Thread Tools Search this Thread Rating: Thread Rating: 33 votes, 4.88 average.
Old 04-10-2017, 07:50 PM   #1501
being3
Modded ///Member
being3's Avatar
My Ride: Turbo M3 7168 27PSI
Intake position with larger air filter ... will fabricate heat shield above filter. All made possible with new motor mount , relocation of Vanos accumulator, and no A/C
"Horsepower is how fast you hit the wall. Torque is how far you go through it."
being3 is offline   Reply With Quote
Old 04-11-2017, 12:21 AM   #1502
332
My Ride: 332
Docrace manifold and ??? fsr tubi manifold? Who made the other manifold if you don't mind me asking?
332 is offline   Reply With Quote
Old 04-11-2017, 09:16 AM   #1503
being3
Modded ///Member
being3's Avatar
Second one is FSR tubular which they don't make any longer since going to cast. Nice thing about FSR manifold is u don't need a scavenge pump and the runners are larger.
Old 04-11-2017, 10:38 AM   #1504
TrippinBimmer
My Ride: Just Fast!
Very nice work. Starting to read your whole build thread now.
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
Stock
NAwhp/NAwtq SAE Corrected
1996 BLU/BLK M3
Stock
1988 SETA 325I
Stock
Old 04-11-2017, 02:46 PM   #1505
332
My Ride: 332
Ya, it caught my eye.... nice piece I'm jelly!
Old 04-11-2017, 07:08 PM   #1506
being3
Modded ///Member
being3's Avatar
buying a used HPF M3
All buttoned up soon ready for install
Old 04-12-2017, 06:46 PM   #1507
robshpf
My Ride: 2002 e46 m3
Is this the high compression motor your selling for 12k?
robshpf is offline   Reply With Quote
Old 04-12-2017, 07:30 PM   #1508
being3
Modded ///Member
being3's Avatar
Yes it is
Old 04-12-2017, 09:50 PM   #1509
robshpf
Oh boy, here we go,lol. Ive been out of the loop for several years now, this is tempting me, big time. Question, has the high compression high horsepower motors been proven to be as reliable as lower compression builds? I remember Marcus had a high compression build that blew fairly early if memory serves me correct. What kind of hp/torque could one expect on pump gas? I would probably upgrade to aem infinity at the same time. I know there are lots of variables, probably use my 6676.
Old 04-13-2017, 12:00 AM   #1510
being3
Modded ///Member
being3's Avatar
Hi Compression is solid with cut ring head gasket... Marcus issues were Supertec valve train clearance flaws in manufacturing that caused motor to go ... ( stay away from Supertec) Pump gas power will be arround 500-550 .. race gas around 800-850 and e85 950-torque will be very good with high compression 700-800 foot lbs ... depends on turbo 6766 6870 7168 r all good turbos. Aem Infinity I can setup tune and make sensor / relay harness as well. Spool and engine response will be very good with high compression compared to low compression.
Old 04-14-2017, 09:04 AM   #1511
MisterM
My Ride: 03 M3
Love the enthusiasm and attention to detail. Very interested in how the cut-ring motor performs in your client's car, Anthony.
MisterM is offline   Reply With Quote
Old 04-14-2017, 09:11 AM   #1512
dtmpowerjc
My Ride: 2002 m3 silvergray
Please post some vids
Sent from my iPhone using Tapatalk Pro
dtmpowerjc is offline   Reply With Quote
Old 04-24-2017, 07:34 PM   #1513
being3
Modded ///Member
being3's Avatar
High PSI line for Vanos Accumulator drivers side relocation. Allows for larger and more direct Intake.
Old 04-25-2017, 10:02 AM   #1514
autospeed_01
My Ride: 2000 328Ci
Damn! These builds look amazing, forget buying a house I'd rather buy one of these engines . I would love to drop by and see these in person if I'm in the lower mainland this year (assuming that's where you are in BC).
My Build Thread
From Salvage to Custom Widebody
DTM Style Angel Eyes (flat bottom)
autospeed_01 is offline   Reply With Quote
Old 04-29-2017, 08:27 PM   #1515
being3
Modded ///Member
being3's Avatar
Ur welcome too .. I'm on the Island
Old 04-29-2017, 09:10 PM   #1516
TREMEK
My Ride: bmw
Your pm inbox is full.
TREMEK is offline   Reply With Quote
Old 05-07-2017, 03:46 PM   #1517
S54 TBO
My Ride: E46 M3
Awesome work as usual Anthony
S54 TBO is offline   Reply With Quote
e46 m3, hpf, stage 2.5, turbo
Rate This Thread
