shorter clutch pedal movement. - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 06-08-2017, 01:35 AM   #1
spark90703
My Ride: 2003.5 E46 M3
like the title says is there a clutch pedal that makes shorter movement?
also unrelated but what is the normal idle for e46 m3 manual?
mine idles about 800-850 rpm.
spark90703 is offline   Reply With Quote
Old 06-08-2017, 03:21 AM   #2
Commando
My Ride: M3 - SMG
A shorter clutch will be a heavier clutch - unless you upgrade to SMG...
Idle is right and RPM is set in the DME. The IAC can get glugged up if you are having idle problems.
Commando is offline   Reply With Quote
Old 06-11-2017, 01:28 AM   #3
JetBlackE46
Modded
My Ride: E36/E46 M3 E46 323
have you considered a clutch stop?
http://www.ebay.com/itm/BMW-Clutch-S...8iOz1g&vxp=mtr
JetBlackE46 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-11-2017, 02:02 AM   #4
BKMrSteel
My Ride: 99 328i
Shorter clutch movement can be had with a clutch stop, as mentioned.
https://forum.e46fanatics.com/showthread.php?t=206363
Shorter clutch engagement can be had with a heavier, stronger clutch. Depending how far you go, and type of clutch, drivability becomes more challenging under daily use.
On a previous car, I installed a 12lb flywheel, heavy pp, and 6 puck clutch with LSD. It was impossible to take off in the rain without the back end coming loose.
<a href=http://forum.e46fanatics.com/showthread.php?t=1094528 target=_blank>http://forum.e46fanatics.com/showthread.php?t=1094528
</a>
BKMrSteel is offline   Reply With Quote
Old 06-11-2017, 04:06 PM   #5
spark90703
I found this Mason clutch pedal on ebay.
I'm thinking about trying it.
http://www.ebay.com/itm/MASON-ENGINE...ZZMZXM&vxp=mtr
I will consider the clutch stop though I don't think my car has it.
thanks
Old 06-11-2017, 05:20 PM   #6
BKMrSteel
My Ride: 99 328i
thanks
That's a lot of money for a part that's going to do the exact same thing. The clutch stop is basically a spacer under the pedal to prevent further travel. It's something you make or install, doesn't come on the car. Read the thread I linked.
</a>
Old 06-19-2017, 04:59 AM   #7
spark90703
clutch stop
I went ahead and gave it a try, the clutch stop, it worked wonderfully.
it made it feel like the clutch pedal has been shorted.
I thought maybe my car would not start but my car started just fine.
thanks.
Old 06-19-2017, 05:59 AM   #8
Solidjake
Radar Specialist
Solidjake's Avatar
My Ride: '13 328i Msport 6MT
Nice. I have the stop as well and it's great. Enjoy
