Thread Tools Search this Thread Rating: Thread Rating: 360 votes, 4.98 average. Display Modes
Old 03-29-2014, 07:31 PM   #41
lszlszx
My Ride: 1.8T, XC70
If it cranks, you may need a fuel pump. Remove the rear seat, that way it's easier to hear the pump prime. Pull on the corner of the seat firmly on each side.
The fuel pump is under the round cover. When you turn the key to position 2, you should hear a short buzzing sound.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 03-29-2014, 07:34 PM   #42
dfuller9
I hear it but still a no go. Pulled the seat up as well
dfuller9 is offline   Reply With Quote
Old 03-29-2014, 08:07 PM   #43
mcopenha
My Ride: '01 325xi, '73 2002
Originally Posted by dfuller9 View Post
Well the car is trying to start but it will not turn all the way over. It isn't ticking like it is the starter it is cranking but the motor won't start.
your battery sounds very weak. Even if it's cranking, it may not be enough to start the car. Had a similar problem recently: http://forum.e46fanatics.com/showthr...425&highlight=. Car was cranking so I ignored the battery, but these cars need a strong battery to turn the engine over quickly enough to start.
test the theory by having someone give you a jump. If that doesn't work, have the battery charged, try again, and report back.
mcopenha is offline   Reply With Quote
Old 03-29-2014, 09:00 PM   #44
dfuller9
Thanks for the tip buddy
Old 03-29-2014, 09:00 PM   #45
dfuller9
Definitely will try
Old 03-30-2014, 01:49 PM   #46
roblivingstone
My Ride: 2000 323Ci
Hey if I pop out my wires for the exhaust cam position sensor, should oil have gotten into that plug area?? Or should it be bone dry, and oil only appear when I pull the sensor out?
I can't run codes, just replaced my fuel pump and still can't start, and noticed that when checking that sensor. New alt,battery(49), and fuel pump. Cranks strong but won't turn over.
roblivingstone is offline   Reply With Quote
Old 03-30-2014, 06:16 PM   #47
lszlszx
My Ride: 1.8T, XC70
You can trouble shoot the sensor. I don't think it's causing your no start.
https://www.youtube.com/watch?featur...&v=jUZAiHpuF0s
Are sure the oil didn't drip from the valve cover on the plug?
Old 03-30-2014, 06:49 PM   #48
roblivingstone
My Ride: 2000 323Ci
What made you so certain from the start lol. I just started a thread, with pictures. Im certain it didn't drip "on" to it because it was directly in the plug. But also I am led to believe it's my issue because I had the slow acceleration in low rpms, and had all the stalling under 40 randomly and the not 100% consistent slow starts. But it didn't wind up being the fuel pump, I am check the filter. But why would the original sensor have oil directly in it if it's not suppose to, seems to me that could cause the sensor to act funny depending on how much oil got to it at the time of use could be the reason for the fluctuation in problems. But, I don't have the tools to test it right now, but did have a CEL.
Old 03-30-2014, 07:12 PM   #49
lszlszx
My Ride: 1.8T, XC70
If it threw a code and the oil leaks through it, you need one.
I hope that'll fix it, it's uncommon for a bad exhaust cam sensor to cause no start.
Old 03-30-2014, 07:22 PM   #50
roblivingstone
My Ride: 2000 323Ci
Oh definitely. I think the intake just went too. I just can't get the codes read I'm changing both, expecting the intake to be just as old
Old 03-31-2014, 09:35 PM   #51
lszlszx
My Ride: 1.8T, XC70
If you hear the pump, you must have fuel.
Scan for codes. If nothing comes up check if there is spark.
Old 03-31-2014, 09:38 PM   #52
roblivingstone
My Ride: 2000 323Ci
ID:	552166yup she went only. Fp is prob fine
Old 04-01-2014, 03:14 PM   #53
lszlszx
My Ride: 1.8T, XC70
Sensor wires are damaged? How did that happen?
Old 04-01-2014, 03:23 PM   #54
roblivingstone
My Ride: 2000 323Ci
No clue actually. And look
ID:	552249Click image for larger version
I electrical taped over all the colours to the tubing to protect those better. They aren't brittle. But I also cut and found where the wires on the intake cam sensor were healthy, re wired and fixed up enough to get me to the shop for a new one.
Is running the wires to my exhaust cam sensor and other two plugs, safe to run from the engine > up through the gap between the oil filter and canister(unbolt and rebolt canister, wires are not tight fit) > along the front the engine to the plugs/sensors?
I'll post a picture of what I mean later
Old 04-04-2014, 10:11 AM   #55
JeffM052
My Ride: '03 M3, '94 325i
My M3 wouldn't start today. Got in the car, clutch in, turned the key. Everything was fine till I turned to ignition. Once I went to start it, the instrument cluster and all the electrical died, no click from the starter, it all died.
Got out, popped the trunk, checked the battery for a loose terminal or something obvious. Wiggled the negative terminal, but it was tight. Saw the cabin light come on, got in, tried again. Same thing. All looks good until I try to turn it over, then electrical dies, just as before.
Jumped in my Acura and found this guide at work, I'll give the troubleshooting you posted when I get home.
Any preliminary guesses?
I'd rather drive a car that breaks my wallet than one that breaks my soul.-Unknown
JeffM052 is offline   Reply With Quote
Old 04-04-2014, 02:26 PM   #56
roblivingstone
My Ride: 2000 323Ci
Is the ground wire that's attached to the battery, well attached on the other side? Most of the time we only think to check the battery, not the other side of the wire.
You might have a problem like mine directly above yours in this post, where wires are shorting out.
You can also check the computer in your dash if it's working, going to 19 off, 9, and check alternator voltage with it, and the rest of your cars voltages
Old 04-04-2014, 03:30 PM   #57
JeffM052
Just got home, jumped in and gave it a crank. Nothing. Dead.
Opened trunk, checked battery again, connections tight.
Car starts. I'm becoming convinced my car is possessed. Still going to check voltages and cables this weekend, but as long as she runs...
Old 04-04-2014, 07:12 PM   #58
lszlszx
My Ride: 1.8T, XC70
Does the dash light up with the ignition in position 2 and go out in the start position?
That would point to an ignition switch problem.
Old 04-05-2014, 01:59 AM   #59
roblivingstone
My Ride: 2000 323Ci
X2 if there is no engine light for sure.
Old 04-05-2014, 10:19 AM   #60
lszlszx
My Ride: 1.8T, XC70
Checking battery voltage at the underhood jumper terminals. In this case full voltage was present.
Checking battery voltage at fuse 29 while starting, this is the ignition switch input to the DME.
