///M3 Forum
Old 06-13-2017, 11:12 AM   #1
Zaphod330ci
My Ride: 2001 PY M3 vert
!!!please help!!!
Ok so i am about to go crazy with a problem!
The Car:
2001 phoenix yellow convertible m3 with 76k miles and mostly stock except for Dinan Exhaust and AFE intake
The Original Issue:
i was out for a day off drive and was going relatively quickly on a back road when i went to grab 5th gear at speed, it didnt want to go in so i went back to neutral, blipped the throttle and then all was well. i didnt think too much of it and carried on, the next day on my drive to work i pulled out of the gas station and went to shift from 1st to 2nd and my clutch wouldnt disengage! i pumped the clutch and got enough pressure to shift enough to get to my office. This felt like a slave cylinder gone bad and after sifting through the forum it seemed like a safe bet.
What Ive done so far:
First i replaced the slave cylinder with a NAPA part and bled the system etc... no luck
Then i thought maybe master so back to NAPA and got a master for it, installed bled and still no luck...
After this i thought maybe the NAPA parts werent up to the task so i ordered a new master and slave from my BMW stealer in town and put genuine parts in, bled the system and feeling pretty good about it but no luck
I then realized that the only part of the hydraulic system that i hadnt changed was the hose in between the master and the slave so i ordered a stainless steel hose as it was an upgrade i wanted to do anyway, bled the system and still NOTHING!!!
Where i am now:
All new parts from BMW and a system that i am nearly 100% certain has no air in it but i cant get hydraulic pressure in the clutch!!!
Please someone help! I have run out of ideas and wonder if anyone has had an issue like this before and can help me get my car back on the road!
Zaphod330ci is offline   Reply With Quote
Old 06-13-2017, 11:25 AM   #2
M3ibarra
My Ride: 04 e46 m3
When was the clutch last changed?
M3ibarra is offline   Reply With Quote
Old 06-13-2017, 11:30 AM   #3
Zaphod330ci
its the stock clutch i believe, im the second owner
when the car is in gear though the clutch grabs fine so that would indicate the clutch is ok right?
if i pump the clutch pedal then i can get it into gear
Old 06-13-2017, 11:49 AM   #4
M3ibarra
My Ride: 04 e46 m3
Does the pedal feel the same with new parts as it did with the original parts?
Old 06-13-2017, 11:50 AM   #5
Zaphod330ci
yep pretty much
Old 06-13-2017, 12:06 PM   #6
M3ibarra
My Ride: 04 e46 m3
Grinds on all gears unless you pump pedal?
Old 06-13-2017, 12:10 PM   #7
Zaphod330ci
yeah just like there is no pressure
Old 06-13-2017, 12:25 PM   #8
M3ibarra
My Ride: 04 e46 m3
I'm gonna say it's the clutch that's worn down
Old 06-13-2017, 12:35 PM   #9
Zaphod330ci
but if the clutch is worn then wouldnt it slip?
Old 06-13-2017, 01:32 PM   #10
M3ibarra
My Ride: 04 e46 m3
If the pressure plate is over heated and has a glaze in it it will slip. Could possibly be the entire clutch system.
