Old 03-15-2016, 02:53 PM   #41
Pole position
My Ride: E46 330ci
Originally Posted by Hobbit382 View Post
Flex fuel is still a ways away. I think up next will be live tuning and the boost control, after that maybe flex fuel.
Cool, sounds good. What kind of boost control parts should I get to integrate into the stock dme system? I was originally thinking innovate scg-1 but that's more of a standalone system. I can wait if not all is know yet as well. Thanks for the help
Shut up and drive
Pole position is offline   Reply With Quote
Old 03-15-2016, 02:57 PM   #42
daniel_f.
My Ride: 330iC
You already have everything on your car
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 03-15-2016, 03:15 PM   #43
Pole position
My Ride: E46 330ci
I am confused what I have to control boost? Will it be via just wastegate spring changes and/or a manual boost controller instead?
Shut up and drive
Old 03-15-2016, 03:29 PM   #44
daniel_f.
My Ride: 330iC
Its to early to go into details, but it will be full electronic solution
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 03-19-2016, 07:57 PM   #45
Pole position
My Ride: E46 330ci
Just Another M54 Turbo Build. By the People, for the People
I installed the fuel pump, filte and regulator today.
First of all, the fuel pump adapter from CRE didn't work, maybe I got the wrong one or something. The adapter was still much too small for the plastic housing. So to get around this issue I went to the parts store and got some big fuel filler hose and cut it to the length of the pump, and then jammed that into the housing and used hose clamps to secure it. Its kinda ghetto but will get the job done. I then used heat shrink butt connectors to splice the wiring. I also used a very hot heat gun to soften up the hard plastic fuel tubing to allow it to fit over the slightly larger fuel pump barbs. I clamped it just to be sure. That took care of the pump install.
I originally was going to run the regulator hanging off the fuel filter, but the gauge on the regulator sat too low so I could not. I used some extra large fuel filler tubing to make the filter wider and fit snugly in the spot the stock filter/regulator goes.
For the regulator the placement can be kind of annoying because of how the lines have to run and ground clearance. I wish I just went ahead and moved this to the engine compartment, but maybe another time. I had to use around 4 feet of hose to wrap around and make the hose not kink and still get to go to where it needed. Remember to use fuel injection hose, not regular fuel hose. I ended up just drilling into the chassis's "frame rail" and using self tapping screws to mount the regulator. I also put plenty of anti-seize on the adjustment screw.
Sorry for the lame pictures, my phone died at the beginning of the work and I was at my friends garage. Car runs well though, no issues. Make sure to heck for leaks well and set the fuel pressure with the vacuum line detached.
ID:	627132Click image for larger version
ID:	627133Click image for larger version
ID:	627134Click image for larger version
ID:	627135Click image for larger version
Shut up and drive
Old 03-23-2016, 05:02 PM   #46
Pole position
My Ride: E46 330ci
I am going to install the radiator next with the sleeve in the radiator line, but capped, so its ready to go. My belts/pulleys are getting kinda noisy so I am going to replace them along with the crank pulley/harmonic balancer for peace of mind while I'm in there and have the room as well.
I have been daily driving the upgraded fuel system and it has been running great, you wouldn't even know it has changed, which is exactly like it should be.
Also I was wondering when you edit the tune to run on just one pre-cat O2 sensor do you need to use a specific wire or does it just pick up on whichever wire the single O2 sensor is connected?
Shut up and drive
Old 03-23-2016, 07:11 PM   #47
Hobbit382
My Ride: 99-328i 00-323i
Attachment 627478
Needs to be bank 1 sensor.
Hobbit382 is offline   Reply With Quote
Old 03-23-2016, 10:18 PM   #48
Pole position
My Ride: E46 330ci
Sounds good, thanks.
Shut up and drive
Old 03-24-2016, 11:32 AM   #49
mrbobmicjoe
My Ride: 2001 325i
do you have any better pictures of the filter? curious to see how you hooked those hoses up and mounted the thing.
What fuel pressure did you set the regulator at?
Cooling stuff looks good! I also have one of those adapters and a bunch of hoses on the way from good ol china!
mrbobmicjoe is offline   Reply With Quote
Old 03-24-2016, 11:42 AM   #50
Pole position
My Ride: E46 330ci
I don't, but the filter really just sits in the stock clamp thing. The hoses are really easy to set up, just leave yourself some extra length so you can loop it around so everything can fit without kinking. Fuel tank > filter > regulator > engine
My gauge isn't too detailed so I just set it around 52psi.
Thanks, yeah that adapter was a 15$ eBay special lol. Also just ordered a bunch of hose on Ebay, although made in America, saved a ton over a name brand.
Shut up and drive
Old 03-26-2016, 11:37 PM   #51
mrbobmicjoe
My Ride: 2001 325i
On the AN fittings on the fuel filter did you use actual fittings or did you just slide the hose over and use a hose clamp?
Old 03-27-2016, 11:27 AM   #52
Pole position
My Ride: E46 330ci
I used a female -6 AN to 3/8" barb fitting from ebay
Shut up and drive
Old 03-31-2016, 09:56 PM   #53
Pole position
My Ride: E46 330ci
Pulleys came in, just waiting on the damper (febi on eBay for 75$) and I'll install the upgraded radiator along with belts/pulleys and coolant feed.
Also ordered some cheap eBay Chinese gold heat reflective tape and "volcano" manifold wrap. Just ordered a little to see how the quality is. Seems good so will order some more, enough for the hood above the turbo and covering most of the stuff around the manifold like ac lines, sheet metal, maybe some charge pipe, and valve cover. All of this only cost 29.99....shipped....from China....
Also just got some sumitomo tires....This is a real budget build.
Shut up and drive
Old 03-31-2016, 10:08 PM   #54
mrbobmicjoe
My Ride: 2001 325i
Whats your plans for the A/C lines? Really want to keep mine, it gets hot in summer
Old 03-31-2016, 10:18 PM   #55
Pole position
My Ride: E46 330ci
They don't seem to be too far in the way so for the hard lines by the manifold exit I think I will heat them up with a torch and bend them out of the way a little. For the lines running to the rear I will wrap them with heat tape and make sure they aren't too close to the down pipe. Honestly seems like something you kinda just need to make work on the fly. I rather have no turbo than no a/c, so a/c is mandatory on my car as well.
Shut up and drive
Old 04-01-2016, 12:35 AM   #56
mrbobmicjoe
My Ride: 2001 325i
Hmmmmm im considering buying a used hose on ebay and testing the bending idea
Old 04-02-2016, 09:41 AM   #57
Pole position
My Ride: E46 330ci
If anybody is curious, this is what a non-oem Febi dampener looks like. Pretty standard, but saves some coin.
ID:	628355Click image for larger version
ID:	628353Click image for larger version
Was going to put "stage2" in this weekend but it just started snowing so am going to hold off to see what tomorrow looks like.
Also just ordered the PMAS HPX maf and CXracing exhaust manifold/downpipe.
I also have been waiting on the 4 bolt oil pump solution from bimmerworld, by gsx I believe. I suggest anybody putting money into their motor upgrade that, not worth it all going down the tube because of the stock bolt/shaft failing.
Shut up and drive
Old 04-03-2016, 06:34 PM   #58
mrbobmicjoe
My Ride: 2001 325i
Attachment 628355Attachment 628353Attachment 628354
Im wondering if the oil pump really is a big concern for our HP goals.... Only people ive seen break them are running crazy high HP. i was just planning on doing the secured pump nut
Old 04-03-2016, 07:07 PM   #59
Pole position
My Ride: E46 330ci
I agree, but you can never be sure. I am doing the big upgrade just to get it out of the way while I'm in there. I originally was planning on just the nut though. A middle ground may be an upgraded shaft and safety wired but like VAC and Achilles offer.
Shut up and drive
Old 04-03-2016, 09:16 PM   #60
daemonicus
My Ride: batmobile
oil pumps unfortunately have problems even on stock cars that go to the track/autocross.
harmonics issues due to revving high and staying in the upper rpm band is what causes them to fail, not any specific horsepower number.
daemonicus is offline   Reply With Quote
