Turbo project for a budget - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-29-2016, 05:31 PM   #21
cwarel
My Ride: 330ci coupe
Originally Posted by Commanderwiggin View Post
Ahahahah thats funny made my day while I was in traffic
cwarel is offline   Reply With Quote
Old 11-29-2016, 05:32 PM   #22
cwarel
Since I have RS4 maf i wanna try to work with it see whats gonna be better draw or blow through setup and from there ill try to tune it myself so i could drive to a shop that will tune it for probably ( or maybe i wont touch it at all and just drive to the shop with charge pipe off and maf on stock position and swap it at the shop. Anyways I cant say anything for sure yet , i gotta get the turbo at least so I could start matching up, because 1 of the engines i got in the backyard , the subframe is still on it or engine is on the subframe with motor mounts etc, because 1 of the cars my dad had in the backyard was a coupe 330ci with 20k miles on it , and some retard with fireworks set the car on fire , so we saved all the subframe tranny engine , but body couldnt be rebuild cuz fire department cut the roof off to put the fire down , kinda said that 20k mile car gone but that was years ago , and its time for the remaining of the car help me. Once everything arrives I will bolt up manifold with a turbo to the engine and I will start making a custom mount ( P.S im **** welder so im just gonna tack it together and let someone else weld it ) hopefully im smart enough to figure this out)
Old 11-29-2016, 06:58 PM   #23
Grm3e46sc
My Ride: M3 e46
Just for the record...what miles your engine has?
Any comp test?
Grm3e46sc is offline   Reply With Quote
Old 11-29-2016, 07:35 PM   #24
cwarel
Any comp test?
The one im gonna boost has 34k on it , the backyards engines ~20k and engine in convertible I have which is 2.5 has 40
Engine that im boosting has comp to specs and the 2,5 liter too
Idk about the backyard engines thou , but before I boost it ill do comp test again and post it
Old 11-29-2016, 08:44 PM   #25
cwarel
Also how much boost 330 engine can take before it blow my gasket ( on pump gas ?)
Old 11-29-2016, 09:23 PM   #26
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: used to be an auto
10,000,000x10^-6
Modification Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 11-29-2016, 09:25 PM   #27
cwarel
Originally Posted by CarbonZHP View Post
10,000,000x10^-6
really 10 psi? bro really trynna make my brain work for this at 10 30 pm ?))
Old 11-29-2016, 11:25 PM   #28
daniel_f.
My Ride: 330iC
In another forum there is one with a stock M54B30 with ~600whp record for M54B25 is ~800whp if i remember correctly.
Plenty of space. RS4 maf curve should be dailed in?! JD Improved should be using it?!
Im currently at baby vacancy!
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-29-2016, 11:28 PM   #29
cwarel
If i would of turbo charged 2.5 , I can get pistons dirt cheap that are the same as CP quility wise not sure what the CR will be , but for 8 pistions you would pay 100 bucks or less ( pistons come in sets of 4 )
So 10 psi it is ?
Old 11-29-2016, 11:37 PM   #30
daniel_f.
My Ride: 330iC
As long as there is no physically limitation, i would always go with the stock parts first!
http://www.bimmerboost.com/showthrea...-block-M54B30-)
22psi
Siemens MS42 wiki!
Siemens MS43 wiki!
Old 11-29-2016, 11:48 PM   #31
cwarel
22psi
Yeah he's running e85 . but im talking about pump gas)))
Old 11-30-2016, 09:14 AM   #32
Jim_Coupe
My Ride: Audi A4 BMW 530i
How do you calibrate those injectors? I curious since im going to bigger injectors.
Jim_Coupe is offline   Reply With Quote
Old 11-30-2016, 09:36 AM   #33
cwarel
It is explained in the wiki , I already made a map for bigger injectors
VERY EASY , but i see guys talking about latency and I tried to look it up but cant find anything ( hopefully latency on my injectors are close or the same cuz they are siemens deka also just 440cc ( also got 458 cc which are the green ones )
Old 11-30-2016, 10:25 AM   #34
Jim_Coupe
Deadtimes is this i think "ip_ti_add_dly__vb" ..You can get away with stock latency on such small injectors.
Anyway in the WIKI i se ALOT of Maps and constants but which of those are the Global constant for injectors? I get that the fuelmaps must be tuned but im just interested in tje injectors. Scaling injectors is a very important ting to do and calibrate before any tuning takes place..
I found these.. Seems to be constants for each individual injector
T_ti_as_0
T_ti_as_1
T_ti_as_2
T_ti_as_3
T_ti_as_4
T_ti_as_5
And these. some of them are pure Fuel maps in my view.. They should all not go under topic injector scaling? Wich of below is just for injectors? Wich did you edit?
c_ti_min_iv
ip_ti_fl__n
ip_ti_cst__n__tco
ip_ti_fast_wf_thd_min__tco
ip_ti_slow_wf_thd_min__tco
ip_ti_tco_1_is_ivvt__n__maf
ip_ti_tco_1_pl_ivvt_1__n__maf
ip_ti_tco_1_pl_ivvt_2__n__maf
ip_ti_tco_2_is_ivvt__n__maf
ip_ti_tco_2_pl_ivvt_1__n__maf
ip_ti_tco_2_pl_ivvt_2__n__maf
ip_tib__n__maf
ip_tipr_cst__tco
ip_ti_tco_ch__tco
ip_ti_tco_ch_is__tco
Old 11-30-2016, 10:31 AM   #35
cwarel
I edited all the maps that are given in the wiki except latency , the way It is described there.
But i havent tested my tune yet , because Im waiting for the fuel injectors O-rngs and filters
Well my injectors sort of close to stock so I believe I dont need calibration , but telling you once I get the O-rings Ill swap injectors and see how the car runs and from there ill see what I can do.
Old 11-30-2016, 10:55 AM   #36
Jim_Coupe
Ok.. Many of those mentioned above i cant even find in the XDF provided.. hmm
Ill do some reserach and get back with some info on this.. I will test this on a 630cc E85 car soon so we will find out a more exact way on how to do this correct
Old 11-30-2016, 11:01 AM   #37
cwarel
ip_ti_cst
ip_ti_fast_wf_thd
ip_ti_slow_wf_thd
ip_ti_tco_1_is_ivvt
ip_tib
type them like this in 64 KB file
Old 11-30-2016, 11:11 AM   #38
Jim_Coupe
ip_ti_cst
ip_ti_fast_wf_thd
ip_ti_slow_wf_thd
ip_ti_tco_1_is_ivvt
ip_tib
Thanks ill try that
Old 11-30-2016, 12:14 PM   #39
cwarel
Thanks ill try that
Yeah no problem , I just noticed if you type same thing as given in the wiki it wont find sometimes because in the xdf its named different i guess
Old 11-30-2016, 01:19 PM   #40
daniel_f.
My Ride: 330iC
Ive started giving the maps some more usefull name before we created the wiki. So right now some maps are more difficult to find due to me being lazy
Siemens MS42 wiki!
Siemens MS43 wiki!
