Old 05-19-2017, 05:59 PM   #1
jeffbert
My Ride: 03 325Ci Convertible
Missing trunk parts 2003 325ci Vert
Hi all, I know my project car is missing the Luggage Compartment Pan (51478236311) and the push pins for the battery cover (51478248015) but is there anything else your expert eyes can find that is missing?
Oh, and one other question, what is the wire harness that is to the right of the jack tray?
and yes, I'll clean it out!
Thanks! Jeff
jeffbert is offline   Reply With Quote
Old 05-19-2017, 06:06 PM   #2
silenze
My Ride: 2003 325CI
I know there is a circle plastic piece that goes on top of the metal spare tire rod. I just put air in my spare yesterday
silenze is offline   Reply With Quote
Old 05-19-2017, 06:10 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
My E46 is no where near home now.
The mushroom shaped item goes on the metal rod to support the middle of the trunk pan.
I cannot recall if there is a foam think that the jack sits in, I know my VW has a foam organizer part that goes in this area.
Also check www.realoem.com
Old 05-19-2017, 09:34 PM   #4
jaga
My Ride: 2002 325i
No E46 near you?
Sent from my SM-A310M using E46Fanatics mobile app
jaga is offline   Reply With Quote
Old 05-19-2017, 10:02 PM   #5
reelbelligerent
My Ride: 2004 330ci coupe
I have almost the complete truck set up from my 04 330ci if you end up needing anything. PM me if you need something.
Sent from my SM-N910V using Tapatalk
reelbelligerent is offline   Reply With Quote
Old 05-19-2017, 11:22 PM   #6
saxual328ci
My Ride: 2004 325ci
Yup Realoem.com You can see what is in the trunk and also in your owner's manual?
http://www.realoem.com/bmw/enUS/show...diagId=71_0183
saxual328ci is offline   Reply With Quote
