///M3 Forum
Old 06-05-2017, 07:09 PM   #1
Ivanfbaby88
My Ride: E 46 m3 convertible
Bosch and valeo alternator
So my alternator went out and I noticed that the bottom half with the bearing and everything else was Bosch but the upper where my voltage regulator which was what I found was the issue so me being me thinking valeo and Bosch made a collab or something order a Bosch voltage regulator since it was cheaper basically my question is will the Bosch one work or is the valeo one needed
Ivanfbaby88 is offline   Reply With Quote
Old 06-06-2017, 07:26 PM   #2
PITT M3 RR
My Ride: E46 M3
You need the Valeo one for a Valeo alt.
Bosch for bosch.
UUC SSK / AFE STG1 Intake / AKG Red Motor mounts / AKG Red Tranny mounts / AKG Red Subframe bushings / AKG Red Differential bushings / AKG Red RTABS / TMS Subframe reinforcement / Custom in trunk subframe structural brace / Bilstein PSS10's / Ground control camber plates / Turner RSM
PITT M3 RR is offline   Reply With Quote
Old 06-07-2017, 08:38 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
+1 they are not interchangeable as the connectors and voltage regulators are different.
Old 06-09-2017, 01:33 PM   #4
Ivanfbaby88
Well I did some digging and aparantly Bosch has been refurbishing old valeo alternators and just keep the valeo regulators which is what I have I order the part and did the job myself for 70$ compared to BMW charging 500+ time to crack a cold one with the boys
Old 06-10-2017, 12:55 AM   #5
Commando
My Ride: M3 - SMG
Congrats on sorting that issue.
Does Bosch really have an interest in refurbing old alternators at all?
Commando is offline   Reply With Quote
alternator
