RHD M54 B30 build - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-08-2016, 12:06 PM   #41
autospeed_01
My Ride: 2000 328Ci
That's awesome! Are you using a FaroArm laser scanner or the point probe for your reverse engineering?
My Build Thread
From Salvage to Custom Widebody
DTM Style Angel Eyes (flat bottom)
autospeed_01 is offline   Reply With Quote
Old 12-08-2016, 12:12 PM   #42
parkin001.tp
My Ride: bmw e46
I'm just using the touch probe
parkin001.tp is offline   Reply With Quote
Old 03-29-2017, 05:37 AM   #43
parkin001.tp
My Ride: bmw e46
Just a small update,
Exhaust system- 2.5" single pipe system from the down pipe back, i'm using two mufflers, one is 18" long, the other is 10", this is going to be a daily(ish) car and i'm only going to be pushing 400bhp max when finished, i want this to be a reliable build so im not chasing big numbers (yet anyway ).
there is a section at the front where a de-cat pipe can be used when im at a Track day-Etc.
i haven't started the down pipe yet, but im planning on using a 3.5" pipe for this, space permitting.
Camber arms - i Took it upon myself to design and manufacture a set of rear adjustable camber arms, being an engineer, and having access to CNC machines, i did exactly that. for 50 i have made myself a set of heavy duty camber arms... WINNER! being me, i also put my builders mark on it
Cylinder head- the cylinder head is finished, i just need to work on the lower half of the engine now, i also had chance to fit all of my custom manifold flanges, all ready for tacking the manifold together now
one other brief note, i've noticed on a few of the Cam journals (Pictured), there is some light scoring on them, i've used some light sandpaper to polish them, i'm not too concerned this may be a problem, but would be nice for a second opinion has anyone else encountered this?
ID:	652570   Click image for larger version
ID:	652571   Click image for larger version
ID:	652572   Click image for larger version
ID:	652574   Click image for larger version
ID:	652575   Click image for larger version
Old 04-15-2017, 03:03 PM   #44
parkin001.tp
My Ride: bmw e46
For the first time in a year and a half, the rear axle is back on and touching the floor!
Making some good progress now
The custom made adjustable camber arms fit perfectly too!
ID:	653528   Click image for larger version
ID:	653529   Click image for larger version
Old 07-22-2017, 04:47 PM   #45
parkin001.tp
My Ride: bmw e46
Hey guys, first update in a while!
I've been working on quite a few things recently and developing a few ideas..
First off is addressing the infamous oil pump nut, I have designed and made my own version of the 4 bolt system, yes it is based on the GSR oil pump shaft but I have decided to remove the dowels from the design, using the centre diameter of the shaft to centralise the sprocket. I am also using nord lock washers to prevent them coming loose. Despite doing this, I was concerned with the amount slack in the chain once I had test fitted it to the block and it made my wonder... Why isn't there a tensioner?
I had a tensioner from an audi 1.8t (20 valve) engine laying around that I rebuilt a while back and offered it up to the block... Looked perfect to me! So I modified the block by drilling a 3mm hole for the spring and tapping a m7 hole for the tensioner to bolt to. Looks great to me and there is tons of clearance when the cover is on!
I have also finally got the car back on 4 wheel's so it's good progress! I've fitted some 360mm discs up front too, ready for some brembo's
The discs are from a range rover sport and cost 89 for the pair...winner!
ID:	663482   Click image for larger version
ID:	663490   Click image for larger version
ID:	663498   Click image for larger version
Old 07-22-2017, 06:39 PM   #46
Pole position
My Ride: E46 330ci
Looks fantastic! The pump tensioner is awesome
Shut up and drive
Pole position is offline   Reply With Quote
Old 07-23-2017, 01:41 AM   #47
parkin001.tp
My Ride: bmw e46
Thanks! I forgot to mention, there is a 2mm washer behind it to make it more central over the chain
Old 07-23-2017, 06:35 PM   #48
Davconelectric
My Ride: 2 dog powered sled
Nicely done with both pump shaft and tensioner.
Davconelectric is offline   Reply With Quote
Old 07-23-2017, 06:36 PM   #49
volter
My Ride: E46 330Ci
That's cool. Have you got part number of that tensioner? You sure it's taken from 1.8T 20V?
volter is offline   Reply With Quote
Old Yesterday, 02:02 AM   #50
parkin001.tp
My Ride: bmw e46
Yeah I'm sure it is, OE- NUMBER - 06A 115 130 B.
There are quite a few variants of the 1.8t 20v engine a few use this tensioner.
Old Yesterday, 03:02 AM   #51
volter
My Ride: E46 330Ci
Seeet
