Old 05-19-2017, 12:39 PM   #581
Pole position
My Ride: E46 330ci
The head porter I used made 1150hp on a Volvo 4 cylinder engine prior to starting on my stuff.
Wow. That's intense
Shut up and drive
Pole position is offline   Reply With Quote
Old 05-19-2017, 09:09 PM   #582
Pole position
My Ride: E46 330ci
Shut up and drive
Old 05-19-2017, 09:33 PM   #583
cosmos328Ci
My Ride: 398.5whp. 498.8ftlb
Love that head gasket.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
http://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 05-20-2017, 08:04 AM   #584
cwarel
My Ride: 330ci coupe
Was that volvo 2000 v40 1.9T? Because Ive heard those engines can stock hold 2.5 BAR
cwarel is offline   Reply With Quote
Old 05-21-2017, 08:02 PM   #585
avantgarde
My Ride: 2001/2005 325xi A/M
Hey PolePosition
Question, you heap love on the PMAS MAF sensor. can you tell me how well the resolution and how far you had to scale the MAF to get the Target AFR and the actual AFR to be relatively close?
Are you still able to use the entire range of the PMAS MAF (650-800+whp with 3" tubing) without losing idle resolution?
Also, you had some serious problems earlier when you had the exhaust done a while back. What was the problem with the MAF? You just said "MAF is not an issue anymore" and left it at that.
I'm thinking I might replace the standard MAF with the PMAS MAF as I start to lay some infrastructure... I may go turbo, I may not. But either way, I would like to lay the infrastructure in if I do go that direction.
avantgarde is online now   Reply With Quote
Old 05-22-2017, 01:05 PM   #586
Pole position
My Ride: E46 330ci
Just Another M54 Turbo Build. By the People, for the People
Yeah I ran the maf while NA for a while. Nothing was wrong with it, I just thought there was I believe. As far as scaling, Hobbit set that up very quickly. So far it's been faultless. I don't know many details about the resolution etc. my car has always idled well so I guess it's good.
In other news
Shut up and drive
Old 05-22-2017, 01:09 PM   #587
avantgarde
that looks like a 6262 GTXRep They are already known good past 650 wheel horsepower on 2-2.5liter engines.
I was looking at using a 6262 DBB GTXRep, myself. I'm excited to see how this turns out.
Old 05-22-2017, 01:10 PM   #588
Pole position
My Ride: E46 330ci
Close, it's a 6262 turbo by BoostLab. They have their own line of turbos now, with a 1 year warranty and everything. Pretty good deal at 1k as well.
Shut up and drive
Old 05-22-2017, 04:37 PM   #589
zha50
My Ride: '04 325ci 5MT
Excellent progresses ! Be very interesting how the new fire breather goes ! Closely following
'04 325ci M-sport 5MT
- Bone stock -
zha50 is offline   Reply With Quote
Old 05-22-2017, 05:31 PM   #590
avantgarde
Are you going to try to get your AC working when you get it all back together or have you just said "screw it" Lol?
Old 05-22-2017, 05:56 PM   #591
Pole position
My Ride: E46 330ci
Thabks zha50!
As for the ac, I would like to get it going. Not sure what's been wrong with it, but after this motor install it will be the highest priority item. It works when I put power to the compressor, so it's just something simple I need to find.
Some more installs
Shut up and drive
Old 05-23-2017, 04:12 AM   #592
cosmos328Ci
Hi Pole position,
What size is the head gasket?
Bore Dia
Thickness
Cheers.
Old 05-23-2017, 08:47 AM   #593
Pole position
My Ride: E46 330ci
Originally Posted by cosmos328Ci View Post
Hi Pole position,
Bore Dia
Thickness
Cheers.
Not sure, here's the link. Its sizing worked with my bore diameter, 84.5, so i just ordered it.
http://server.pure-pf.com/webshop2/e...50mm-bore.html
Shut up and drive
Old 05-23-2017, 12:02 PM   #594
cosmos328Ci
Cheers.
Old 05-23-2017, 08:58 PM   #595
Pole position
My Ride: E46 330ci
More progress
Shut up and drive
Old 05-24-2017, 12:49 AM   #596
cosmos328Ci
Coming along real nice.
Old Yesterday, 01:41 PM   #597
Pole position
My Ride: E46 330ci
Motor is all together. Downpipe mocked up as much as I can do outside the car. Looking forward to this long weekend to get it all installed and started up!
Shut up and drive
Old Yesterday, 01:46 PM   #598
klodkrawler05
My Ride: 02 BMW M3
looking awesome! down to the wire now for getting it ready for Gridlife eh??
klodkrawler05 is offline   Reply With Quote
Old Yesterday, 02:26 PM   #599
Pole position
My Ride: E46 330ci
Yep, as usual lol. Only thing that sucks is I'm still stuck on the nexen tires for now. Struggled with them last time, called, and they said yeah they arent designed for lap time but to last forever to survive drift comps. Kinda pissed as that isnt as described at all, and they now justttt came out with the "g" version for racing. Those bridgestones are fast! either way itll be a good time, you get the supercharger on?
Shut up and drive
Old Yesterday, 03:00 PM   #600
klodkrawler05
My Ride: 02 BMW M3
Hopefully the extra power helps overcome the tire for now!
Yup got the supercharger on and took the car to a local autocross last weekend to shake it down, hoping to get some little stuff plus aero buttoned up this weekend so we can try for an all BMW podium!
