Sponsored by The Tire Rack
Old 07-19-2016, 10:35 AM   #21
CharlieFoxtrot
My Ride: 02 330Ci
Originally Posted by BKMrSteel View Post
Took a road trip with that tire setup, encountered some bad roads along the way, and I blame the low profile for having replaced two wheels after.
I'd sooner blame the distortion of the tread/sidewall/rim relationship due to the stretched fitment. Properly fitted tires will have tread rubber and structure protecting the rim under most impacts. Stretched tires will theoretically let the tread structure tuck up between the beads, leaving nothing but the sidewall between the edge of a pothole and your wheel rims.
Fence, I'm sure some people drive hard enough to find understeer on public roads. I did that kind of thing when I was a teenager, though my cars back then had much lower limits than our E46s.... These days, it'd have to be a serious emergency situation for that to happen.
CharlieFoxtrot is offline   Reply With Quote
Old 07-19-2016, 10:36 AM   #22
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
What would be the stock tire size you guys recommend for the front wheels, 7.5x17? I need to change the tires I have on ASAP cause it tramlines so bad
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 07-19-2016, 10:43 AM   #23
CharlieFoxtrot
My Ride: 02 330Ci
BTW, I'm very happy with my square 245/8.5" setup and new alignment specs so far. Drove from FL to NY with no tramlining or other complaints on the highway. I've got 36psi all around. Now I can rotate the tires, and it looks subtly cooler.
It was a real challenge to find a pair of decent 8.5" rears to use in the front. Took a year of periodic Craigslist searching in 3 major metro areas. I ended up buying a staggered set of 4 in FL, but the price was close to what I'd have gladly paid for just a pair. SO now I have four 7.5" wheels in storage in FL.
Old 07-19-2016, 10:48 AM   #24
CharlieFoxtrot
My Ride: 02 330Ci
Originally Posted by lllRazorlll View Post
stock tire size
That's the words, right there. 225/45/17. Quality brand tires. Suspension parts in good condition, good alignment job done by a guy who knows BMWs, just a hair of toe-in and minimum negative camber.
Old 07-19-2016, 04:43 PM   #25
lllRazorlll
Modded ///Member
My Ride: '00 328i
How much do run flats contribute to tramlining? Didn't realize my tires were way off
Old 07-19-2016, 04:56 PM   #26
zander271
My Ride: 6spd ZHP/5sp XI
What are your tire specs for the rears? If your fronts are 205's you should have 205/50/17(D=25.07) not 205/45/17(D=24.26)
ZHP Mods: JB Lightweight fly wheel (10.5 pounds), Koni FSD ProKit, Supreme Power Drop Hats, Hotchkis front(30.2mm)/rear(25.4mm) sway bars, Sprint Booster, AFE Stage 1 Intake, Morimoto EvoX-R Headlights, Orion V4 Angel Eyes, Satin Black 18x9 ET42 APEX ARC-8 Wheel
330xi Mods:Front Koni Yellow Struts and Rob43 Rear 9 Way adjustable Rear Dampers,Custom Sport Springs,Supreme Power Drop Hats,ZHP 5 speed shift knob
Old 07-19-2016, 05:21 PM   #27
CharlieFoxtrot
My Ride: 02 330Ci
We're in a style 68 thread and his sig pic shows style 68 wheels. That means on a non-M3 he should have 225/45 and 245/40 on 7.5 and 8.5" wheels.
Razor, my computer just flushed the longer response I wrote. Short version is, runflats do contribute, even with correct fitment. You should be able to find plenty of online comments to that effect, including that specific tire model on BMWs. With wrong fitment they probably contribute more. You've got several things wrong, start fixing them and it can only get better.
Old 07-19-2016, 05:28 PM   #28
zander271
I know its a style 68' thread. I asked because he commented about having the wrong size tires. Having a large mismatch in tire size between front and rear would cause some weirdness.
Old 07-19-2016, 06:41 PM   #29
CharlieFoxtrot
My Ride: 02 330Ci
OK, I can see your point about different front/rear sizes.
But you threw me off with this. He "should" not have 205s at all, so the aspect ratio question is moot.
Old 07-20-2016, 12:52 AM   #30
zander271
Style 68 wheel and tire questions
Diameter of the tires is very important. Depending on the ratio difference the front wheels would be doing more rotations.
Old 07-20-2016, 07:54 AM   #31
lllRazorlll
Modded ///Member
My Ride: '00 328i
The rears are Michelin Primacy MXM4 225/45. I bought these wheels with the tires on them. I wanted to know the stock/OEM tire size to get rid of tramlining and so it can be OE spec
Yeah they aren't the right tires...they're run flats and the wrong size which makes it hell to drive
Old 07-20-2016, 02:12 PM   #32
zander271
Yea get the correct size tires on your car and report back.
Old 07-20-2016, 03:12 PM   #33
lllRazorlll
Modded ///Member
My Ride: '00 328i
I got the stock front tire size what about stock rear 8.5x17?
Old 07-20-2016, 04:42 PM   #34
CharlieFoxtrot
My Ride: 02 330Ci
...he should have 225/45 and 245/40 on 7.5 and 8.5" wheels.
quoting myself....
Old 07-20-2016, 05:57 PM   #35
lllRazorlll
Modded ///Member
My Ride: '00 328i
quoting myself....
Oops. Thanks for your competence
Old 08-08-2016, 10:54 AM   #36
lllRazorlll
Modded ///Member
My Ride: '00 328i
To all owners of staggered style 68s: what size rim is your spare wheel?
Old 08-09-2016, 09:08 AM   #37
xdmikey
My Ride: e46 cabrio
I have a mini spare. It works to get me to a Dis**** Tire but I rarely take trips in this car.
DINAN CAI, 3.46 DIFF, CDV DELETE,DINAN S2 & EXHAUST,HARDTOP
xdmikey is offline   Reply With Quote
Old 08-09-2016, 01:37 PM   #38
CharlieFoxtrot
My Ride: 02 330Ci
Everything I've read says 7.5" for the spare. FWIW. I have a donut...
Old 08-18-2016, 09:07 AM   #39
lllRazorlll
Modded ///Member
My Ride: '00 328i
Gotcha thanks again
Old 03-23-2017, 12:33 PM   #40
STREETFIGHTER50
My Ride: '04 Sil-Gry ZHP 6-Sp
So what sizes did u end up going with? Also, for the guys that are running the 17x8.5" square set up can u run a 255/40 tires on the front without a spacer?
BEWARE of this crook Daniel Duran AKA "e46ornothing"
http://www.e46fanatics.com/forum/sho...202&highlight=
STREETFIGHTER50 is offline   Reply With Quote
