Old 05-14-2017, 02:43 AM   #1
Portalus
My Ride: E46 328Ci 99'
328Ci 99' Supercharger - help please
Greetings,
I'm starting a new supercharger project for my E46 and at this point I'm bussy with gathering all needed parts and items to instal supercharger. I've heard about possibility to boost M52tu B28 without a piggyback and remapping. Does some1 got any experience with kompressors in E46 ? What boost can handle OEM FlowMeter without any Check-Engine errors ?
Portalus is offline   Reply With Quote
Old 05-17-2017, 06:44 PM   #2
Infamousredrum
My Ride: Murdered out 330
You doing the hydemotorworks designed kompressor install? Im thinking of doing the sc14 Or a cheap ebay crx racing turbo as i only want to run 7psi as im auto. I am told can get away with tuning stock ecu if running like 8 or less psi
Infamousredrum is offline   Reply With Quote
Old 06-05-2017, 07:43 AM   #3
indee321
Ive just bought an sc14 to start on hyde's v2 project. I am also only wanting to keep engine stock , maybe increase injectors but thats it. Apparently an 7 -8 psi set up WITH INTERCOOLER is a reliable route to go down according to hyde's site. Its alot to get your head around though right ? ! Im still trying to work out the pulley size i need.. i cant find the diameter / radius of the 323i crankcase pulley anywhere.. not even on real oem . Does anyone know ??
indee321 is offline   Reply With Quote
Old 06-05-2017, 08:13 AM   #4
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
More likely 5.5 inch in Dia.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 06-06-2017, 10:47 AM   #5
indee321
I just been outside and measured.. i make it 5 inches diameter .. thats not great news for me , trying spin that sc14 blower
Old 06-08-2017, 12:45 PM   #6
Portalus
I'm very sorry for a so late reply but I was thinking about EATON M62 but I allready got my answear.
I've heard it's no need to piggyback it but there is a allways need to do a small "remap" for AMF and Injection plan.
Anyway my problem is solved, thank You very much for interest and one more time appologize for such late reply.
Old 06-13-2017, 04:59 PM   #7
cosmos328Ci
Hi indee321,
I have measured the three main drive pulleys that I have and all are around the 5.5 inch Dia.
(M52TU28, E39 M54B30 and E46 M54B30)
How are you measuring?
Circumference / 3.14159 ?
I was not going to reply again... but if you are doing your own calculations you need the correct size.
All the best.
Old 06-14-2017, 07:28 AM   #8
indee321
^ thanks for reply..it seems i measured the wrong pulley lol measured the one nearesy the radiator whenit should be the pulley behind it which is about half inch bigger.. cheers
Old 06-14-2017, 07:32 AM   #9
cosmos328Ci
Kool.
