Old 11-15-2016, 10:46 PM   #1
HOODY007
My Ride: '04 330ci
Vibration from rear center tunnel
Hello all,
I have a 2004 330ci, Steptronic, 192K miles. I've had the car since 155K, and the following problem has not changed in severity. Under medium/ hard acceleration from a stop, I can feel a vibration from the rear of the center tunnel, from behind the transmission. I have already had the CSB and guibo replaced with genuine BMW parts, and the two mechanics I took the car to have suggested a driveshaft rebuild, owing to a worn CV joint on the driveshaft. Is this the likely culprit, or could it be something else?
This vibration is significant to the point where it affects acceleration.
Thanks,
Hoody
HOODY007 is offline   Reply With Quote
Old 11-16-2016, 03:19 AM   #2
BiH55
My Ride: 2001 bmw 325i
If the CV joint is bad it would cause the vibration. On my 325i the cv is also bad
BiH55 is offline   Reply With Quote
Old 11-16-2016, 10:21 AM   #3
E46Envyy
My Ride: 04 330ci Auto
If the car was driven with a bad CSB for a long amount of time it may warp the drive shaft. This may be the case.
E46Envyy is offline   Reply With Quote
Old 11-16-2016, 02:28 PM   #4
HOODY007
My Ride: '04 330ci
Ah! Thanks- the car had this issue when I bought it; there's no telling how long it was driven like that. I presume I will need a new CSB and guibo, as well as new transmission, engine, and diff mounts as well? Also, in this scenario, could my existing driveshaft be rebuilt? Or am I looking at buying a whole new one?
Thanks!
Old 11-16-2016, 02:38 PM   #5
swordsman11868
My Ride: 2003 325i
I changed guibo and CSB due to age and some vibration issues.
Long story short vibration is still present between 25-40 mph both on accel and decel. Some have suggested worn rear diff bushings and I tend to agree since they have never been replaced with 165k miles on the clock.
I'm just here to change the world.
BMW Wiki: http://www.bimmerfest.com/wiki/index.php
E46Fanatics inspiration Robolop: http://forum.e46fanatics.com/showthr...87566&page=101
2016 Beheadings in Saudi Arabia: 92.
swordsman11868 is offline   Reply With Quote
Old 11-16-2016, 03:51 PM   #6
E46Envyy
Thanks!
when my brother had this issue he waited about a month until he had time to change the CSB and guibo. Once they were changed it reduced the vibration but it was not gone. He then got a used drive shaft and new CSB( cannot remove the CSB without damaging it) which fixed the problem. Not sure about transmission or engine mounts, should be fine. The diff mount maybe but as I said he had no other issues.
good luck, Lachlan
Old 11-17-2016, 04:47 PM   #7
HOODY007
My Ride: '04 330ci
good luck, Lachlan
Out of curiosity, did your brother change his driveshaft because it was not salvageable, or because he was able to find a used one for less than the cost of a rebuild? I'd like to have the original one rebuilt if possible, as it assures me a longer lifespan than a used one...
Old 11-17-2016, 05:23 PM   #8
E46Envyy
I think it was not salvageable as fixing a slight warp is very hard. He picked up the used shaft for around 100$. Never thought of the drive shaft as a wear item, should they not last forever if the CSB/ guibo was replace before failure?
If you can get it rebuilt for a reasonable price then go for it, likewise the drive shafts are very common.
Old 11-17-2016, 05:51 PM   #9
das_autobahn
My Ride: 2004 330ci coupe
grease breaks down and sometimes goes dry causing failure. my ujoint was dry and rusted/bound on only two caps causing vibration. the cv and giubo are fine. i have a reman shaft w new csb/cv joint and also have a new giubo going in tomorrow.
my old one ill take to get rebuilt (it can be done) balanced and on standby for a swap when needed in another 100,000 miles lol
das_autobahn is offline   Reply With Quote
Old 11-17-2016, 05:51 PM   #10
CylonRed
My Ride: '01 E46 330i sport
Info from a indy repair shop owner who specializes in BMW. Their drive shafts are not serviceable as they are splined (Ford/Mazda among other do it as well). So if it needs to be replaced it will have to be rebuilt. He only trusts one person who is in Arizona while Mike Miller (from Roundel magazine) trusts 2 - one in GA and the other in OR. It is quite difficult to get right.
If there is no rush then they can probably rebuild your driveshaft (if it can be) else I would assume that it would be like other parts - they send a drive shaft with a core charge and you send yours back and get the core money back.
CylonRed is offline   Reply With Quote
Old 05-19-2017, 09:27 AM   #11
HOODY007
My Ride: '04 330ci
Just in case anyone else comes across this post, the vibration turned out to be collapsed transmission mounts. After changing both the mounts and the CSB, the vibration is gone.
Old 05-19-2017, 10:06 AM   #12
Archbid
My Ride: 2003 330cic
Appreciate your closing the loop!
Archbid is offline   Reply With Quote
Old 05-19-2017, 12:11 PM   #13
Fox Fader
My Ride: '05 325i
Hard to believe those other techs, I mean mechanics didn't see that as easy as those mounts are to see.
'05 325i handshaker CW Package 130k
M Shift Knob - 545i Short Throw w/ Suede Boot - Tint: 20%r, 35%f - PowerStops
HomeLink® - Clear Fender Signals - LED Interior Lights - Tein S.Tech - Koni Str.t - Clear Corners
10 Ford GT 401a 5sp 17k miles
17 High-Ball Matte Nuclear Sunset Orange
11 KLR 650
07 Tuono Factory
03 F150 STX Lightning replica
11 Kia Sorento SX (wife's)
Slammin Tunes
Fox Fader is offline   Reply With Quote
