Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 2.60 average. Display Modes
Old 08-16-2016, 12:12 PM   #81
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
Originally Posted by orb View Post
The E46 is already old, the first ones were made nearly 20 years ago now. I doubt we'll see anything we haven't already. Materials quality had improved since earlier BMWs.
Haven't seen any problems with dashboards, and I don't think we will. Any interior plastics that would degrade already have. Pillars sag, the console pieces melt, etc.
Never underestimate the power of UV... Heh. It wreaks havoc on paint and typically those issues don't start to show up for a number of years.
That said, a lot of it comes down to basic care and feeding (car cover, dash cover, sunshade, garage, regular detailing, etc).
I've been encouraged by what I've seen of the E46's material quality, particularly re:the dash. I have a hunch the two-piece dash design helps too. It's easier for defects to show in one large swath of plastic/vinyl rather than in two.
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 08-16-2016, 01:39 PM   #82
Mike Larry
Mike Larry's Avatar
My Ride: 575 nello
I've had my EML light come on twice and the combo of the DSC and e-brake light come on twice in the past couple months, which has spanned about 1000 miles of driving. I did some research and I believe the EML light problem to be a faulty TPS sensor and the DSC/e-brake thing to be a dirty speed sensor, but I haven't had the time to confirm or address these problems. I'm planning to buy a Schwaben BMW/MINI scan tool to pull the codes to confirm the next time the light comes on, and then DIY or take it to a shop depending on how difficult the job is. In the meantime, is it unsafe to drive my car for short distances or should I just take it to a shop now even though none of the warning lights are on? My e46 isn't my daily driver anyways.
Mike Larry is offline   Reply With Quote
Old 08-16-2016, 02:18 PM   #83
My Ride: Lexus
Automotive glass, regardless of auto make, is inherently UV-rejecting. Most add tint too, so really, little to no concern there.
Old 08-16-2016, 09:44 PM   #84
bobnagga
My Ride: 2000 323ci
Here's a dumb question: what's that bottom cover called and is it structural? Not the plastic piece, but the metal one behind it with the square hole to access the oil plug?
Nevermind, got it.
bobnagga is offline   Reply With Quote
Old 08-17-2016, 01:43 AM   #85
Archbid
My Ride: 2003 330cic
Reinforcement plate
Archbid is offline   Reply With Quote
Old 08-17-2016, 05:40 AM   #86
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
Ok to drive. When lights active means you won't have abs just regular brakes. Job isn't difficult just soak the area of the wheel sensor with a penetrant oil prior to removal. I'm not sold on a dirty wheel speed sensor in every case though it is the cheapest route for diagnosis. A BMW scanner will tell you the exact fault location.
BMW-North is offline   Reply With Quote
Old 08-18-2016, 11:24 AM   #87
lllRazorlll
Modded ///Member
lllRazorlll's Avatar
My Ride: '00 328i
Who wants to help me build the Need for Speed Most Wanted M3 GTR in the "Hero" livery in real life?
8:40
>IN SEARCH OF GRAY SEDAN SPORT SEATS<
lllRazorlll is offline   Reply With Quote
Old 08-18-2016, 12:41 PM   #88
asianisafish
My Ride: 330ci
So... I have 2004 330ci and have the mtech2 front bumper
But I can't for the life of me find the right expanding rivets that hold it in.
I bought some from ecstuning but I ordered the wrong ones.
Went to the BMW dealership twice and the dude had no idea what I was talking about and gave me the wrong ones twice. So I'm lost.
Currently held in by zip ties by the grill and random holes in the aluminum carrier bar
asianisafish is offline   Reply With Quote
Old 08-18-2016, 01:08 PM   #89
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
Have you tried realoem.com?
Old 08-19-2016, 01:48 PM   #90
lingon300k
My Ride: 2005 325xi Automatic
I thought of an actual question that I generally though too dumb to ask:
I often downshift, using the manual mode on the auto trans, to engine brake when going down hills. Is there any downside to this?
lingon300k is offline   Reply With Quote
Old 08-19-2016, 02:03 PM   #91
05SMG
My Ride: 2005 330ci ZSP
+1 on realoem.com. I replaced wheel well liners using that source. If the parts clerk knows what he/she is doing they'ed go straight to that site and find it. Find your part numbers and bring it in and have them look it up to cross reference both searches.
05SMG is offline   Reply With Quote
Old 08-19-2016, 04:07 PM   #92
Archbid
This should be fun...
And it is likely that it doesn't matter either way. You are not going to get meaningful brake fade if you brake, and your clutch and brakes are going to wear out from the 100,000 other shifts and stops you do regardless.
If the forces are enough to stress rods and gears to failure then you are at the end anyway.
Drive the way you like to drive!
Old 08-19-2016, 04:43 PM   #93
lingon300k
Thanks for the response!
It's less about fun, and more about keeping the brakes cool/slowing the car more efficiently. Technically, I live on a mountain. The hills I'm talking about are real hills.
I like the manual mode on the automatic for this reason. Otherwise, I don't see any use for it. Sport mode raises the shifts enough for passing, getting through traffic. I often have to brake pretty hard while going down a very steep hill then stop at a stoplight, which is probably the worst thing you can do to your brakes.
Old 08-19-2016, 04:52 PM   #94
My Ride: Lexus
Not really. The upside is it'll help your brakes slow the car. The downside is potentially more wear on your engine as it's now spinning faster. But that's what a car is for, so use it. =)
Old 08-22-2016, 12:54 PM   #95
Spannerhead
Save the Manuals!
OK I've got one. Not sure what to search for on this. What is this?
(image is not of my car; I don't have auto lights)
Mine looks misshapen, almost like somebody just drilled a small, rough hole in the plastic. But then I see other E46s with the same little hole in their light switch panel.
Old 08-22-2016, 01:03 PM   #96
lllRazorlll
Modded ///Member
My Ride: '00 328i
That's the auto dimmer for the red interior lighting when the lights are on
Old 08-22-2016, 01:18 PM   #97
Spannerhead
Save the Manuals!
Ah; thanks. So, at night, if I shine a flashlight on the sensor, it should......dim the red dash lights...?
What threw me off is that the edges of the hole are so jagged. It looks for all the world like somebody took a punch and hammer to the plastic panel.
Update: After taking a closer look at it, it's the square sensor in the round hole that threw me off. The hole itself is perfectly round, but from a distance, the reflections made it look slightly jagged. Live and learn.
Old 08-22-2016, 03:48 PM   #98
wallaby13
My Ride: 330i 5MT
I need some replacement floor mats. Any recommendations? all weather preferred but anything is better than the ones in the car
wallaby13 is offline   Reply With Quote
Old 08-22-2016, 03:56 PM   #99
lingon300k
WeatherTech FloorLiner. After having them for the past year, I doubt I'll ever buy any other mat, or own a car without having them in it.
Old 08-22-2016, 04:40 PM   #100
ybuybmw
My Ride: 03 330ci
How do I tell when my clutch is on its way out? It does not slip at all, but it grabs very softly. I'm wondering if there's a way to gauge how much life is left (120k miles, mix of city traffic outside DC) or if you just know once it starts slipping.
ybuybmw is offline   Reply With Quote
combined, common, simple, thread, unorganized
