Who here daily drives an e46 m3? Reliability? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 06-10-2017, 07:20 PM   #21
Hisdem
My Ride: 2004 M3 Convertible
Originally Posted by danwilz View Post
If your eating up tears you have a problem, unless your drifting! Check your RTAB's
Good call, but not necessarily. UHP tires like PSSs just wear horribly without rotation, even if everything else is in order.
Hisdem is offline   Reply With Quote
Old 06-12-2017, 07:03 AM   #22
Obioban
My Ride: 05 M3, 01 M5, M3iT
Send a message via AIM to Obioban
Originally Posted by scarede46er View Post
What about the rod bearings? I plan to get a z4m unless the bearings have still not been sorted out.
Rod bearing wear rate wears out by time spent at 8000rpm. If you set the limiter to 7500rpm, you'd never need to replace them. In a track car living at the limiter, they will probably need replacement at 50,000 mile intervals.
Do them as oil analysis dictates they need to be done. Not buying a car because it hasn't had a service done that it may not need at all seems silly to me.
-Ian
Current Cars: 2005 IR/IR M3, 2001 LMB/blk M5, Wife's 6mt NA RWD e91, 04 M3 wagon
Past cars: 04 M3, 96 M3, S50B32 e36 M3 CM race car
Obioban is offline   Reply With Quote
Old 06-23-2017, 11:07 AM   #23
Clanph25
My Ride: e46 M3
I bought my 2006 M3 coupe 6MT with 122,000 miles. I drive around 40 miles a day for my commute mostly highway here in socal. Right when i got the car i had the valve cover gasket replaced and the vanos checked. Did a coolant flush and replaced the thermostat myself. replacing the fan clutch tomorrow. other than that the car is incredibly reliable. going to check out the subframe when i put my new KW coilovers on this weekend. ive owned the car for a little under a year and it has about 132,000 miles on it now.
Clanph25 is offline   Reply With Quote
