///M3 Forum
Old 06-01-2017, 06:03 PM   #1
Timskii
My Ride: E36 s54 swapped
My s54 is making a scary noise
Hello my s54 is making a very odd noise. This noise comes on in about 3-5 minutes of driving. When the noise comes on I can make it go away if I turn the car off for about a minute but it will come back after a bit of driving. I had the VANOS system replaced with the Beisan system about 300miles ago and just today I replaced the water pump to see if it was the problem. I popped off the valve cover and the upper tensioner looked good and the sides seemed good from what i was able to see. I tried searching and no one seems to be having this noise/problem. _a_
Timskii is offline   Reply With Quote
Old 06-18-2017, 11:51 PM   #2
m3Lishus
My Ride: '04 M3
Have you checked your pulleys?
m3Lishus is offline   Reply With Quote
Old 06-19-2017, 10:30 PM   #3
tedavis01
It is hard to see where the noise is coming from from the video. I had a similar noise last year but could not locate the issue. I had it towed to the shop and discovered rod bearings had gone bad, vanos was checked and it was fine but could be that as well.
tedavis01 is offline   Reply With Quote
bmw, e46, m3, noise, s54
