No one to race with..Selling New Spec E46 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 03-08-2017, 01:40 AM   #1
Omn3d0n
My Ride: Porsche Macan
Hi All,
I decide that I would not be racing this year. I started my build last year and have nearly completed my car. I was hoping that the class would take off in colorado, but nothing and I'm the only one. All the racing is either on west of east cost. Bummer. Also the nasa gts class has had to many people leave. So its not going to happen. The car is complete except a cage & spec E46 tune. It also comes with a aluminum open trailer with a tire rack. Car has not been taken to the track. Just finished it this week and decided that it did not make sense.
PRICE: 26K for car 2.5K for trailer = 28.5K
email
sudhir@takumi-capital.com
for pictures and video
2001 White Coupe with 117k miles from California.
A lot was done and I've listed all the parts but the overview is that it all done. I've replace and upgrade everything recommended plus some. Used OEM or better for parts Bimmerworld, Turner, oembimmerparts, zechausen, ground-control, and diffsoline. Car has not been tracked.
Quick Overview.
Subframe re-enforcement kit
Engine
all hoses, gaskets. vanos, disa, ccv, gsr oil shaft, power steering, belts, pulley, engine mounts
Cooling
water pump (metal impeller), CSF radiator, expansion tank, hoses, SPAL fan, zionville thermostat
Diff
DiffsOnline Spec E46 racing Diff
Diff Cooler (Bimmmerworld pump)
OEM Diff Fluid
Powerflex bushings
Brakes
Solid Brake guides
Stainless steel brake lines
Rebuilt calipers
CASTROL SRF
Exhaust
Header
Spec E46 Exhaust + Y pipe
Supension
new control arms, bushing (all around), tie rods, TrackCAB, Powerflex RTAB, ground-control setup and sway bars
Trans
ZF Trans Dents, Guibo, Center Bearing, Tilton Clutch, Rogue Short Shift
Build Sheet
M3 Bumper Body EBAY
Solid Brake Guides Brakes Bimmerworld
Brake Rebulid Kit Brakes Zeckhausen
Stainless Steel Brake Lines Brakes Zeckhausen
CASTROL SFR Fluid Brakes Amazon
Brake Rotor Set Screws Brakes OEM Bimmer Parts
Alum Water Pump Pulley Cooling Bimmerworld
Antifreeze Cooling OEM Bimmer Parts
CSF OE-Plus radiator Cooling Bimmerworld
Expansion Tank Cooling OEM Bimmer Parts
Expansion Tank Cap Cooling OEM Bimmer Parts
Expansion tank hose Cooling OEM Bimmer Parts
Lower Radiator Hose Cooling OEM Bimmer Parts
SPAL Fan Cooling Bimmerworld
SPAL Fan Bracket Cooling Bimmerworld
SPAL Harness Cooling Bimmerworld
Upper Radiator Hose Cooling OEM Bimmer Parts
Zionsville Thermostat Cooling Bimmerworld
Expansion tank lower hose Cooling OEM Bimmer Parts
Diff Cooler DriveT Bimmerworld
SPEC E46 Diff DriveT DiffsOnline
Wheel Bearning DriveT OEM Bimmer Parts
Center Bearing DriveT OEM
BMW OEM Diff Fluid OEM
2 Oil Filter Kits Engine OEM Bimmer Parts
Air Filter Engine OEM Bimmer Parts
Alt/WaterPump Belt Engine OEM Bimmer Parts
Bimmerworld Engine Mount Engine Bimmerworld
CCV Value Hose Kit Engine OEM Bimmer Parts
Disa Value Repair Engine German Auto solutions
EGR Plate Engine Bimmerworld
Engine Belt Engine OEM Bimmer Parts
GSR Oil Pump Shaft Engine Bimmerworld
GSR Replacment Oil Shaft Engine Bimmerworld
Heater Hose Engine OEM Bimmer Parts
Heater Hose Inlet Engine OEM Bimmer Parts
Hose Cooling Pipe To Reservior Engine OEM Bimmer Parts
Hose Cooling to Rack Engine OEM Bimmer Parts
Hose to Reservior Pump Engine OEM Bimmer Parts
Housing To Block Gasket Engine OEM Bimmer Parts
Oil Dist Block Engine Bimmerworld
Oil Level Sending seal Engine OEM Bimmer Parts
Oil Pan Baffle Engine Bimmerworld
Oil Pan Gasket Engine OEM Bimmer Parts
Power Steering Alum Pulley Engine OEM Bimmer Parts
Power Stering Reservior Engine OEM Bimmer Parts
PS High Pressure Hose Engine OEM Bimmer Parts
Tensioner Pulley Engine OEM Bimmer Parts
Valve Cover Gasket Engine OEM Bimmer Parts
Vanos Line Kit Engine OEM Bimmer Parts
VANOS Repair Engine Besian Systems
Headers Exhaust EBAY
M50 Header Install Kit Exhaust Bimmerworld
Spec Exhaust Magnaflow Exhaust Bimmerworld
Y-P Magnaflow Exhaust Bimmerworld
Fuel Filter Fuel OEM Bimmer Parts
Fuel Starvation Kit Fuel Bimmerworld
Alum Subframe mounts Suspen Bimmerworld
Control Arms Suspen OEM Bimmer Parts
Discount Suspen Ground Control
E46 Coilover Completion Kit Suspen Ground Control
E46 Strut plates Suspen Turner
Front Chasis Reinforcement Suspen Turner
Front SwayBar Suspen Ground Control
Jack Pads Suspen OEM Bimmer Parts
MCS Suspen Ground Control
Meyle HD Control Arms Suspen OEM Bimmer Parts
Meyle HD Tie Rods Suspen OEM Bimmer Parts
Non M TrackCAB Suspen Bimmerworld
OEM Tie rods Suspen OEM Bimmer Parts
Powerflex Front Diff Bushing Suspen Bimmerworld
Powerflex Rear Diff Bushing Suspen Bimmerworld
PowerFlex RTAB Suspen Bimmerworld
Rear Ball Joint OEM Suspen OEM Bimmer Parts
Rear Chasis Reinforcement Suspen Turner
Rear Racing Upper Mount Suspen Ground Control
Rear SwayBar Suspen Ground Control
Shock Tower Reinforcement Suspen Turner
Sway Bar Reinforcement Suspen Turner
Weight Jack Suspen Ground Control
Guibo Trans OEM Bimmer Parts
Clutch Alignment Tool Trans Bimmerworld
Clutch Stop Trans Bimmerworld
Rogue Oct Short Shift Trans Bimmerworld
Rouge Trans Mounts Trans Bimmerworld
Shifter Selctor Rod Trans Bimmerworld
Tilton Clutch Trans Bimmerworld
ZF Trans Dents Trans Bimmerworld
Omn3d0n is offline   Reply With Quote
Old 03-20-2017, 11:30 AM   #2
revzillia
My Ride: audi/ M3
That's too bad . I think the car fits into a few SCCA classes T3 and STU if that helps
revzillia is offline   Reply With Quote
