Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 04-09-2017, 02:08 PM   #1
Spec E46
Moderator
Spec E46 race car for under 25k
2001 330i sedan, 148k miles
OS Giken race LSD with spec ratio 3.46
Spec MCS Suspension/Springs/Shocks/Camber Plates
Hotchkis F/R Sway Bars
Adjustable F/R Sway Bar Links
Ground Control Jacking Rear Spring Perches
Turner adjustable rear camber arms
Achilles Motorsports Oil Pan Baffle
Achilles Motorsports Oil Pump Upgrade
Bimmerworld Heater Core Delete Kit
Aero Catch Hood Pins
Spal Electric Fan with dash switch
DISA Valve Upgrade Kit
Bimmerworld/Epic Spec Tune
Bimmerworld "Solid Rubber" Engine Mounts
Bimmerworld SE46 Race Exhaust
E36 M3 OBD2 Headers, exhaust wrapped
Reinforced Rear Subframe
E46 M3 RTABS with Reinforcers
Rear Balljoints
Bimmerworld Brake Lines
Bimmerworld Solid Brake Guides
Bimmerworld Race Studs
SPA Firesystem
NRG Quick Disconnect/Hub Adapter
AJ Hartman Carbon Fiber Main Panel
Stewart Water Pump
Zionsville AutoSport Thermostat Kit
Carbon Fiber Sunroof Blank
BImmerworld dual fuel pump starvation kit
Recent clutch and flywheel
New coolant expansion tank
The previous owner hit a tire wall on the driver side and damaged the front fender and both doors. Rear quarter panel is a bit scuffed but otherwise ok. The doors can can probably be hammered out (I already did to some extent) and the fender may be salvageable as well depending on how picky you are. Or they can be replaced, all four doors lift right off the hinges and the front fender is easily removable.
I just got back from a two day track event (instructing bmwcca comp school) and it performed flawlessly. I aligned and corner balanced it before the event, there was no detectable tire wear after two days, nor did it consume any oil. I also set up the shocks and swaybars using my preferred settings and it drove exactly as expected, nicely neutral with just a hint of understeer that can be coaxed into oversteer as needed.
Offered at $23,900. The Sparco Pro-Adv seat and Schroth Profi 2 harness may be included at additional cost, both are one year old. Delivery within a day's drive of Raleigh NC can be arranged as well. Email jtower@gmail.com.
jason tower, spec e46 national director
Spec E46 is offline   Reply With Quote
Old 04-09-2017, 02:15 PM   #2
Spec E46
Moderator
exterior pics
ID:	653146   Click image for larger version
ID:	653147   Click image for larger version
ID:	653148   Click image for larger version
ID:	653150   Click image for larger version
ID:	653151   Click image for larger version
ID:	653152   Click image for larger version
ID:	653154   Click image for larger version
Old 04-09-2017, 02:16 PM   #3
Spec E46
Moderator
interior pics
ID:	653156   Click image for larger version
ID:	653157   Click image for larger version
ID:	653158   Click image for larger version
ID:	653160   Click image for larger version
ID:	653161   Click image for larger version
ID:	653162   Click image for larger version
ID:	653164   Click image for larger version
Old 04-09-2017, 02:21 PM   #4
Spec E46
Moderator
misc pics
ID:	653166   Click image for larger version
ID:	653167   Click image for larger version
Old 04-13-2017, 09:47 AM   #5
Spec E46
Moderator
asking price reduced to 23,900
Old 04-14-2017, 10:25 AM   #6
Spec E46
Moderator
sold
