Summer projects - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 02-05-2011, 08:07 PM   #41
cak323i
My Ride: ///M3 & 330i ZHP
sg,
Awesome posts on brakes Thanks for the valuable info
I'm now subscribed
2004 TiAg ///M - 171,000 miles.......................2003 Imola ZHP - 180,254 miles
cak323i is offline   Reply With Quote
Old 02-12-2011, 12:23 PM   #42
sg_wannabe
My Ride: '06 M3 Coupe
Send a message via AIM to sg_wannabe
Originally Posted by pmoneyblass View Post
Good information on breaks.....
Sent from my PC36100 using Bimmer App
Originally Posted by cak323i View Post
sg,
I'm now subscribed
sorry for the late reply, y'all. i somehow missed the email notification. i don't frequent this forum.
i am glad that my reply posts are somewhat helpful. i did some research on them combing what i found with what i already know.
i think most folks will agree that bbk has the "pop" or bling factor. whether or not they are worth it depends greatly on what you are looking for (i.e. your priorities in considering them) as well as budget considerations, etc.
if it is given that one wants better overall braking performance, then it is arguably worth it. even if one were to track regularly, many experienced folks would say that a good set of tires, good set of pads, stainless steel lines, and better-than-oem brake fluid are more than adequate especially if one were to brake correctly. but if one were to track heavily and do long heats/sessions, then it warrants serious consideration for a bbk. depending on what bbk one considers, pad choice will change. in some cases, it opens up the opportunity to run far better race/track application pads. in other cases, one will "lose" the option of other pads including street application options. some bbk designs allow changing pads without removing the caliper while others do not.
there are many other things to consider including the cost of maintenance and replacement parts (rotors especially). another is whether or not the bbk has dust boots. this is a near non-factor for a heavily tracked car but something to think about when driving a lot on the street. in addition, depending on what bbk design and brand one gets as well as what wheels one has or is considering, proper wheel clearance can be an issue.
PROJECT UNDER WAY
sg_wannabe is offline   Reply With Quote
Old 02-12-2011, 04:56 PM   #43
eyebrakel8
My Ride: Harley
Vanos, bearings, valve adjustment, subframe, coils to start with mine.... Got her used and feel like she could be spruced up a bit. Then it's pulleys, electric fan, radiator, rear and alpha.n.tune. I don't talk about my power goals cause I'm going for NA for now.... Already have cat less SS headers, acs exhaust and shark. Lots of bracing and coil overs and 2800 pounds makes the S54 faster than an M3.
eyebrakel8 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-12-2011, 04:59 PM   #44
eyebrakel8
My Ride: Harley
Shadowless,
A BBK would net extremely low performance gains if any over good pads, fluid and SS lines. They are more aesthetic than anything. That being said... I'll have one once my car is sorted to 110% with standard up keep and such. The PO did not keep her to my liking but the price was right.
Old 02-24-2011, 10:35 AM   #45
pmoneyblass
My Ride: M3
With your current setup what was the hp gain???
pmoneyblass is offline   Reply With Quote
Old 06-07-2017, 03:00 AM   #46
BimmerSmitty
My Ride: 2004 BMW M3
I just got mine! New wheels, Change Spark Plugs, Get the Air bag recall done, paint the calipers to match and change the brake pads and new rotors cross drilled and slotted. It looks like its also could use new belts. I'm also going to change the suspension to the Billstein pss10's that I have in my 325I and putting some cheap raceland coilovers in the 325I my son uses it now.
Slave to OT
BimmerSmith
BimmerSmitty is offline   Reply With Quote
Old 06-07-2017, 02:10 PM   #47
ol_Blue
My Ride: m3
Pay it off
ol_Blue is offline   Reply With Quote
Old 06-19-2017, 12:47 AM   #48
m3Lishus
My Ride: '04 M3
Paying a professional for an opti coat treatment for your car and wheels won't be such a bad idea.
m3Lishus is offline   Reply With Quote
