Installed oil pump with VAC Motorsport shaft upgrade and VAC oil pan baffle welded in by Eric at EFAB Motorsports. Installed front subframe with AKG Motorsport reinforcements also welded in by Eric. New front control arms and AKG Motorsport delrin FCAB inserts. Also got back the ECU from Epic Motorsport. The only thing left to do is install front bumper and graphics before next weekends event at Gateway with NASA.
ID:	595884   Click image for larger version
ID:	595885   Click image for larger version
ID:	595886   Click image for larger version
ID:	595888   Click image for larger version
ID:	595889   Click image for larger version
Old 04-04-2015, 09:38 PM   #70
BigBill
My Ride: 01 330ci
Picked up the bumper from Chad today looks awesome. Time for some graphics.
Old 04-05-2015, 06:52 AM   #71
BigBill
My Ride: 01 330ci
Not sure why pic didn't attach
Old 04-07-2015, 02:56 PM   #72
BigBill
My Ride: 01 330ci
Stopped by EFAB Motorsports yesterday to have Eric give my build a look over. Discovered I had put the new guibo in wrong and told me to put 2nd chassis plate back in under the exhaust rubber mounts. Completed work on the car last night. Everything else checked out fine. Now the car is ready for this weekend at Gateway!
ID:	596380   Click image for larger version
Old 04-07-2015, 03:57 PM   #73
KTulay
My Ride: SE46
It was commented on Faceback that the second chassis plate will not fit if using the resonator.
KTulay is offline   Reply With Quote
Old 04-07-2015, 08:56 PM   #74
BigBill
My Ride: 01 330ci
Running straight pipe for now
Old 04-07-2015, 09:46 PM   #75
325ragtop
Looking Good Bill! Have fun and good luck with the car @ Gateway!
I got my brakes finished, and painted the roll bar over the weekend. With a little luck, I should be ready for the track by this time next week.
Old 04-07-2015, 10:16 PM   #76
BigBill
My Ride: 01 330ci
325ragtop. Thanks. Let's see some pics
Old 04-08-2015, 01:13 PM   #77
scottarosen
Bill, have you noticed that the rubber mounts under the center support are collapsing due to the weight and the Pipe is resting on the support itself instead of being supported on the rubber? Mine seem not to be able to hold the weight.
Second question, why did EFAB recommend putting the second chassis plate back on?
Scott
scottarosen is offline   Reply With Quote
Old 04-08-2015, 03:50 PM   #78
BigBill
My Ride: 01 330ci
Pipe is close but not touching the plates. Plate is pushing the rubber mounts up. Said plates increase chassis stiffness.
Old 04-10-2015, 10:48 PM   #79
325ragtop
Ok, let's see if I can do this! Never posted pics b4.
Old 04-10-2015, 10:51 PM   #80
325ragtop
Can seem to attach more than 1 at a time.
