Old 05-25-2016, 10:29 AM   #21
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Originally Posted by evanr614 View Post
D90. It's kind of a dinosaur now. I kinda kicked the hobby of photos when I got my E46...:/
Nice. I'm trying to get into photography.
On a side note, if you're planning on changing your shocks and struts, should you invest in reinforcement plates for the strut towers and possibly subframe reinforcement in the rear?
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 05-25-2016, 10:41 AM   #22
evanr614
My Ride: used 2 have 2 pedals
Reinforcements for the front/rear are inexpensive and a good idea. Subframe reinforcement however is a whole other ball game
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 05-25-2016, 12:39 PM   #23
evanr614
Rear End Restoration Picture Thread
Snuck under the car and took a few photos. I want to get rid of some of the rusty brackets and bolts eventually, the cross member needs cleaned but other than that it looks pretty good under there.
Old 05-25-2016, 12:52 PM   #24
lllRazorlll
Modded ///Member
My Ride: '00 328i
Don't you need to weld in the strut tower plates also?
Old 05-25-2016, 12:56 PM   #25
WDE46
My Ride: '13 128i, '04 330Ci
The front strut mount reinforcement plates just sit between the strut mount and the body. No welding.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 05-25-2016, 12:56 PM   #26
evanr614
I'm just referring to the bolt on plates. For the front strut mounts and rear shock mounts
Old 05-25-2016, 01:46 PM   #27
lllRazorlll
Modded ///Member
My Ride: '00 328i
Oh really? I thought they had to be welded. I'll get on that if that's the case.
Could you post a link to what you are referring to, please?
Old 05-25-2016, 01:49 PM   #28
evanr614
http://www.ebay.com/itm/Rear-Shock-M...-/301874943137
and i actually have a set of front reinforcements im not using if you want to buy them
Old 05-25-2016, 01:57 PM   #29
lllRazorlll
Modded ///Member
My Ride: '00 328i
Do those fit in the front and the rear? And do those do the same job as these plates in the front? https://www.turnermotorsport.com/p-3...t-plates-pair/
Old 05-25-2016, 01:58 PM   #30
evanr614
That ebay link is only for the rear. they go on the inside of your trunk on top of your shock tower. they essentially do the same job
Old 05-25-2016, 02:42 PM   #31
lllRazorlll
Modded ///Member
My Ride: '00 328i
So in here?
https://www.google.com/search?hl=en&...cufOaKymd-M%3A
Would you say a strut tower brace does the same job as those reinforcement plates that go underneath the shock tower 'hat'?
Old 05-25-2016, 03:03 PM   #32
WDE46
Old 05-25-2016, 05:13 PM   #33
///BM3R
My Ride: 330ci...///M3 soon
nice work dude. love your e46...think ill be doing the same with subframe and suspension.
///BM3R
///BM3R is offline   Reply With Quote
Old 06-06-2016, 12:02 PM   #34
evanr614
Best 40 dollars I ever spent. trunk lip spoiler
Old 06-06-2016, 12:07 PM   #35
lllRazorlll
Modded ///Member
My Ride: '00 328i
+1 I love lip spoilers
Old 06-06-2016, 02:37 PM   #36
brea
My Ride: 00 328Ci & 98 528i
evanr614, how much was that mason bar you installed? Did you have to contact them directly to order? I only see the complete setup that ties into the shock towers on their website. That bar you have looks like a good compromise between support and preserving trunk space. I'm assuming it included the threaded rods and other hardware? Thanks in advance
'00 328Ci - M54B30 Manifold - EU2 - Rogue Engineering UDP's - Catless headers - OE M3 Engine/Trans Mounts - UUC Stainless Brake & Clutch Lines - ST Coilovers - SPC Adjustable Rear LCAs - Mason Engineering Rear Subframe Support - Burger Motorsports 12mm Spacers - 5spd "ZHP" Shift Knob
brea is offline   Reply With Quote
Old 06-07-2016, 08:56 PM   #37
evanr614
Had the magnaflow welded in today. Fitment isn't perfect but the sound is really nice compared to the muffler delete. Now I just have to decide between getting headers or working towards the manual swap or getting a shark injector. I'm leaning towards the swap.
I ordered it directly from him but I believe they are on eBay. It is a great compromise between support and trunk space. All of the hardware is included it just takes some fabrication to make it all work.
Old 06-09-2016, 10:43 AM   #38
brea
thanks for the response, I ordered mine off ebay yesterday. Your 328 looks great, nice work. Would be interested to hear a review of the full poly bushing setup after another few thousand miles. And definitely go for the manual swap.
Old 06-09-2016, 12:15 PM   #39
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
Sounds like this is turning into your build thread. Exhaust looks sharp. I approve of your plan of working toward the manual swap. I was going to ask for a sound clip but then I realized it would include fail-ish auto trans shifts. Get that 3rd pedal!
Also maybe I missed it but what's the latest on the white 330 from FL?
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 06-09-2016, 12:23 PM   #40
evanr614
Yeah I haven't put enough miles on it yet to have a valid review.
I am going to start to piece together the bigger parts for the manual swap! I may do a sound clip of the muffler. It's been a while since I had the stock one but it's a little deeper and sportier than stock but far from loud at all so it's nice.
The white 330 is in its new home in Columbus and will be undergoing a COMPLETE cooling system, system overhaul, power steering overhaul, CCV overhaul, odds and ends such as cabin filter, intake filter, fuel filter, fuel pump, VCG refresh with new plugs/coil boots, OFHG, and then a few suspension items for now such as front control arms/FCABS. I know I'm missing some things but now we're just waiting on parts in the mail
