when I was going thru a similiar phase with my 318i N42B20 I also looked at the MAF. First I was told it must be the alternator, which I refurbished, then I was told it must be MAF which I clean several times but finally it was the crankshaft sensor. It started stalling everyday just after engine reached operating temperature (105 deg C) and everytime I took in for a scan they found nothing. So I bought a basic OBD scanner. Plugged it in and drove around until it stalled then quickly read the OBD, it stated Crankshaft Sensor fault. Also noticed if I drove home first them read the OBD, it had nothing to report. I suspect when the sensor goes faulty and if you give it some time to cool off then drive around, the cars thinks it must be just a glitch and that all is fine now so it erases the fault. BTW i thought I could fix it so I opened the MAF, boy was I surprised at the electronics in there, no wonder it costs that much to replace.
is it not just a case of spraying an electrical cleaner into the maf was going to get some after work and give it a shot
it hardly looks like that?
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
