No start fuel issues - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 06-13-2017, 12:42 AM   #1
Bradzx
So after comming home from the gym I noticed I had about 12 miles left to run on , on the way to the gas station I wanted to fill at a ethonal free station two miles away , after driving a mile the car suddenly shut off but the power was still on . Tried to start the car but still didn't fire long story short I got gas filled it still didn't turn over or fire. Car had been towed home .When ever I turn into position two no power to fuel pump , no noise nothing. Checked fuses in the glove and under the hood and all checked out. At this point I'm thinking it's the fuel pump , replaced fuel pump and still no power to the pump or noises I'm thinking it's the fuel pump relay any insight would help
Bradzx is offline   Reply With Quote
Old 06-13-2017, 02:05 AM   #2
Topazzar
My Ride: '02 M3
Check this out - http://www.pelicanparts.com/BMW/tech...mp_Testing.htm
Do it in reverse order though, check the relay first. The fuel relay is the same as some others (light green) so you can swap another one in to see if the fuel pump starts to prime
E46 M3|ESS Supercharged|SG V1 Muffler|Silvers Coilovers
Topazzar is offline   Reply With Quote
Old 06-13-2017, 08:45 AM   #3
Bradzx
I thought the fuel pump relay is all black and in the trunk beside the green one ?
Sponsored Links
Advertisement
Old 06-14-2017, 12:43 AM   #4
Bradzx
Bump
Old 06-14-2017, 11:16 PM   #5
Bradzx
Bump still neeed some more info guys
Old 06-15-2017, 06:18 AM   #6
Kalloni
My Ride: BMW E46 320d 2003
Did you try starting it with throttle wide open?
Kalloni is offline   Reply With Quote
Old 06-15-2017, 11:41 AM   #7
Bradzx
I have not but with I power the fuel pump I don't think it would make a difference e
Old 06-15-2017, 09:10 PM   #8
Commando
My Ride: M3 - SMG
So does the motor turn as in crank when you try to start?
If it is turning over but not firing do some research youself on the EKP MODUL near the battery in US cars.
Commando is offline   Reply With Quote
