M54 Fuel Pressure / Aftermarket Regulator Routing - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 10-29-2015, 03:27 PM   #1
diablorojo
My Ride: Supercharged 330i
Looking to stabilize my fuel pressure and figured it would be a great discussion as we are hitting higher HP numbers in our non M projects.
What happens when the hose is disconnected to the FPR on the fuel filter?
Is it possible to disconnect the vacuum house and place an aftermarket FPR inline to the fuel rail? (no vacuum to the stock FPR on the fuel filter)
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 10-29-2015, 04:01 PM   #2
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Removing the hose from the FPR will increase fuel pressure.
Install a M52/M52TU fuel filter without the FPR and use your aftermarket FPR.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 10-29-2015, 04:05 PM   #3
diablorojo
So if removing it increases fuel pressure, whats the reason to change to the other fuel filter if the adjustable FPR is going to regulate the flow anyway?
What is the advantage in switching them out?
Old 10-29-2015, 05:03 PM   #4
cosmos328Ci
If you remove the hose from the OEM FPR incorporated on your fuel filter you will have a higher fuel pressure, you will not be able to adjust the fuel pressure below this static higher fuel pressure with your adjustable FPR.
The advantage of switching the fuel filter to the M52/M52TU is you will have full fuel pressure control with your adjustable FPR.
Old 10-30-2015, 01:54 AM   #5
Davew
My Ride: 2004 330ci Msport
Fpr on stock m54 filter returns the fuel to the tank, hence why you will have no control. That's with MS43 cars anyway, not sure on the setup of ms45 cars.
Davew is offline   Reply With Quote
Old 10-30-2015, 06:16 AM   #6
diablorojo
Gotcha!!! But do I really want or need to go below the static pressure? I thought the purpose was to increase pressure for reliability. With everything else upgraded the pressure and fuel flow also requires upgrading.
Old 10-30-2015, 06:51 AM   #7
mdrobnak
My Ride: 04 330i SMG TT STG1
MS45 cars are atmosphere referenced. I had a longer return line added (from the rail) and run an aeromotive fpr. This setup works for both the Motec and the DME, and if I want to, I can add vacuum reference at any time (if I run out of pressure due to too much boost...) As has been said, you need a different filter..Using the E36 filter at the moment.
-Matt
2004 330i with Technique Tuning Stage 1 Kit, UUC Twin Disc Clutch + FW Kit, Walbro 400 Fuel Pump, Aeromotive FPR, Modified Return Lines, E36 Fuel Filter, Ethanol Content Sensor, 550i Clutch Actuator, Lengthened actuator rod, modified exhaust, and FX-R projectors.
93 Octane - 8.5 PSI : 309RWHP on a Superflow / 3XXRWHP on a DynoJet
E85 - ? PSI : ???RWHP on a DynoJet
First SSG MoTeC M150 Powered 330
mdrobnak is offline   Reply With Quote
Old 10-30-2015, 01:17 PM   #8
diablorojo
Thanks. I hunt one down.
Old 10-30-2015, 02:33 PM   #9
Hobbit382
My Ride: 99-328i 00-323i
You'll need a non oem filter for e85
Hobbit382 is offline   Reply With Quote
Old 10-31-2015, 08:27 AM   #10
rkneeshaw
My Ride: 330i ZHP
It's my understanding that the "vaccum" line on the FPR needs to be connected to the ESS manifold, because on a boosted car you need to offset the pressure against the fuel injectors. In a stock NA car you have engine vacuum that helps suck the fuel out of the injectors, but when you get to boost there is positive pressure pushing against the fuel coming out of the injectors. Looking at how a FPR works, adding positive boost pressure to the "vacuum" line will INCREASE fuel pressure to offset the positive boost pressure in the manifold.
If you keep literal vacuum on the FPR while adding boost, you are lowering your fuel pressure AND the pressure in the manifold will further hinder fuel flow, a double whammy.
At least in ESS case, they tune their fuel control assuming that you have a positive boost pressure coming down that FPR "vacuum" line during boost.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2 - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - StopTech
Build thread: http://forum.e46fanatics.com/showthread.php?t=696662
Wheelwell: 2003 BMW 3 Series
Fuelly: 2003 BMW 330i
rkneeshaw is offline   Reply With Quote
Old 03-30-2017, 04:27 AM   #11
ic033
My Ride: 330ci
May I bump the old thread..
Im running a turbo m54 and having lean AFR on high RPMs (going towards 15-16AFR).
Stock FPR is connected to the same line as brake booster, after the check valve.
By the info on the last post I should connect the vacuum hose to the manifold so it would have positive pressure?
Anyone running FPR from a m3?
Or aftermarket FPR?
Which should I go for?
ic033 is offline   Reply With Quote
Old 03-30-2017, 01:25 PM   #12
JakerMacDorey
My Ride: 93 325is
Pretty sure the check valve prevents the booster from seeing boost. If that's the case, then your FPR is also not seeing boost. You need a signal source that sees boost for the FPR to behave in the manner that you want - fuel pressure increases when engine is on boost.
JakerMacDorey is offline   Reply With Quote
Old 03-30-2017, 01:28 PM   #13
ic033
My Ride: 330ci
Yup, after check valve there's no boost.
Okay, let's try that tomorrow!
Old 05-04-2017, 04:53 AM   #14
eemil
My Ride: Z3 Coupe
Hi!
I will be running a Walbro GST450, i heard that many have had problems with the increased flow on stock fuelfilter/fpr combo on M54.
I just bought an M52TU fuelrail with "built in" FPR which should handle way more flow. Very cheap upgrade along with an stock M50/M52/M52TU filter
eemil is offline   Reply With Quote
Old 05-04-2017, 10:00 AM   #15
Pole position
My Ride: E46 330ci
Just remove stock filter/regulator. Install upgraded can style filter in its place. Bolt adjustable fpr to trans tunnel. Route soft lines back into the stock lines. Route map line back to the manifold or pressure block. No check valves or anything, you want to reference manifold pressure and set the static pressure with the car running and the map line removed. Done, works great, no issues even with a huge fuel pump.
Shut up and drive
Pole position is offline   Reply With Quote
Old 05-04-2017, 06:16 PM   #16
summit56
My Ride: 328ci AA stage 1
What FPR are you guys using?
summit56 is offline   Reply With Quote
Old 05-05-2017, 12:45 PM   #17
Pole position
My Ride: E46 330ci
I use a fuelab mini regulator
Shut up and drive
