2001 330ci SpecE46 Project - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 12-13-2016, 10:41 AM   #1
rollobrm
My Ride: 2001 BMW 330ci
Selling SpecE46 project to fund new business venture. 2001 330ci factory slick top, black with 130,000. This was my daily driver from 2009-2014 and I personally put 70,000 miles on this car. All maintenance was kept up. I have receipts and a detailed excel file going back to 30,000 miles from previous owner. No rust. All race parts were purchased new or in like new condition. While the car was parked on the street, the drivers front fender and bumper were damaged. New fender and M3 bumper are installed but not painted. Car is not in driving condition but will start as I was in the middle of building it. Interior is stripped, sound deadening removed, and audio harness removed from wiring.
Receipts for everything. Roughly $10,000 left in parts as it still needs safety (Cage, seat, fire suppression, etc), epic tune, Y pipe back spec exhaust, and spec MCS Suspension.
Asking $15,000 OBO
For Questions - please email rollo.bryan@gmail.com
Parts List:
Engine:
Hard Motorsports Baffled Oil Pan - installed
VAC Oil Pump upgrade kit - Oil Pump Shaft - installed
Bimmerworld m54 Heater Core delete kit - New in Box (NIB)
S52 Exhaust Headers
M50 EGR Plate - NIB
Bimmerworld e46 Non-M Front Y-Pipe - NIB
Bimmerworld Lowering Solid Engine and Transmission Mounts - Installed
Cooling
CSF e46 Non-M Aluminum Radiator - NIB
Expansion tank - NIB
Water distribution Pipe - NIB
Stewart Water Pump - NIB
E46 Non-M Silicone Coolant Hose Kit with new connectors - NIB
Driveline
Tilton Single Disc Non-M Ultra-Lite Clutch/Flywheel Kit - NIB
Bimmerworld "junior puck" Clutch Stop - NIB
Bimmerworld Race Shifter - NIB
Diffsonline SpecE46 3.46 LSD - installed
Bimmerworld solid aluminum differential mount set - installed
Guibo - installed
Suspension
New Koni Str.T dampners w H&R sport springs - rear installed
Vorshlag Camber plates
Rogue spring perches
Hotchkis Sport Sway bars - installed
Bimmerworld Adjustable steel RLCA - installed
Treehouse Eyeball Front CAB - installed
Polyflex RTAB - installed
VAC solid aluminum rear subframe bushings - installed
Lemfoeder Front control arms - installed
Brakes
Bimmerworld Stainless Brake lines - installed
Hawk HT-10 racing brake pads - NIB
Brass brake caliper guides - installed
Hard Motorsports brake cooling backing plates - NIB
Rotors - 1 track day
Wheels/Tires
Bimmerworld black 5 lug wheel stud package (with nuts) - NIB
Apex Arc-8 17x9 Satin Black with Nitto NT01 tires mounted - 1 track day
Apec Arc-8 17x9 Satin Black - NIB
Body
Bimmerworld Front subframe reinforcement kit - installed
Bimmerworld Rear subframe reinforcement kit - installed
Safety
Bimmerworld Billet seat mount - NIB
Schroth Profi II 6 point Harness - expired
Momo Steering wheel - installed
NRG Short Hub and quick release - installed
Slide-Type Captive Hood Pins- NIB
Sparco Hood Spring Kit (for trunk) - NIB
Spares
2 Rear Axles
Stock oil pan
Stock Differential
Can include stock wheels for rollers
Can include stock seats and electronics
Slightly damaged drivers front fender.
Fluids - NIB
Red Line Water Wetter
Red Line Fuel System Cleaner
Red Line Racing Engine oil
Red Line D4 ATF
Red Line RL-600 Racing Brake Fluid
ID:	647051   Click image for larger version
rollobrm is offline   Reply With Quote
Old 12-22-2016, 07:48 AM   #2
rollobrm
Posting current pictures.
ID:	647520   Click image for larger version
ID:	647521   Click image for larger version
ID:	647522   Click image for larger version
ID:	647524   Click image for larger version
ID:	647525   Click image for larger version
ID:	647526   Click image for larger version
ID:	647528   Click image for larger version
Old 01-27-2017, 10:03 AM   #3
rollobrm
Price Reduced $14,000
Car runs and drives. Dashboard is back in car, ABS and Check Engine light are on. ABS is on due to left wheel speed sensor, working on getting the correct new sensors ordered and installed. Check Engine is due to P1445 - Diagnositc Module Tank Leakage- pump control circuit signal low. Believe this is from dropping the gas tank while installing subframe reinforcements.
Tail Lights, Head Lights, Wipers all work. Emergency brake has been removed so "brake" light is on.
