Sponsored by The Tire Rack
Old 03-23-2017, 03:06 PM   #41
CharlieFoxtrot
My Ride: 02 330Ci
Streetfighter-- Tire fit might depend more on your suspension. With stock sport suspension, the 245/40 fit great on my car. A 255 is only (nominally) 10mm wider, so a problem is unlikely. There's probably a bigger difference between different brands in the same size than there is in the same tire, one size larger...
CharlieFoxtrot is offline   Reply With Quote
Old 03-23-2017, 07:05 PM   #42
STREETFIGHTER50
My Ride: '04 Sil-Gry ZHP 6-Sp
Does it look like u have a lot more room for that extra 10mm? 17x8.5" ET50 seems like they'd be really close to the struts.
BEWARE of this crook Daniel Duran AKA "e46ornothing"
http://www.e46fanatics.com/forum/sho...202&highlight=
STREETFIGHTER50 is offline   Reply With Quote
Old 03-27-2017, 09:06 PM   #43
CharlieFoxtrot
My Ride: 02 330Ci
Sorry, I can't get my hand back there with the car on the ground. It might be on jacks soon, so I'll try to get you an answer. It's close, for sure, but don't forget the extra 10mm width is only 5mm on each side...
Old 04-24-2017, 10:34 PM   #44
burntoutrubber
My Ride: 330ci
I have a 330cic with the standard style 68 17x7.5 17x8.5 staggered setup. I want to run a square setup because I drive 15k per year and the tire cost is making me crazy because without rotating the tires I can't get a warranty. I am not keen on 8.5 all around, and would prefer not to have to buy new wheels to go 17x8 all around.
Has anyone run 17x7.5 with 225/45R17 on all four corners? I have factory sport suspension (refreshed, of course, but not lowered or modded)
And would I need spacers on the rear to make the wheels even?
burntoutrubber is offline   Reply With Quote
Old 04-25-2017, 02:06 AM   #45
STREETFIGHTER50
That will work. A lota folks runnin all four 17x7.5s as their winter set ups. I'd use 235/45R17s though.
Old 04-25-2017, 02:31 AM   #46
burntoutrubber
My Ride: 330ci
Will 235s fit on 7.5 rim? I thought they required 8 minimum
Old 04-25-2017, 03:32 AM   #47
STREETFIGHTER50
235s will fit on a 7.5"-9" rim per TireRack specs. I'd go max rubber on there. JMO more meat will have more grip & looks better. Also, more curbage protection lol
Old 04-25-2017, 04:38 AM   #48
CharlieFoxtrot
My Ride: 02 330Ci
No spacers needed.
You might want to find a good bmw shop to align the car with more tire-saving specs. There are several threads here that discuss it.
Old 05-15-2017, 09:15 AM   #49
RedOctober330i
My Ride: 2002 330i
Anyone had issues running a square 7.5 set vs the OEM 7.5/8.5? I'm looking to do a winter setup and I currently have the staggered set, but tires are trash. Another member here has a square setup for real cheap with new tires and I'm tempted to pick up his set and sell mine. Buddy of mine says OEM is "better" but does it really matter?
FWIW- Running Style 67 M rims in the summer.
One BMW to rule them all....
RedOctober330i is online now   Reply With Quote
Old 05-15-2017, 10:37 AM   #50
STREETFIGHTER50
U can definitely run 7.5" squared. No problems at all. I'd even go 235/45R17 on them
