Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 05-22-2016, 12:47 PM   #1
bhirche
My Ride: E46 330i, X4
Wiring Question
Hi everyone,
I started to thin out my wiring harness.
First disconnected battery and took out the media harness car started without any issue. Next I traced the Horn wiring from the fuse box to the relay and disconnected it from the Horn and ground. I tried to start the car after that and it would not crank over.
I put the wiring back in but it still wont crank over. There are no error codes.
Anyone of you had a similar issue? Could it be the EWS? Could unwrapping the harness have broken another wire?
Thanks for your help!
bhirche is offline   Reply With Quote
Old 05-22-2016, 10:23 PM   #2
askjeeves
My Ride: M3/330
did you disconnect any of the ground wire connectors? I remember at some point of wire thinning I had disconnected the one on the passenger side of the transmission tunnel and couldn't figure out why the car wouldn't start for a bit.
askjeeves is offline   Reply With Quote
Old 05-23-2016, 12:39 PM   #3
BigBill
My Ride: 01 330ci
Suggest going onto Facebook SpecE46 page ask question. Tag Kevin Tulay
BigBill is offline   Reply With Quote
Old 05-25-2016, 08:04 AM   #4
BigBill
My Ride: 01 330ci
Any luck?
Old 05-28-2016, 10:11 AM   #5
tegmaniac
My Ride: 2001 330ci
I have ran into the same problem. Let me know what you find out.
tegmaniac is offline   Reply With Quote
Old 05-31-2016, 09:51 AM   #6
bhirche
The car runs again!
First I thought that it was the magnetic clutch switch. But I was wrong. Good thing I had a donor standing around, so I changed the whole clutch pedal assembly and the car starts again. Thanks for your help guys. I really appreciate it!
