Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 2.60 average. Display Modes
Old 05-16-2017, 09:28 PM   #841
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Thread: small/simple/dumb questions
Anyone have these show up in PA Soft and know what they're about?
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 05-19-2017, 07:02 AM   #842
lllRazorlll
Modded ///Member
My Ride: '00 328i
Need to do brakes soon. What are your thoughts on these pads & rotors? I'm looking for something that has good bite but less dust than OEM
Rotors
https://www.fcpeuro.com/products/bmw...z4-126-34048sr
https://www.fcpeuro.com/products/bmw...z4-34111164539
Pads
https://www.fcpeuro.com/products/bmw...em-34116761244
https://www.fcpeuro.com/products/bmw...set-hb136f-690
Old 05-19-2017, 09:50 AM   #843
My Ride: Lexus
Both pads will cause OEM or higher dust levels. I'd personally go with the Brembo blanks.
overall i'd go with brembo blanks and textar pads. no need for the slots. however it is probably a decent product.
keep in mind Textar 330 fronts are known to squeak so this could affect you if the pads are similar size as 330 (I forget if they are) but things could've changed since a few years ago.
i'd go ATE or Jurid if you can find them.
Old 05-19-2017, 09:54 AM   #844
My Ride: Lexus
first one i'd guess your mirror met some unnatural resistance when tilting? or something up with the motor some how. does it work?
i've seen all sorts of errors on many E46s, mostly shadow codes, but the thing the code is for still works fine. If it works, don't worry!
second one i dont know. sorry. chalk these up to e46 gon' e46. you'll go crazy if you constantly search for shadow faults. cause everything will shadow misbehave
Old 05-19-2017, 10:21 AM   #845
lllRazorlll
Modded ///Member
My Ride: '00 328i
330 brakes are bigger than 328 from my understanding. I heard good things about all of these brands. I just don't want to sacrifice bite but if I can find a good balance between that and low dust, then that would be great
Old 05-19-2017, 12:49 PM   #846
YoitsTmac
My Ride: 328Ci
You really might as well just get 330 upgrades while you're here. A good test for me is (for autos): Where is your foot on the brake pedal, height wise, in relation to the gas pedal?
YoitsTmac is offline   Reply With Quote
Old 05-19-2017, 01:00 PM   #847
YoitsTmac
My Ride: 328Ci
Anyone want to pass me some love and get me a pinout for the CD53 plug?
Old 05-19-2017, 02:05 PM   #848
lllRazorlll
Modded ///Member
My Ride: '00 328i
Can you rephrase that
Old 05-19-2017, 02:11 PM   #849
YoitsTmac
My Ride: 328Ci
A good test for bite is to share how far the minimum distance your foot is depressed on the brake pedal (in relation to the gas pedal) to keep the car from rolling.
Separate fact: you should go with 330 brakes if changing your setup
Yeah I got distracted mid reply last time
Old 05-19-2017, 02:38 PM   #850
evanr614
My Ride: used 2 have 2 pedals
not sure i'd bother with tracking down used calipers/bleeding brakes if you just need some pads and rotors. you'll be happy with refreshed components. the 330 brakes are barely bigger
Atlantis Blue 328Ci Project Thread
http://forum.e46fanatics.com/showthr...523&highlight=
evanr614 is offline   Reply With Quote
Old 05-19-2017, 02:45 PM   #851
lllRazorlll
Modded ///Member
My Ride: '00 328i
I'll try to measure that. You mean when at a red light the minimum pressure needed to keep the car from rolling?
330 brakes are 325mm front and 320mm rear whereas the 328 brakes are 300mm front and 294mm rear. I feel like that is a noticeable difference
Old 05-19-2017, 02:47 PM   #852
evanr614
i guess i'll let you be the judge, and i know you can do the math but 5-6mm is not very much lol
Old 05-19-2017, 04:59 PM   #853
lllRazorlll
Modded ///Member
My Ride: '00 328i
Rotors are practically 1" larger my friend
Old 05-19-2017, 05:03 PM   #854
evanr614
5mm?
Old 05-19-2017, 08:27 PM   #855
lllRazorlll
Modded ///Member
My Ride: '00 328i
Front rotors are enlarged by 25mm and rears are 24mm
Old 05-19-2017, 09:00 PM   #856
brea
My Ride: 00 328Ci & 98 528i
From what I gathered when I looked into doing this swap, the fronts are pretty straightforward in that you just need to change the calipers and brackets to go along with the larger pads and rotors. But the rear requires that you change the hub, axle, bearing and the entire trailing arm if you want the parking brake to work.
I know several people who swear by akebono pads for minimizing brake dust while maintaining OE performance. I stuck with OE all the way around because it wasn't worth the hassle of sourcing everything for a minimal increase in braking.
Sent from my iPad using E46Fanatics
'00 328Ci - M54B30 Manifold - EU2 - Rogue Engineering UDP's - Catless headers - OE M3 Engine/Trans Mounts - UUC Stainless Brake & Clutch Lines - ST Coilovers - SPC Adjustable Rear LCAs - Mason Engineering Rear Subframe Support - Burger Motorsports 12mm Spacers - 5spd "ZHP" Shift Knob
brea is offline   Reply With Quote
Old 05-19-2017, 11:14 PM   #857
s3bas
My Ride: 325ci 02
Engine coolant is reading -40 celcius what is repobsible for this thermostat . And tempeture on dash is giving off weird read temps co stantly changing . How many thermostats does the car have and what are they for if it does ?
Sent from my HTC One using E46Fanatics mobile app
s3bas is offline   Reply With Quote
Old 05-19-2017, 11:17 PM   #858
HOODY007
My Ride: '04 330ci
Engine coolant or outside temp? Check to see if the temp sensor is damaged...
On another note, at what interval should the DISA valve be rebuilt? I'm pretty sure I have 200K on my original one...
HOODY007 is offline   Reply With Quote
Old 05-19-2017, 11:22 PM   #859
s3bas
My Ride: 325ci 02
Both Engine temp and outside temp are acting up . We're is the outside thermostat or how would I search for it on you tube . Not sure I got my vamps seal and anti rattle kit done at 195,554. And I have 205,300 now . I also get code p0011 . But I already changed the sensor closest to the pasanger side wheel next to the second dart air pump is that the one that this code belongs to .
Old 05-20-2017, 05:55 AM   #860
YoitsTmac
My Ride: 328Ci
Shots fired lol. But yes, at a red light on flat land. Easy way to compare since they will all be the same amount of force so it's easy to compare bite. Don't need a ruler measurement, just a "smudge" or "lot" above or below the gas
combined, common, simple, thread, unorganized
